Question about Frigidaire GLTR1670A Front Load Washer
Socks getting sucked into the motor
I have a fridigaire LFT2940ES0 and I am constantly having to take the washer apart because of a sock getting sucked into the motor. It doesn't matter if I fill it too full, or if there is only a few things put in it. Can you tell me if there is anything I can do to stop this? It is annoying and it did burn up the motor one time costing me $200.00. I also have the mold problem that the other washers have. I would think after spending $700.00 on a washer you wouldn't get black mold with a horrifing smell and not having to take it apart every month to get a sock out of the motor. Is there any hope in sight without having to get a new washer? Thanks family of 6
Re: socks getting sucked into the motor - Frigidaire GLTR1670A Front Load Washer Washing Machines
Same issues here...argh.
Posted on Jul 21, 2010
  • 249 Answers
Buy a net bag for about $3 put socks into in and pop in the wash!good luck from eire!
Posted on Dec 12, 2007
0 characters
3 Points
My stackable maytag lse7804ace washer will not drain after agitation. The dial sticks and begins to hum.
As with most appliances and cars wiring harness are made to service many models for economy to the manufacture. One harness may have 50 wires in it but your washer may only use 30 of those wires. A wiring diagram is a must. If it did not come in the paper work that came with the washer you should be able to find it online. The last 2 washes I worked on had away to put them into a self diagnostic mode this may also be in your manuel. In both cases they had a no drain problem as the code stated and gave me a place to start and because of the way washers are made now adays the drain water pump gets clogged after so many seconds of not pumping it will shut the washer down. I guess to keep the motor from burning out. Taking the water pump assembly apart I found a sock yes a sock wrap around the impellers and this was in both washers. Removed the socks reassemble and both washers worked like new. this site might help you too.
I have a Maytag refrigerator never again from day one one problem after another. The Maytag of yesterday is no more.
Jun 14, 2014 | Maytag Performa PAV2200
Water leaks out of the detergent tray like it's overflowing.
That happened to us when there was a piece of clothing (in this case a sock) that somehow left the drum and got lodged in the tube that feeds water into the drum. The entering water pours into and through the detergent tray, so when the tube feeding the drum is blocked, you get water pouring out of the detergent tray.
We had a repairperson come out to fix it, and he disassembled the whole thing enough that he could get at that tube and dislodge the sock. The next time it happened, I did the same thing, and managed to get it cleared as well. If you're not comfortable taking apart big chunks of your washer, it's probably smarter to let a qualified repairperson do this repair.
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Baby sock caught under agitator
funny thing is the two most common things to block a water pump hose are a small coin and a babys sock yet your the first person ive seen belive it to be a sock. yet as i said that will only block the drain hose to the water pump if the washer is pumping out water then its not that if it is that the bin! wont spin you have other problems it could be a loose belt the gear box or the main motor has simply strarted to give out a small sock wont stop it from spinning
hope it helps some
Apr 24, 2010 | Roper RAX4233PQ Top Load Washer
Keeps sucking socks into motor
im having the same issue i just had a motor replaced and the repair man said even a tissue can cause problems like this as well as animal hair. i was my dogs blankets in the washer all the time , how do we keep from this happening ????
Dec 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Water wont drain out after use
This washer uses a electric pump. Strings and coins can easily stop the small inpeller. The pump comes apart for cleang. You must remove the front panel by inserting a putty knife in the tp and using downward force the front will come off.
Pull the panel towards you and simplely lift it off the bottom mount. You can now inspect that pump. Lower the drain ose into a bucket to allow as much gravity flowing water to get out before you remove the pump housing. Just unlock the tab and twist apart the pump to get the strings and such out. Have rags ready. LOL
Jul 17, 2009 | Hotpoint VBSR3100GWW Top Load Washer
Mildew odour from Whirlpool Duet washer.
I've had this problem a couple of times over the years I've had this washer. What caused the odour in my machine was one (or more) of my kids' socks getting stuck in the machine. With the door open, gently reach in and bend the grey rubber door seal back and feel for clothes that have slipped between the drum and the rubber. If there's nothing there and it has been smelling bad for a while, then it's likely that the socks have been sucked into the drain. To clear this without paying a $150 service charge (I did that the first time and watched him fix it in 10 minutes), you'll need to remove the bottom front plate of the washer (there are only three or four Torx -or star head- screws holding it on). Once that plate is off, you'll see a white plastic knob that is the cap of the drain trap. Unscrew the cap and a couple of cups of water will leak out so shove a couple of towels under it beforehand. You should find some long-lost now-rotting socks. The last time I had to do this, I found FOUR socks in there. This also contributes to the 'suds' error message as it prevents proper drainage. I've only had this problem with kids' socks, everything else is too big to get stuck, I guess. Maybe try a laundry bag for the smaller stuff.
Apr 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water coming out from detergent dispensor drawer
Is this an HE2 washer? if it is, open door gently tug at bellows top left hand corner you should see a small piece of clothing stuck between tub and dispenser inlet to the tub.
Dec 31, 2008 | Kenmore 46462 Front Load Washer
Fisher Paykel washer GWL15
I have noticed this same problem and wonder if it because my FP washer wasn't draining properly and dirty water couldn't get out. See my post on "eco smart won't drain, smells hot". I found one of my husband's socks when I removed the black motor/white plastic housing on bottom of washer. tip washer back and you'll see this electric motor. My post tells how to remove it. then you can look into that small space and see if there is something plugging it.
I am waiting on my replacemt motor, and hoping all the dirty streaks are gone. the water I drained out after i removed the sock was really grimy and gritty with dirt. I'm sure the sock has been holding a lot of junk in the bottom of the tub and it would end up on clothes during spin cycle. My issue has been going on for a few weeks and then the motor finally smoked which led to the sock discovery!
Oct 02, 2008 | Fisher Paykel EcoSmart GWL15
Frigidaire CWS3600AS Top Load Washer
I know it sucks but at least the repairman can give you a break on the cost cause you have it apart and he charges by the hour,tell him youll put back together yourself after he gets it out
Jul 13, 2008 | Frigidaire CWS3600AS Top Load Washer
Amana Washer - Pump Assembly
there is no way to take it apart if you cant pull it out break it and buy a new pump it got there by over loading the washer
Feb 04, 2008 | Amana DLW330RA Top Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
85 people viewed this question
Top Frigidaire Washing Machines Experts
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
