Question about Sony CDX-M800 CD Player
Sub display screen
After starting my truck the other day, the sub-display screen and buttons quit working. they come on when the screen is closed and you can see them going off as the screen opens. I need Help!
  • rebelnek Dec 12, 2007
    thanks for the tip...i can not see that the pcb has snapped it looks fine to me ... do you have any other suggestions... thanks..
  • Anonymous Feb 05, 2008
    Recently, whenever I start my car, the front panel flips down and the display LED goes out....buttons still work but all illumination in the front panel goes out.
  • 78 Answers
It's usually the flexible pcb that connects the fascia to the main board that needs replacing, because the fascia opens and closes each time the ignition is turned on and off the connector flexes and eventually some of it snaps, sometimes if you pop the trim off you can see the snapped pcb on the bottom right hand side of your radio
Posted on Dec 12, 2007
  • tom mcloughlin Dec 14, 2007
    you may not be able to see that part of the pcb is snapped as its got a plastic film covering it so the best way to discount it is to replace the flexi, sorry but repairing these things dont always have an easy solution if it did I wouldn't have a job
Sub Zero 690 ice make not working after tripping breaker
Is the "ice" icon displayed on the screen? you have to turn on ice production on a Sub-Zero
Aug 30, 2016 | Sub-Zero 690 Side by Side Refrigerator
H3-00 error
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 24, 2015 | Sharp Ar M350n
Have Sharp - AR-5516 and H5 error blinking on the screen
1. Entering the simulation mode
OR
Mar 28, 2015 | Sharp Office Equipment & Supplies
How can i clear H 4 error code on my sharp AR-153E coppier. your help please.
OR
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Mar 20, 2015 | Sharp Office Equipment & Supplies
How do I Change the frequency on a Rkio Nike TWo way radio
Hi Gary - I copied this from the RIO NIKE manual:
mode button
Press MODE to select the setting you want to change.
The normal display is replaced by the adjustable setting.
Use the + and - buttons to adjust the settings.
These are the settings you can change.
1. Main Channel (1-14)
2. Sub Channel (1-38)
3. Channel Scan (ON/OFF)
4. Sub Channel Scan (ON/OFF)
5. Button Confirmation Tone and Roger Beep ON/OFF)
6. Vox (OFF, ON LO, ON HI) (psc[communicate wxonly)
When you have proceeded through all adjustable settings, the normal display will reappear. Or, press TALK at any time to return to the normal display.
select main channel
There are 14 main channels.
To select main channels:
1. Press MODE until CHAN is displayed.
2. Press + and - keys to select the main channel.
select sub channel:
Each main channel has 38 sub channels, sometimes called
CTCSS channels. Select one of these sub channels to transmit
on a channel that is free from traffic.
To select sub channels:
1. Press MODE until SUB CHAN is displayed
2. Press + and - keys to select the sub channel.
Note :If you select channel "0," you will be able to receive transmissions from all the sub channels of the main channel you selected.
Download manual:
Jan 27, 2014 | Rio Nike PSC Communicate (14 Channels)...
Operation buttons and sub display are failing
go to ebay and type in the model number of the unit and it will bring up some part that can fix the problem. i had the same problem and i just ordered the part. its actually a ribbon connector. im sure you just open up the radio and take the old one out and connect the new one up. this seems to be a common problem with this unit. the ribbon just starts to tear, and as it tears, you will start to lose functions on the stereo. i happen to like this stereo, so i decided to repair it. good luck with yours.
david
May 31, 2009 | Sony CDX-M630 CD Player
Sub won't power up
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Nov 16, 2008 | JVC TH-A10 System
Sub-title does not appear.
It's called "closed captioning" and should be under the menu/setup button. Subtitles are only for DVD players.
Jun 24, 2008 | Memorex MVT2135 13 in. TV/VCR Combo
NOT SUB on head set
I had the same problem to fix it you press the menu button then scrool up untill you see REGISTER.
Press OK the display shows "BS 1 2 3 4" Enter the number of the base unit you wish to register the handset to.
The display shows "PIN code" (original code 0000) press OK the display shows "Search X (where 'X' is the number of the base you are registering to)
Press and hold the "page button" on the Base unit untill it beeps twice then after a few seconds the phone should work again.
Mar 14, 2008 | Cable_and_wireless CWD4901 Cordless...
Sony CDX-M800 CD Player Logo
85 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
