Question about Proview PL926WBi 19" LCD Monitor
Proview 900w I bought a proview 900w monitor the other day and am having problems with the resolution settings. It did not come with a cd to install the correct driver, and when i download the driver for it off of proview website and try to update drivers, it says it is fine. But it isn't... i am currently using 1024x768 in display properties...which makes it the CLOSEST to normal looking. Everything looks stretched and horrible! how do I fix this so i can enjoy this nice wide monitor?
  • 2 more comments
  • shitbird Dec 24, 2007
    resolution settings ?
  • jy5244 Dec 29, 2007
    I bought a Proview PL926Wbi 900w monitor the other day and am having problems. The screen looks stretched horizontally.
    It came with a cd to install the correct driver, but the driver is not on the cd.
    When I click on the cd folder that supposedly contains the driver, I get the message that the location does not contain info on this hardware.
    I am using 1024x768 resolution in display properties.
  • Gilbert Smith
    Gilbert Smith Jan 04, 2008
    need drivers for Windows XP
  • turpentine Jan 07, 2008
    I need a user manual, please.
    Problem Solver:
  • 20 Answers
This prob is memory is in monitor so contact sevice engg of proview
Posted on Dec 29, 2007
Am useing prvivew 900 w not work as full screen
Posted on Jul 19, 2008
    Problem Solver:
  • 8 Answers
Can your vidio card even handle a 4200 dpi monitor dosent sound like it try upgrading the computer before you upgrade the screen i have a proview it runs great at 4200 dpi but my vidio card can handle it :)
Posted on Jan 27, 2010
Push the button on the monitor labeled auto. it'll fix it.
Posted on Jan 04, 2008
SOURCE:
Does my Proview PL926WBi 19
Any monitor will work with any computer provided the correct graphics card driver is installed. When you install Vista and you do not install the graphics driver, Windows will default to Generic VGA driver and you will not get the best resolution that the monitor can display.
Jan 29, 2010 | Proview PL926WBi 19" LCD Monitor
I have a proview monitor PL926WBI Model 900W
It seems to be that something gets hot inside after a few minutes of operation of the monitor. So I placed a small fan so that air flows thru the monitor and that did it. What gets hot inside , I don't know.
Oct 25, 2009 | Gateway FPD 1510 15.1" Flat Panel LCD...
I have a proview 900w and it comes on but only for a couple seconds then the backlights turn off. Does anyone know how this might be fixed?
check your signal cable from your computer or the port itself. one of those might have a problem causing the monitor to go off.
thanks
wonder
Sep 18, 2009 | Proview PL926WBi 19" LCD Monitor
My monitor does not work right. it says vga not support.. its a proview 17" flatscreen..active matrix tft lcd
I suspect your Computers Display settings need adjustments and or a Driver from Proview installed...therefor if you can get on the net, I would look at FAQ's on Proviews Website, i.e:
http://www.proview.net/Support/FAQ_Question.aspx?pi=2026
hope that helps,
Bastian
Jun 02, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
19" proview LCD monitor light and signal
How old is this thing? Mine is about 4 or 5 years old... junk it!
Mar 25, 2009 | Proview PL926WBi 19" LCD Monitor
Proview wb926wbi monitor
Try changing the resolution to 1440x900. This is the ideal resolution for this monitor.
To change the resolution:
Right click on an empty space on your Windows desktop.
Choose Properties (XP) or Personalize (Vista)
Choose the Settings tab (XP) or Display Settings (Vista).
Slide the resolution slider to 1440x900, then click apply.
If asked whether you want to keep this setting, choose yes/ok.
Note: Not all video cards support this resolution. Updating your video card's (not monitor's) driver may add it.
Jun 29, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor having resolution & display problem
Plz change resolution or refresh rate in desktop properties.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 07, 2008 | Computers & Internet
Proview PRO576 error message "mode not supported" and will show nothing else
Okay, we got a fix by having another monitor hooked up to our computer and going in to display and changing the display settings to a lower setting. The screen resolution - turn it to lower - I guess somehow - the setting was too high for our monitor. Don't know how it changed itself though. Anyway, change it to a lower resolution then re-hook up your monitor and see if it works. The reslution can be pushed back up until you notice the problem again.
Mar 05, 2008 | Proview PRO576 15 in. Flat Panel LCD...
Proview 900 series black flat panel monitor
Same problem, and solution 1 given here fixed my Proview 900W. A few of the 470uF caps on the power board were oozing dielectric probably due to overheating. Hopefully the replacements will hang in there for a couple more years...
Oct 17, 2007 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
3,839 people viewed this question
Top Proview Computers & Internet Experts
 Mike M
Mike M
Siul Oyaratgam
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
