Question about OKI C5500n Laser Printer
How do i solve fatal error 980
Pls help me solve the error 980 on OKI C5600
  • Anonymous Mar 22, 2014
    Motion c5600 printer has fatal error 122
I got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Posted on Aug 29, 2010
  • 5 more comments
  • ecks80 Jan 25, 2011
    is there any way i can attach the files here
  • BAMM Loma Jun 06, 2011
    What type of files are they? businessandmoneymgmt@gmail.com
  • ecks80 Aug 24, 2011
    I have created an email address and forwarded the patch files and instruction to that email.
    email is oki5950@hotmail.com password is error980
    so anybody still having that error plz feel free to sign in and download the files.
  • kalin1102 Sep 16, 2011
    Thanks a lot, a solved the error!
  • mashhoury
    mashhoury Jan 17, 2012
    Hi people
    i had a problem when i tried to sign in to oki5950@hotmail.com cause of password resetting , so the password now is(Error980).
    thanks for help.
  • Maureen Mbui Aug 09, 2013
    hey, I have the same error. could you please send me the patch?
  • kosti Oct 02, 2013
    Same problem but different printer.I have an Oki c711wt with the same error.Send me the patch,please!
If you have 980 fatal error and have checked that there is no paper stuck in fuser or you have removed the paper and still have error, then you should contact Oki, there is a fix for this exact problem, if you contact them they will send you a patch which you will need to run on the printer. This will fix your problem
Posted on Mar 02, 2011
  • 4 more comments
    How can I get the patch? My printer is out of warranty and the rep's only solution is to buy another fuser which may or may not fix this.
  • arryzed Jun 06, 2011
    if you email me arryzed@zedhead.fsnet.co.uk I can then forward you the files needed
  • arryzed Jul 13, 2011
    the above comment is in correct, a patch need to be applied
  • Dejan Goricanec
    Dejan Goricanec Apr 18, 2014
    Can someone send me the patch on dejan.goricanec@gmail.com.
  • Dejan Goricanec
    Tnx a lot. BR
  • rossana
    rossana Jul 28, 2014
    hello, I have the same problem, can you please send me the patch at rossana@manet.it thank you very much!!!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error 980 on OKI C5600 means that the error by media clinging to the fuser and the fuser is required to be replaced.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Sep 14, 2009
    the above comment is incorrect, a patch needs to be applied to correct problem...DON'T replace fuser
  • 28 Answers
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
    the above comment is incorrect, remove ALL paper from fuser, then a software patch needs to be applied to correct problem available from Oki...DON'T replace fuser until you have tried this first, because you will still get the same error even with new fuser
  • dablaze Sep 12, 2011
    That's true! I replaced the fuser with a new unit and i still get the error message!
4 Suggested Answers
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: does anyone know what is
If you look on top of the fuser roller(upper orange roller), there is a thermistor (orange rectangle plastic that rides on the roller) you will see four wires going into that housing. Two are for the thermistor and the other two is for the fuse that is built into the housing. You would have to use a soldering iron to melt the plastic that the fuse is sitting in. You would have to figure out what to use as a fast blow fuse.
Okidata makes it difficult to take out the thermistor because the nut is locktite on the screw. Try using the soldering iron to melt it. Just make sure you dont damage the thermistor.
Posted on Jul 03, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
OKI C5500
Error 980 means media clinging to the fuser,remove the fuser and see if there is something wrong in it
Jul 07, 2008 | OKI C5500n Printer
Error message: Service Call 980 - Fatal Error
It means a call to OKI will be necessary. Typically, fatal errors are related to internal ROM, or board components that effect the boot process of the printer. When it can't boot - you get this type of message.
Dec 31, 2010 | OKI Electric Industry B4545 Laser Printer
Oki c 5600 980 fatal error
Jul 20, 2009 | OKI C5500n Laser Printer
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Nov 22, 2008 | Ricoh Aficio 250 Copier
980-fatal-error
Service call 980:Error
Cause: Error by media clinging to the fuser
Error description: Media has clung to the fuser.
Solution: Power OFF. Replace the fuser unit.
Nov 19, 2008 | OKI C5800Ldn Led Printer
980: Fatal Error
*Service call
980:Error
*Error by media
*Power OFF
Suggestion -
Apr 07, 2008 | OKI C5800Ldn Led Printer
OKI C5500n Laser Printer Logo
6,073 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
