Question about Gateway Solo 1450 Notebook
No boot is the battery bad
  • saulty77 Dec 11, 2007
    how to test the battery on a laptop
  • 833 Answers
Batteries last about 2-3 years...perhaps longer...depending on how you use them. To test, go to control panel. Find the power options tab...use the utilities in there to tell you what the system finds. There may be other power utilities on your machine which are used by Gateway. Explore them and get your answer.
Posted on Jan 07, 2008
My pboblemme the boot
No Speeka English??
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 20, 2012 | HP Compaq nx6110 PC Laptop
Can not boot coad 5
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 17, 2012 | Compaq Presario CQ56110US Laptop
Tecra S1 flashing orange light
Does it boot up so you can use it?
If it boots up and you can use it then the flashing orange light might be telling you that your battery is low or dead. If it does not recharge when you have the power cord plugged in then either the Power Cord is bad and not charging the battery, or the battery has completely died and is out of it's useful life and has to be replaced.
if it does does not boot up try the steps below.
May 14, 2012 | Toshiba Tecra S1 Notebook
My dell latitude c810 start only to 5 sec.and shutdown (with removed battery. only with adaptor)
I'm guessing you are saying your laptop starts up for 5 seconds when you try to boot it then shuts down and only with the ac adapter.
Remove the Power Cord & Battery , Open the Cover to the Memory and remove one of thememory chips (the cover will have one or two screws on it). Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 01, 2012 | Dell Latitude C810 Notebook
Just got a brand new sylvania 7 " netbook -charged it overnight and tried to start it up but all we get is a application error message.
One thing you can try is to remove the battery and see if the machine will boot up with the Ac plugged in. If the battery is bad the machine may not boot with the bad battery installed. This is a safety feature to keep from overheating a bad battery with the charger. If the machine then boots up you need to replace the battery or take the machine back for a swap out.
Mar 13, 2011 | Sylvania G-Netbook
Acer extensa 4630z will not boot with battery, if I take the battery out and do a power reset it will boot without the battery. is this just a bad battery?
try to boot with the battery and charger inserted and then check the battery status from your system. the battery might need replacement.
Sep 07, 2010 | Computers & Internet
My Toshiba Satellite laptop does not fire up at all. Yesterday as I was working the screen blinked a few times and went dead. I can't get it to come back up. Tried connecting to an external monitor but it...
Four possibilities come to mind.
1. Your power supply is bad and the battery ran down.
2. Your system board died.
3. You have a bad device plugged into a USB port.
4. Your battery is bad and holding down the AC power.
To troubleshoot, disconnect all external devices, even remove the CD drive if possible. Try to boot.
Next, boot with just the battery.
Next, boot with just the AC supply.
That's about it. If you still have no power at boot, it is the system board.
Apr 27, 2010 | Computers & Internet
Lights come on and off d610 the power lights come on and then go out no video no anything
Usually a bad motherboard will cause this, however, don't overlook a bad battery or charger. Even a bad USB device can cause this. Remove the CD player and all USB connections, then try again. Check the battery charge by pushing the button on the bottom. If there is a red light, then it is bad. If there are no lights then it is not charged. Also, check to see if your charger has a light on. If it does, try booting without a battery.Finally, try booting with the battery only (if it has a charge).
Apr 12, 2010 | Dell Latitude D600 Notebook
My Ibm t49 the display shuts off as soon i as i boot up help
There are several possibilities within two categories:
SOFTWARE (you are using MS, so this is more likely)
HARDWARE these symptoms can be caused by bad battery and/or bad PSU (AC Power Supply Unit)
Software: You may have a virus, or may have damaged the NT kernel, or some critical software components by installing cheap games or bad SW. Read the recovery instructions on your XP CD to boot and run recovery and/or utilities that might repair the laptop OS. If you have no CD, try booting and hitting F6 key after BIOS screen... then explore the options there. Next, try booting and hitting F8 key after BIOS screen... then explore the options there.
If there are no problems repaired or evident in software, you should remove the battery, plug in the PSU and try booting. If all goes well, your battery is probably bad. If NOTHING happens, then your PSU is definitely bad (or the PSU cable/jack/connection to your computer is bad)
Conversely, remove the PSU and boot only with the battery. If it boots up (or goes farther than it did before) then the battery may be low/damaged BECAUSE the PSU is bad. If your laptop does not even open/get at least to BIOS screen, then the battery is dead. Try recharging overnight with laptop off but plugged into AC. If it is the same in the morning, replace the battery.
Both the battery and PSU can be checked with a VTVM, to compare voltage/output levels, with the ratings on the labels
Dec 06, 2007 | IBM ThinkPad T40 2373 Notebook
CMOS/GPNU Checksum Bad 0085
You may have a bad CMOS battery. Does it do this on restarts as well as cold boots.....if you only receive this message on cold boots, then you have a dead battery.
Nov 26, 2007 | Intel Motherboard
Computers & Internet Logo
100 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
