Question about Sharp AL-1655CS Laser Printer
Replace td warning
I just replaced the drum, but now the warning is flashing and doesn't reset
  • Anonymous Jan 04, 2008
    yes have same problem help me
I went into the user menu and RESET FACTORY setting and the error went away
Posted on Jan 09, 2008
2005 LS lexus 430 replaced the brake pads but the warning light is still on how do i reset
Per a Google search you can't reset it. The sensors that trigger the light must be replaced w/new ones.Call the dealer for pricing on the 'brake wear sensors'.
There are 'workarounds' but I'll let you find those for yourself.
Nov 06, 2013 | TPMS Scan Tool with TPR Reset Tool Kit...
Drum warning is flashing
It you take the drum out, look on back, there is a little fuse on the top rear of the drum . Replace that fuse. Radio Shack will have them. Once the fuse is replaced, put the drum back in, It will see a new fuse, blow it and reset the counter. Really easy.
Sep 20, 2011 | Xerox CopyCentre C20 Black and White...
Alarm says replace drum soon. Can the message be
The "replace drum soon" indicater is a warning for you to have a new replacement drum "on-hand". Soon the display will change to "REPLACE DRUM" AT WHICH TIME THE UNIT WILL STOP PRINTING.
When the new drum cartridge is then installed...the REPLACE DRUM indicator will be reset. DO NOT replace the drum before the machine says to.
Jun 04, 2010 | Muratec F320 Plain Paper LED Fax
How to reset pcu correctly
Cant remember if these models use the rebuildable pcus or not.
If it does:
change the developer / blade / charge roller/brush and drum if needed then run the TD initilization .
If copy quality is good then you can run td ini without changing those parts and just replace them at failure.
If it doent:
Change the whole pcu
it will reset itself
or if copy quality is good run the td ini and the message will clear.
Apr 06, 2010 | Ricoh Aficio 120 Copier
The drum unit has been replaced but the drum warning message is still flashing. How do I reset? Have tried user RAM clear but that did nothing.
That should have reset itself. A couple of things. You may have received a bad cartridge and need to report it as DOA, from wherever you purchased it.
Also, sometimes if you replace the drum when it says : Drum unit low or reorder Drum, and you replace it before it tells you to replace the drum, it will not reset.
There is a fuse that blows quickly and resets the counter. That may not have been attached right and not the machine did not detect a new cartridge.
Feb 18, 2010 | Xerox WorkCentre Pro 635 Laser Printer
Xerox FAXCENTRE 2218 Drum Warning displays on
Often times with that machine, if you replace the drum before it says replace, it will not reset.
Jan 04, 2010 | Xerox FAXCENTRE 2218 18PPM FAX
Xerox Work Center 657 Will Not Recieve, After Replacing Drum
Check to see if when he reset the fax reverted back to receive only as a default.
  1. Press [Menu] (the Up arrow key), and press [3], [1], [0], then press [1].
  2. Select the Answer Mode:
    • Press [1] to select Auto answer, then skip to step 3.
    • Press [2] to select Manual answer, the press [Stop] to return to the Standby mode.
  3. If you select the Auto answer feature, use the numeric keypad to enter the number of times (must be 2 digits, 01-10) the phone must ring before the machine answers, then press [Enter].
    NOTE: When the machine is set to Auto answer and the set number of rings occurs, the machine answers with a fax signal tone and enters the Auto Receive mode.
  4. Press [Stop] to return to the Standby mode.
Jun 30, 2009 | Xerox WorkCentre Pro 635 Laser Printer
Locked up AL-1642CS with blinking Drum Light
the clear key may be stuck which seems to lock up your machine. The procedure to reset the drum lite is clear, auto (exposure setting), clear, auto when hit in a timely manner the display will go blank. Enter 24 then press the start key, then enter 07 and press the start key again. If you can't get the keys to work the circuit board may have cold solder joints.
Good luck
May 03, 2009 | Sharp AL-1642CS Copier
Sharp AL-1655CS Laser Printer Logo
161 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
