Question about Xtant1.1i Series Mono Car Audio Amplifier
No sound out
Alright so I've got a 121m xtant amplifier feeding a 10" sub. It worked until recently. I've checked the rca cables and connections, they're good. The red light is on and no orange or yellow lights are on. I checked the voltage on the power supply and continuity to ground, all good. The confusing part is that when I check the voltage across the speaker outputs I don't get anything on my multimeter (in the mV range). I do get a varying mV voltage across the postive (or negative) terminal with respect to ground...
Not sure what is wrong here, checked the jumpers and everything looks good...
  • mattyg1026 Dec 20, 2007
    The sub is fine, did the check you said above and also checked the impedance, 4 ohms. Check.
    The positive terminals of the speaker output and the negative terminals are following each other ie there is no potential difference "across" the terminals so no current flow through the speaker coil and then no oscillating magnetic field to move the magnet.
  • 143 Answers
You should be getting a reading from the speaker terminal if you have it wired properly & the stereo is playing.
if you are testing the DC voltage 'ACROSS' the terminals you will not get a reading.
Test the pos terminal as you did the main feed...Black probe on earth terminal, red on the pos speaker terminal.
If you are getting a reading then try a different sub.
continuity test across the terminals of the sub & push on the cone if the buzzer changes on/off as you push on the cone the voice coil may be burnt? pump the cone up & down it may clean it a bit?
Posted on Dec 15, 2007
Kicker dx 500.1 keeps ruining my subs
if your sub isnt blown, i'd follow your own idea and look for a bad wiring connections, also what kind of head unit do u have? check the settings on ur head unit to see if there is a seperate setting for your amp/subs if it does have one, make sure it is set properly
if it does not have a setting like above, check the rca cable from the radio to tthe amp, and make sure that the rca cable is plugged in to " input instead of the output
Jan 15, 2013 | Kicker 2010/10 Dx500.1 Car Audio Monoblock...
Subs and amp sat in my garage for a year. I just
check your subs by connecting them straight from the stereo. If they work then there is an issue with the signal comming from the stereo through the rca cables to your amp, check those. Try another amp if you can with those rca's or test the amp with a friends car, either way try to rule out everything until it points to the problem.
Apr 17, 2010 | PPI PCX-2200 Car Audio Amplifier
MTX Thunder 3401 not responding. Lit but no sound.
turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
Apr 05, 2010 | MTX Thunder 3401 Car Audio Amplifier
One sub works other doesn't
Disconnect the wire from the speaker and meter it out. check it for a dead short, the meter would read 1..... You can also check the action of the sub by pushing on the center lightly, moving the cone. If it's blown, it will not travel smoothly. If your meter reads ......1 then you've really done it and totally cooked the wire clean thru, thus no resistance. Hope this helps.
Sep 29, 2009 | Xtant A3001 Car Audio Amplifier
Amp is shutting off after 10 min of driving!! please help!!
Does it happen at all volume levels?
What is the gain setting on the sub amp?
Have you checked for 12V @ remote turn on after problem occurs?
Sounds as if the remote turn on relay inside the amplifier is losing signal, or has become damaged. If the protection light does not light up, the problem is not thermal, shorting, or high/low voltage.
The amplifier is in need of repair. This is not an end-user fix. Looking at about $50 to repair.
Thanks for using FixYa- a FixYa rating is appreciated!!
Feb 18, 2009 | Profile BAJA HA700M Car Audio Amplifier
My sub flickers on and off in my truck!!!
could be a number of things loose wires bad ground fuse on its way out or internal problems
Feb 13, 2009 | Profile BAJA HA700M Car Audio Amplifier
RCA cable use
You can plug into the left channel and it will feed both the left and right channels.
To confirm that it's feeding both channels, connect the speaker to one channel at a time. With signal fed into the left channel only, you should get sound when you connect the speaker to either channel.
Apr 18, 2008 | Sony XM-754HX Car Audio Amplifier
Weak output from sub..
The woofer was not demagnetized.
If one signal cable is damaged, it could reduce the signal getting to the amplifier and could reduce the output.
Plug one RCA plug in at a time to confirm that both are working properly. If one is lower or not working, the cable may be defective.
If both work properly, double-check the settings on the head unit (sub-out, bass, crossover frequency...)
Oct 28, 2007 | Alpine MRP-M350 Car Audio Amplifier
Subs will go off the wall with bass, but not in tune with music.
hi, first disconnect the rca input, then switch on headunit and if the amp produces a constant bass thump it then means it has an internal fault. if the amp idles quietly then replace the rca cable, or try connecting the headunit lineout feed directly to the bass amp, in this way you cud find out if your fault is coming from the headunit or the equaliser. cheers
Nov 23, 2006 | MTX Thunder 8302 Car Audio Amplifier
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
Xtant1.1i Series Mono Car Audio Amplifier Logo
151 people viewed this question
Top Xtant Car Audio & Video Experts
Tom Chichester
Are you a Xtant Car Audio and Video Expert? Answer questions, earn points and help others
