FWS445RFS I CAN NOT LOCATE THE PROBLEM WITH MY WASHER. THE WASHER FILL UP AND WHEN IT STATER TO AGGITATE WATER BEGINS TO SPILL OUT FROM UNDER THE UNIT. I TOOK THE FRONT COVER OFF AND CHECKED ALL CONNECTIONS AND COULD NOT FIND THE SOURCE. LET ME KNOW WHAT DO YOU THINK IT MAY BE! THANKS!
  • 75 Answers
Hi there it sounds like you may have a crack or split in the tub unit
Posted on Dec 11, 2007
Whirlpool cabrio model 6300sw1 won't aggitate and gives ol code
It is overload error.
"oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill •
and begin the wash cycle. If the washer is overloaded, it will
drain any water and detergent that was added during the fill.
To correct the overload, remove several items and add
detergent. Close lid and press START.
Also try to download user manual from this site and check page 19.
Download WHIRLPOOL CABRIO WTW6300SW1 Use Care Manual
Sep 03, 2014 | Whirlpool Washing Machines
Washer will not aggitate or empty
You have a bad lid switch. Here is that part to order.
There is also a video on that same page to show you how to make the repair.
Nov 15, 2013 | Amana NTW5400TQ Top Load Washer
My washer is 7-8yrs old it will fill with water but then will not aggitate,spin or drain
the lid switch is defective underneath the lid,disassemble the unit and replace this switch under the top and reassemble the unit
Sep 11, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Washer will not aggitate. Filled with water but is now just sitting there.
check the lid switch under the top when they go bad the washer wont run on most if not any cycle except fill mode just as if the lid is open
Jul 02, 2011 | Whirlpool Washing Machines
LOOK AT THE LIDE SWITCH FIRST WILL IT FILL WITH WATER WILL IT DRAIN WILL IT SPIN IF THE ANSER IS NO TO ALL LID SWITCH IF ONLEY TO AGGITATE MAY BE A TIMER OR AGITATOR IT SELF
Apr 03, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Water begins to drain into the detergent drawer but does not drain into drum fast enough so the drawer area begins to fill and then begins to spill out of the drawer area all over the floor. If I press...
remove the drain pump and check out.
This is inevitably caused by a blockage. The small fabric conditioner compartment in the soap dispenser drawer has a removable plastic cap. This cap fits on the top of a tube which has a hole running through it where the water should siphon through.
When the time comes for the fabric conditioner to be released, cold water enters the small compartment and just washes the conditioner over the top and down the dispenser to the tub. When the water stops flowing, all that is left is the clear water. This water should siphon up the inside of the cap and down the tube.
This tube often gets blocked with the conditioner and if you remove the dispenser drawer and take off the cap you can give the whole thing a good clean out. If the cap is missing, the siphoning will not occur.
To test the function, hold the soap drawer under the tap and allow the water to fill the fabric compartment to overflowing. When you turn off the tap, the remaining water should slowly siphon out of the hole under the cap.
its the problem in the pump and something is getting blocked in the pump so water is not getting out.
    Front-Loading Whirlpool Washers
  1. Unplug the washer. Remove the three screws along the bottom of the toe panel and pull the panel forward to remove it.
  2. Put your bucket or towels under the drain pump. Open the pump slowly so the water doesn't all spill out at once. If you have a wet/dry vacuum, you can connect it to the drain hose to remove the water from the washer before opening the pump.
  3. Open the door covering the pump wiring and disconnect the wiring.
  4. Remove the two drain lines from the pump.
  5. Remove the screw that attaches the pump to the washer frame and pull out the pump.
  6. if the pump is leaky or cracked it needs replacement.
  7. for prats you can get it from
  8. www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 05, 2009 | Washing Machines
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool LSQ9549lW0
sounds like something is stuck in the water pump. look under the machine and you will see the water pump front and center of machine.
Jul 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
New Timer--New Problem
Sound like you connected the timer up wrong, from my drawing check the following connections to the timer.
terminal 12 & 26 - Black (linked) mains supply
terminal 17 yellow/red (from rinse switch)
terminal 28 grey (from water level switch)
terminal 15 light blue (advance rinse switch water level switch)
terminal 27 brown (door switch)
terminal 25 brown (door switch)
terminal 62 green/black (motor)
terminal 7 red (motor)
terminal 32 yellow (motor)
terminal 9 blue (capacitor /motor)
terminal 8 white/yellow (motor) and white (water solenoids hot and cold)
terminal 71 pink (water selector switch and hot solenoid)
terminla 72 purple (water selector switch and cold solenoid)
terminal 70 white/blue (water selector switch)
Watch the light blue wires as there are several of them!!
Dec 12, 2006 | Admiral AW22 Top Load Washer
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
