Question about Sharp 32F540 32" TV
Sharp 32f540 switching input channels
Hi, our tv just started switching channels from input1 to input 2 and 125 on its own. We have checked all the connections, replaced batteries in the remote and unplugged the tv overnight. My question is this an easy and inexpensive fix?
  • 4 more comments
  • Ladythree Dec 11, 2007
    Thanks but we're not close enough for neighbors and their remotes.
  • Ladythree Dec 13, 2007
    Has anyone found a solution to this problem yet?
  • Anonymous Feb 15, 2008
    Same
  • sourleg Feb 15, 2008
    same problem with mt sharp 32f641, switching inputs. don't see any pattern to it.
  • bobbyg617 Mar 29, 2008
    Same sharp 32" (32F540) TV and its switching from any channel I have on to input 2...only 4+ yrs. old. Any help?
  • bart_4_0 Jul 07, 2008
    My tv switches channels on its own. We can't figure out how to make it stop
  • 129 Answers
Ladythree,
the problem for your unit is the manual button switches. In the long time it wasnt used. it got stucked and somewhat rusted. This problem can best be addressed by replacing the buttons switches(tac switch).
this should solve your problem.
chris
Posted on Mar 29, 2008
How do we set up the tv to pick up air channels with the indoor amplified antenna?
Terk FDTV2A HDTV Indoor Antenna Unboxing Setup Test Part 1
double check your TV is set to the correct input before scanning.
the link above shows installation
press the helpful button
Jan 22, 2016 | Sharp LC52E77UN 52 in TV
Where's the fuse on sharp 2004 32f540
It can be located at the main power supply regulator board.
Mar 04, 2013 | Sharp 32F540 32" TV
My tv has a audio but no video?
If your TV has features to put off the display either on the TV or on remote, change it. If not, check the input cable for any loose contacts. Try changing channel and see whether some channel is being shown. If it is shown, the problem is in the input cable connector. If you are using input from yellow, red, white RC cable through a desk top or some other device, the yellow cable might have come off while cleaning the TV or may not be tightly fit. In short, check all the inputs and let me know.
Jul 04, 2012 | Sharp Televison & Video
Hi, my RCA CRC311 BT turns on my Sharp television, changes the channels, etc, but it won't switch to video mode, even when I hit input. It is an old TV, but I used it to watch videos, dvds and play games...
Unfortunately you will not be able to switch input.
I also have a Sharp, I have tried 5 different universal remotes. None will switch input. I guess that function is not provided properly.
Sep 18, 2010 | RCA RCR311B Remote Control
Sharp Aquos LC-37D64U Skips HDMI
The problem was caused by ME not setting up my Harmony Remote correctly after buying the new TV. The remote was programmed to turn on SA8300>turn on Receiver>Turn on TV>Select channel 3.
Simple change from select channel 3 to select Input 4.
Mar 23, 2009 | Sharp Televison & Video
Sharp vcr problem
The way to connect them is as follows:
1. Connect the cable from the wall to the cable input on the cable box.
2. Connect the cable box RF output to VCR RF input (VCR must be on channel 3).
3. Connect the RF output from the VCR to the RF input on your TV (TV must be on channel 3).
After all the connections are done, leave the VCR and TV on channel 3 and use the cable box to select the channel you want to record programs from.
Good Luck.
Jul 10, 2008 | Sharp VC-A410U VCR
Switching Channels Automatially
Good day.
You need to pull out the board from the unit for you to replace the tac switches.
Regards,
chris
Jul 07, 2008 | Sharp 32F540 32" TV
I am trying to fix a Sharp 27k-s100 television.
Can you use the remote control to change the channels? If not, it may be that to need to reprogram the remote to work with your TV. I just had the same problem. I have GE universal remote and have reprogrammed it to work with my SHARP 27k-s100 TV by following these instructions: http://www.ehow.com/how_9190_program-ge-universal.html The code that worked for my TV is 173. Other codes listed for SHARP are: 004, 006, 012, 029, 095, 111, 112, 113, 122, 171. Good luck!
Sep 11, 2007 | Sharp 27K-S100 TV
Sharp tv changing channels
Well, the only thing that seems to be working so far is to plug AV cables into the "input 2" ports (on the front of TV). I plugged in my PS2, without turning it on. It has not switched at random since (about 30 minutes - it had been switching off and on for the past 2 hours). Anyone else have similar success?
Oct 28, 2006 | Sharp 32F540 32" TV
Sharp 32F540 32" TV Logo
211 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
