Question about Refrigerators
Frigidaire Freezer Runs Warm in Cold Weather
I have a Frigidaire Fridge/Top Freezer that I keep in my unheated garage. During the winter, it seems that the Freezer (turned to the lowest setting) tends to thaw when the garage is cold (probably 30 to 35 degrees). Ironically, the freezer works great in hot weather! The unit is three years old and this is the third winter I've experienced the problem. Any ideas?
  • 75 Answers
Hi there the problem you have is that the temp in the garage is to low, the fridge part of your fridge freezer has priority and will only activate the compressor when req'd ie. in cold weather the fridge may not need to switch on the compressor for days at a time this is when the freezer will defrost.
All you can try doing is having some very low heating in your garage in the cold weather
hope this is of help.
Posted on Dec 11, 2007
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Fridge freezer kept in cold garage. Freezer works from time to time but fridge stopped work. Could it be a thermostat problem or due to temperature of garage?
The problem is with the garage temperature. The temperature sensor for the refrigerator is in the fridge compartment, but the evap coils are in the freezer. Refrigerators were designed to work in an air conditioned space. When they are put into unheated spaces, it does not work well. The fridge thermostat typically is set to 40 deg F. If the outside temperature is close to that, then it does not turn on the compressor as much so the freezer will have a hard time staying below freezing.
There are garage refrigerator kits for people who put fridges in un heated garages in the winter. They just simple electric heaters that warm the fridge's thermostat to cause the compressor to run more often. This helps the fridge to maintain temperatures better in the freezer compartment. The same thing can be accomplished by putting a small wattage bulb in the refrigerator compartment. Just remember to remove it during the warm weather otherwise you will pay a large electricity bill in the summer months.
Dec 09, 2010 | Smeg FAB46X Top Freezer Refrigerator
I have a Frigidaire refrigerato with top freezer that I keep on the back porch. The freezer has quit working completely. The temperature has been below freezing lately and I was wondering in this has...
Good day,
Yes, Frigidaire specifically states any temperature below 55 degrees will unbalance the machine causing the freezer to warm.
This is due to the fact that the thermostat that runs the entire machine is located in the fresh food section. When it reaches it's normal temperature it shuts the entire machine down.
In cold weather it could stay off for the best part of the dy, if not the entire day.
As well. on some model Frigidaire's, they makes a winterizing kit.
It is wired to the thermostat in a manner that heats the thermostat artificially in cold weather to cause it to cycle more.
Contact your local appliance parts house to see if they carry the kit for your machine.
Feb 17, 2010 | Frigidaire FRT21H8 Top Freezer...
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Freezer not getting cold enough.
That is normal since the cold control is on the refrigerator side and is satisfied. It needs to be in a heated environment and not in an unheated garage.
Jan 02, 2010 | Frigidaire FRT21P5A Top Freezer...
Cold garage interferes with top freezer keeping cold enough
Sorry it took awhile but there is not a cold area kit for this refrig available. it needs to be used in a controlled climate so that the controls will operate properly thanks for your patience. Peyton
Jan 27, 2009 | Frigidaire FRT21H8 Top Freezer...
Freezer temperature won't get cold enough.
This might sound stupid, but I had a similar problem. A few years ago when I was renting I noticed that suddenly my freezer stopped working well. I eventually had to call my landlord to check it out. It turned out that there was a knob to adjust the freezer temp and I had turned it to the warmest setting somehow. If it isn't that, I would return the freezer.
Hope that works for you
Jan 18, 2009 | Frigidaire FRT18G6J Top Freezer Side by...
Freezer won't work in garage in cold weather
Modern fridge/freezers are built to automatically defrost themselves. To do this they require that the room temperature is well above freezing to allow the defrost to take place. If you site the freezer in too cold an environment it is unable to defrost itself and will eventually stop working. It sounds strange but if it is too cold the freezer cannot work. The solution is to buy and fridge/freezer that does not automatically defrost itself if you want it to work in a cold environment.
Dec 06, 2008 | Refrigerators
Does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Nov 21, 2008 | Frigidaire FRT21H8 Top Freezer...
Refrigerators Logo
1,041 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
