Question about Standard (CRT) Televisions
Tube tv - no picture
Picture went out... black screen.
sound - good
5 Suggested Answers
  • 81 Answers
SOURCE: black screen in middle of picture
go tothe menu, caption, take it off the text mode. this should solve your problem
Posted on Apr 07, 2007
  • 244 Answers
SOURCE: My Sony TV KV32s45 32" Shows no picture but has sound.
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
Intermittent video or snow
Resolder points A, B, C, D in tuner PCB, check cold solder on tuner shield 2-106-349-21
Posted on Nov 24, 2007
SOURCE: tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Posted on Apr 16, 2008
  • 1635 Answers
SOURCE: Orion STV2551 27"TV...
The flyback transformer, and some other components may have failed. The main power supply may also be damaged.
It is impossible to know the exact failed parts without trouble shooting the set.
Jerry G.
Posted on Jun 10, 2008
  • 1635 Answers
SOURCE: Panasonic 27'' tube television
There are some components in the vertical deflection circuit area that are failing. An experienced TV service man should be able to troubleshoot and repair this for you. It could take several hours of labour cost.
Jerry G.
Posted on Apr 26, 2009
0 characters
1 Points
At first it was lots of horizontal lines over the screen, and later TV screen went completely black. The sound still is perfect. Perhaps I just need to replace the fuse? I love this TV! Thanks...
You have stated that your TV has a lot of horizontal lines before it went off picture. We say that lines as retrace lines. So many of them will there on the entire screen, at about one inch or so apart, horizontaly scattered along with picuture. At that time, you may be unable to down the brightness control also. Even though you have reduced the brightness control to zero position, there will be some brightness level on the screen. You should have to repair that fault at the begining. There is a voltage going to the picture tube base, known as screen voltage. That voltage determine the emission of the picture tube, and we call it a bias voltage. When it goes higher than normal, this trouble ie retrace lines will occur. In long run it may spoil the picture tube itself. I don't know what the case of yours.
Anyway it is best for you to consult an experience technician in this case. Ok.
Nov 05, 2010 | Sony KV-35V35 TV
I have a Sony Trinitron 32" tv. When I turn it on, it has started taking longer and longer for the picture to come on. Sound is fine. Now once the tv is on for a while, the picture goes black for...
Yes.... u must adjust the screen voltage going to picture tube....located on the CRT module>>>little board connected directly to picture tube (take back off TV and you will see ) play around with screen control on the CRT module......can be adjusted at times to keep from losing picture!!! tube is bad...i know sure looks good when showing a picture....TRY adjusting screen voltage ( YES while TV is ON>>>CAREFULL ) gl
May 19, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony trinitron
check the heater as your tv is ON, there must be a yellow light at the rear of the CRT tube. If the heater is ok then check the IC jungle side. resoldering the leads sometimes will solve. If not refer to your local Tech.
Jul 31, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
No picture, sound works on Sony TV KV-27V22.
try to adjust the screen. it is located behind the CRT board.(CRT board is the board that attached to the picture tube) you will find a black knob which label screen adjust it by turning the knob.
Jul 04, 2009 | Sony KV-27V22 TV
hi the problem is the picture tube of ur television has got damaged.. its better to replace a new picture tube...
Jan 24, 2009 | Philips Magnavox 27MS343S 27" TV
NO Picture, No Sound
might be the picture tube,have it checked by a tv repair man
Jul 29, 2008 | Philips Magnavox 20MS233S 20" TV
Tv screen goes black
Apr 16, 2008 | Sony KV-35V35 TV
Sony Trinitron - Picture Disappears
Hi, IK circuit is engaging which basically means the picture tube is getting tired, the only "fix" is temporary (may get another year out of it). You have to increase the "screen control clockwise".
Remove back of set, follow large black or red wire attatched to picture tube down to the flyback transformer, mounted on flyback are two black controls, one is focus (leave it alone) the other is "screen", adjust it clockwise approx. 1/4 inch, remember that this is a high voltage circuit so use one hand in the set the other hand out of the set at all times,any questions ? e-mail me back, good luck, BMW Rider
Feb 27, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Screen is black
on that tv you have to check just for circuit of high voltage - check
transistor near flyback transformer - delfo
Dec 11, 2007 | Philips Magnavox 27MS343S 27" TV
WEGA 36" : Screen is low contrast and green
Sorry to say, it sounds like a bad picture tube, But could be also the capacitor that filters the screen voltage on the crt drivers. In all my years though, your complaint has been the picture tube. Good Luck.
Jan 02, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Standard (CRT) Televisions Logo
99 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
