Question about Black & Decker Compact Power Screwdriver
Drill how do you unscrew a drill screw
  • Anonymous Feb 17, 2008
    Black & Decker 3/8 cordless drill model BD 1000 Type 2 5 amp 0-2500 VRS
    Keyless chuck.
    The chuck won't keep the bit tight. I want to replace the chuck but can't get the old one off. How do I get it off.? I want to replace it with a keyed. Do you have pictures as well as imformation. Thanks
  • Anonymous Jun 17, 2008
    how do i remove screwdriver bit from drill chuck
    Champion:
  • 313 Answers
There are no breakdown for the said model
Posted on May 29, 2008
B&D lithium 12v model LDX112c. Phillips screw head locked in chuck but no matter what torque setting it won't start to unscrew unless I manually make the first turn or two.
Try another known good fully charged battery. That's assuming you haven't stripped the head out of the screw or the driver bit itself isn't damaged. If that's not the problem I'd get a corded drill and try unscrewing it using that drill.
Aug 21, 2017 | Drills
How do you remove the chuck on a cordless drill?
If it is a reversible drill open the chuck as wide as possible.
Look inside for a screw that prevents the chuck from coming unscrewed. Remove the screw and you shovld be able to unscrew the chuck.
Aug 25, 2014 | Drills
How do I change the chuck in my Craftman 3.5 electric drill
If you open the chuck as far as it will go and look inside you may see the head of a screw, especially if the drill is reversible. So undo the screw and then you should be able to unscrew the chuck. But I am not sure if it will be easy to unscrew. With a keyed chuck you use the key and a hammer to unscrew the chuck.
Oct 14, 2013 | Drills
A dewalt dcd970 18v xrp and when i try to unscrew anything the bit comes loose. Can't figure out why?
check the inside of the chuck at the bottom(open the chuck to max). There should be small screw there with either a hex or a Phillips head. It is a left hand screw that locks the chuck in place and will not let it unscrew when you are removing parts.. If it is not there then you will have to get one from an old drill that is junk unless you can get one from an electrical appliance shop the repairs drills.
Oct 24, 2011 | Dewalt Air Tools & Compressors
I HAVE A DEWALT 511 HAMMER DRILL AND I CAN'T REMOVE THE CHUCK. COULD PLEASE ADVISE ME ON WHAT TO DO.
Open the chuck fully and look inside, there should be a screw there that has to be removed to remove the chuck in view of the fact that it is a reversable drill and the chuck cannot be screwed off like a conventional inudirectional drill.
Jul 09, 2011 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
Want to Replace chuck Keyless chuck always loosens and bits fall out.
Inside the chuck barrel there is a screw which unscrews counter clockwise, then
the chuck itself should unscrew counter clockwise as well.
May 09, 2011 | Ryobi 18volt 12" Cordless Drill Model P206
Explanation for the dial numbered 1 - 23) and switche (1 & 2) on a Worz wd44d cordless drill please?
Those numbers are for drill jobs or for screw / unscrew jobs.The higher the number the strongest power of the drill will do.Often for drill purpose the higher number is set to obtain the maximum power of the drill.But if you want to use to unscrew a, let say,a home minor job like unscrew or screw a wall hanging picture you can choose a number that fir the power you need to do it.
Nov 13, 2010 | Drills
On a model 315.101231 3/8 corded drill I need to remove the keyless chuck how do I do that?
May 31, 2010 | Craftsman 3/8" Corded Drill
Need to remove the chuck on my 3/8 milwaukee drill. I opened the chuck and removed the screw in the bottom but can't get it off. does it pry off or unscrew? right or left hand screw???
if this is a cordless drill please review the tip section, if not the spindle has a hex that you can put a thin wrench on and the threads are standard meaning you would use a chuck key or allen wrench to hit it in the counter clockwise position to remove it. Let me know if you have any problems
Nov 23, 2009 | Milwaukee Tool Drills
Black & Decker Compact Power Screwdriver Logo
97 people viewed this question
Top Black & Decker Hand Tools Experts
Marvin
Marvin
Robert Monigold
Robert Monigold
Don Numinen
Don Numinen
Are you a Black & Decker Hand Tool Expert? Answer questions, earn points and help others
