Beta VCR I Have a beta 4000 VCR that eats my tape evertime I try to play the tape. What can I do to stp this?
  • Nay24 Dec 11, 2007
    My beta VCR chews my tapes everytime I press play. What Can I do?
  • 124 Answers
Open unit clean all rollers that the film touches w/ alcohol pads it will take out all grime,dust do it a couple of times until alcoholcpads are clear no more dirt you can clean video head w/ it too.
Posted on Aug 13, 2009
    Problem Solver:
  • 10 Answers
Get all the belts changed in it and the pinch roller replaced. All of those decks had real rubber belts plus the lubricants where made from animal fat. It's a wonder it does anything at all but beta is great its the foundation of HDcam and the SR series today and what a beautiful picture.
Posted on Dec 13, 2007
How can I correct my vcr recording the voice is really fast ..
VCR? Like in Beta Max or VHS? Wow, yours still works? Ok, lets see. I remember opening it up to maintain the wheels and rollers that touch the tape as it passes. Used rubbing alcohol and a ear swab to wipe all the grit and tape particles off the posts and rollers. If it's playing fast sound on a purchased video then it's the tape wrapping around a dirty roller which will usually chew up the tape at that point. If it is a recording that you did recently then it's still a dirty machine that got to 'eat' the tape during the recording. Either way you will need to clean the machine up manually or if you still have one of those automatic tape cleaner (must still have fluid in it) then run it several times. Best bet is to open it up and check all the belts. you may find a broken belt that needs replacement. The leftover belt pieces may have gummed up the works so it needs to be removed along with the gummy stuff.
FYI, any pre-recorded movies are probably available on cable, on-line. I suggest you have your home movies transfered to digital format, Memory chip (Not DVDs as they are going out too.)
Aloha, ukeboy57
PS on the off chance your calling your cable DVR as VCR which is an old term then is it possible your taking a digital recording and playing it on another device? If so then the format of the recording is not compadable with the player. Too many video formats out there. Try to load the movie on a computer and allow the web browser to find the appropriate program to play it.
May 11, 2018 | The Audio Players & Recorders
How to eject an HDCAM tape stuck in as BVW75 Beta deck.
I don't know what this error code means but I have managed to remove tapes which stuck in a VCR and cannot be ejected. Whether you do this is purely up to you, but it's usually possible to remove the casing (carefully!) so that you can get to the tape-handling section. Then it's a matter of gentle probing & trial and error to get the machine to release its hold on the tape. Look for a series of mechanically linked parts which are driven by motor but activated by a microswitch tripped by action of inserting the tape. Just don't strain the linkages and if you remove anything make a note of where it came from.
Apr 28, 2015 | Televison & Video
Toshiba vm42 beta player won't stay on play
Wow! A beta unit.
what most likely is wrong is the drive mechanism is either worn or slipping or you have a bad belt that drives that.
A trick to try--put it in fast forward and let it run all the way to end of tape and then rewind all the way a few times.
if it will then try to work in play it is either a idler (rubber drive wheel) or slipping belts.
They used to sell kits with the drive idler and all the belts but that was a long time ago..........
May 20, 2012 | Televison & Video
My vcr/dvd recorder eats the tapes.
clean pinch rollers and head. check if there is any dirt on capstan post
Apr 30, 2009 | Philips Magnavox DVD/VCR Dual Player
Replacing belts on Toshiba Beta VCR
I own a old VCR Toshiba Beta Hi-Fi V-S36C he's not working.So I opened the small trap under it and I found a black belt dry and broken on the cover .the belt is not more good at all.I need imformations to fix it. Any help will be very appreciated
Jan 08, 2009 | Toshiba Televison & Video
Sony PVW-2800 Beta SP Deck / Tape wont load - Error 20
Error 20 is "Cassette compartment motor lock" this is meaning the cassette loading mech is not accepting the tape It could be miss-aligned in it's position or one of the sensors is defective or the motor is bad
May 08, 2008 | Sony PVW-2800 VCR
Vcr eating tapes
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
Let me know if you need more information as to where to purchase these parts.
- Jim
Feb 12, 2008 | Philips Magnavox 20MC4304 20 in....
VCR problem in EWR2OV4
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle. The pincher wheel can become worn and/or dirty from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out than can be wound up. You can try using a re-grip solution on the idler tire or replace it.
- Jim
Jan 29, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Eating tapes and then refuses to work
try opening the case. then, using your fingers, roll the gear that drives the tape eject mechanism until a full tape eject limit is reached. power up and try
Nov 16, 2006 | Symphonic SL260A S-VHS VCR
Televison & Video Logo
224 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
