Question about RCA P52926 52" Rear Projection Television
HDTV 52 INCH RCA
THE MAIN MENU SCREEN KEEPS POPPING UP ON MY TV. I HAVE CHECKED TO SEE IF THE BUTTONS ARE STUCK ON THE REMOTE OR THE FRONT OF THE TV THEY ARE NOT STUCK. I ALSO TOOK THE BATTERIES OUT OF THE REMOTE. (CHANGED) UNPLUGED THE TV TO RESET IT ALL DID NOT WORK. CAN YOU HELP?
  • Anonymous Jan 07, 2008
    I also have a RCA 56" Model P56926 S/N 032551112, chassis PTK195RP TV. I have the same problem watch tv for a while, then the menu displays, will stay for 1 to 10 min, then go away on its own. During the time the menu is on the screen, all functions from the front or remote are locked, except for the mute. Unplug it for a long period of time, over night and it will usually work for 30 min. to an hour, and starts again. Sometime you can watch it for an hour or so and no problems. Now the sound goes away and the picture is OK, then later the sound comes back. Not the remote, it has been replaced. Joseph.Cochran@Embarq.com
  • c-roe Feb 20, 2008
    I have an rca mod#r52wh77 and I have been having the same exact problem. It started out with just the menu popping up on the screen, so we switched remotes, unplugged everything and reconnected again. Then the volume bar started going up and down on its own, and now both the volume bar and the menu simultaneously go on all day. talk about frustrating.
  • 934 Answers
It could be a failing tac switch or the micro. The only way to tell is signal trace the switch circuit with a 20mhz scope.. Need a shop for that if you don't have the equipment and it's not terribly expensive...
Footnote: either failure can and usually will get worse over time and may infect other function, vol,ch, power and so on... Find a reputable shop and take it in.. If you have any problem location one let me know..
Bill
Posted on Dec 11, 2007
The menu screen keeps popping on and off the tv screen..even took the batteries out of the remote..same problem...help!!
You need to Clean all of the Front Panel contact switches with contact cleaner.
Power/Vol- vol+ Ch- CH+ Menu.
Nov 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Menu screen keeps popping up all the time
ok this is a problem i have seen many times at the shop. this is a faulty keyboard Ibutton) assembly cuircit board. this can be replaced. removeing the keyboard is involved. you have to remove the front panel. now if you disconnect this cuircit board it is still possible to operated this tv with the remote untill the treplacement board arives
Sep 21, 2010 | RCA D52W23 52" HDTV CRT TV
RCA HDTV Monitor; menu popping up and volume going down
The small signal board needs replacement. You can get replacement small signal boards from www.tvrepairworld.com
Jun 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
The tv menu keeps popping up
need you to observe and trace if menu popping up causer by stuck up button, if so you can replace right away.
Apr 04, 2010 | RCA D52W23 52" HDTV CRT TV
Rca flashing the menu screen
Check the buttons on the front keyboard panel. Try cleaning them if that's no help replace the panel or the buttons.
May 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" Menu Keeps Popping Up and Down
I see this alot at the shop ... the front panel buttons have become damaged. THe best coarse of action is to replace the front button cuircit board assembly... **** there is a tempery fix untill you get the part... remove the front panel and take button cuicit board out...just use remote to control the tv. This is also a way to test to see if this is the problem.. if you romove the connector to the buttons and the problem goes away then the buttons are the problem. you get get this cuicit board at union electronics. You have to get the extended model number off the back ussally d52w20yx1 or yx2 or yxsomething...not to difficult a repair
Nov 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Menu pops up constantly
there is a problem with the front control buttons. i see this quite often at the shop. the best way to deternmine this is to remove the buttons and use the remote to turn it on if it goes away then i would suggest replace the button cuicit board assembly
Oct 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA projection TV
are buton on remote sticking or on tv it self clean controler tap on button
Oct 07, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA TruFlat 30-something inch
what chassis is in your set.look on rear panel ./st
Dec 09, 2007 | RCA 32F530T 32" TV
RCA P52926 52" Rear Projection Television Logo
117 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
