Question about Dacor Preference PGR30 Gas Kitchen Range
Dacor oven The pre-bake feature is on every time I try to turn the oven on bake and I dont know how to turn it off I have tried.
    Problem Solver:
  • 4 Answers
I believe it is supposed to be. Prebake, including the convection fan, will happen until the oven reaches the set temperature.
Posted on Nov 25, 2009
Large oven in dacor dual oven range broiler comes on when i select bake
on bake both bake and broil will come on the broil shuts down around 260 deg
this is normal its done to shorten preheat time
Jun 03, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
Oven won't heat
quite possibly the element burnt out .
Sep 22, 2017 | Dacor MCS230SS Millennia Electric Double...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
I dont no how to pre heat the oven
To pre-heat an oven is to simply turn it on to the desired temperature and wait 5 to 10 minutes. If you have a timer then set the timer for the desired time you want to pre-heat then begin baking as usual.
There is no magic to pre-heating an oven and everyone that bakes has a different opinion.
Sep 23, 2010 | Ovens
F8 error message on Dacor gas range
Look for the error code in the troubleshooting section of the owner's manual. Otherwise, search for:
Make Model error code F8
Sep 29, 2017 | Kitchen Ranges
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
Dacor Oven Won;t Heat
power surges can short out the electonics in appliances. If you can locate where the tech sheet is and I would say its behind the control panel on top, look at the wiring diagram and see if there are any replaceable fuse's. Or a resetable fuse for the heating element. If not check to see if power is getting to the main control bord. If there is power there you may need to replace the control.
Jul 19, 2007 | Dacor ECS130 Epicure Electric Single Oven
Oven door won't open
Hi... Having problems with my Dacor ERD36 as well, I came across this posting that might help with your particular situation of not being able to open the oven door.
Here is the link to the forum:
http://www.applianceguru.com/forum1/2189.html
In case you can't get to the forum link, here is the response:
Have a 2nd person at the circuit breaker turn off power. You press and hold the cooktime keypad. The other person turns the breaker back on. The display will show the 4-character ID code of the ERC (e.g., 1180). You have 30 seconds between each test.
Press and hold these keys on sequence:
convection bake
standard bake
pure convection
broil
timer 2 (momentary push only)
stop time
clock
Finally, we arrive at the test we want:
Open the door, push and hold cook time for 10 seconds. Self clean latch motor will activate. Door latch will complete a cycle. The test will end the ERC will display the time of day.
Complete this test within 30 seconds or you'll get an F0 code (stuck keypad).
I hope this helps.
patti
Dec 06, 2006 | Dacor Epicure ERD36 Dual Fuel (Electric...
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
Dacor Preference PGR30 Gas Kitchen Range Logo
447 people viewed this question
Top Dacor Kitchen Ranges Experts
Oloyede Monsuru
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
