Question about HP OfficeJet 7310 All-In-One InkJet Printer
Hp officejet 7310 fax problem
i have a problem with this all-in-one product. Sometimes it faxed and sometimes it doesn't. Same thing with recieving. What can it be?
    Scholar:
  • 54 Answers
Just change below settings
Press setup on the all in one. Navigate to Advanced Fax Setup using arrow key. Set the FAX Speed to Slow and turn off the ECM (Error Correction Mode). Try sending fax. Please simply send a fax (single page black and white text) (1-888-473-2963 . Check for the result.
Posted on Dec 22, 2007
HP 7310 All-In-One
I see those in the shop all the time, sometimes dirty rollers, sometimes paper clips and other foreign material caught in transport, and sometimes just stops for a scanner error. Usually a simple fix in the shop but impossible to diagnose without seeing.
Jul 23, 2009 | HP Officejet 7310 All-In-One Printer
Auto reject faxes
Hi There
Simple answer No ! best way is to get your telco supplier to block the number that is spamming your fax m/c
Regards ~Al "alstech"
May 24, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Unable to send or receive fax over vonage/dsl
I also have vonage and this fax macine - the incoming fax was going to vonage answering machine.
I went to setup (that little button above and to the right of the OK button to "basic fax setup" and changed my rings to answer from 5 to 2. This will work for me, because I only set it to auto answer when I know a fax is inbound - you might want to adjust so you can aswwer a call if you do not have a dedicated fax line.
Good luck
Dec 05, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Error
You should be able to send out a fax on there without replacing the cartridge.
Jul 28, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310
showing paper jam and have checked and don't see any paper
Dec 17, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Officejet 7310 HP
Follow the steps below to perform a fax diagnostics test. 1. Set up the all-in-one for faxing according to the setup instructions found in the product's User's Guide. 2. Make sure you have inserted the print cartridges and loaded paper before starting the test. 3. Press Setup, 6, and then 6. This displays the Tools menu and then select Run Fax Test. The HP all-in-one displays the status of the test on the color graphics display and prints a report. 4. Review the report. * If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems. * If the test fails, review the report for more information on how to fix any problems found. 5. After you pick up the fax report from the all-in-one, press OK. Then turn the printer off, and then on again. If necessary, resolve any problems found and rerun the test. If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems.
Aug 07, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
145 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
