Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Posted on Sep 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My water dispensor want work, I'm getting water, no humming when
Whrilepool refrigerator Mdl ED25DQ, how to replace water dispensor switch.
Anonymous
Level 2:
  • Expert 38 Answers
  • Posted on Sep 14, 2009
Anonymous
Expert
Level 2:
Answers
38
Questions
0
Helped
24418
Points
150
Before you replace the switch have you checked the following.
Proper waterflow / pressure, filter condition, water line has no been crimped or bent, water line is not frozen.
Have you tried unplugging the unit and waiting a few minutes, plugging it back it and checking it?
I am sure these Q's may sound dumb, but I don't know everything you have already done. AND I hate to see people spend money on stuff they don't need.
Hope one of these help.
If so, please rate me.
Thanks,Matt
Water dispenser quit.ice maker works fine you can hear motor hum when pressing water dispenser button
You should not hear the noise of a motor unless you are trying to dispense ice. Is that the case your ice dispensor is not working?
3helpful
No water from dispensor in door.
Ice supply line is frozen in the freezer door. Using a hair dryer with the door open you have to thaw the line. This will take time but this will fix.
3helpful
Whirlpool ed25dq icemaker not working even though
the water valve maybe the problem as it is a dual one,, and if filter moded it has 3 solnoides flow . that control water . ck sol with ohm meter or test cord . . ice maker also works only at 15 deg or lower . so ckk tempt of freezer .. mm
Maytag plus msd2758ge water-dispensing problem
check your micro switch behind the water dispensor lever. You'll need to take the face off the ice/water dispensor to find the switch. Or could be the water valve is stuck in the open position. You'll need to replace the water valve. Hope this helps!
2helpful
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
I have a GE refridgerator model number GSS25IFRE BB the ice maker and water dispensor just stopped working. The filter is new. and still has the problem with the plug in. Also if you hold a glass in the...
Do you have water getting to the filter? if not:first loosen filter and see if you might have air in line,secondly, the copper or aluminum water line from water supply to solenoid may be limed-up,third loosen line at solenoid and see if your getting water that far,those solenoids pulsate when operated on A.C.current you should hear a hum when activated to get water and that would explain pulsating light at water dispenser
Water dispensor not working
Since you have water getting to the icemaker/dispenser, the most common problem I've seen is the solenoid valve is history and needs replacing. It could also be the switch that is normally activated by the dispenser itself and in turn activates the solenoid valve or the wiring in-between the switch and valve, but I have personally not seen either one of those go bad.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
