Question about Kenwood VR-407 Receiver
Kenwood basic M2 Amp Lightning strike
A lightning strike took out a nearby transformer and now my kenwood amp will blow one of the internal 7 amp fuses if the power is turn on to it. The local shop took a look and said that this amp has very strange circuitry and they couldn't help me. Another shop said that the output transistors were all blown but did not know where to get parts. I found a source but they are about $50 apiece and there are 8 of them. It still sounds odd to me that all 8 would be damaged as I believe that this amp has two rails of 4 transistors each, with 4 of them coming on line only at very high settings. The amp was off at the time of the lightning strike. There is no physical damage apparent to the transistors or the heat sinks that they are mounted to. Any ideas? Thanks ratmoul
  • 1,512 Answers
You can check the output transistors for short circuits with the low ohms range or diode checker . If they have failed, then it is often a good idea to replace all as much stress can be placed on an output array in this type of failure. to repair reliable, all outputs on an offending channel should be replaced.
Make sure the fuse you replaced was the same type of fuse. check markings.... T stands for sloblo... a fast blo duse may let go at turn on. The power supply may have a shorted rectifier diode in it also.
be aware however, every time a fuse of that rating blows... more damage may be occurring to the amp.
Posted on Dec 15, 2007
It might be easier for a novice to find the emitter resistors (white rectangular ceramic with three pins exiting) there are four of them
each is a pair of resistors @0.22 ohm each side.
Connect a multimeter to the center pin, and each outer pin in turn,
if you find an open circuit in any of these then the respective output transistor has failed (shorted to the power rail + or - depending on whether its a NPN (positive rail) or PNP (negative rail) device that`s failed. As explained above, you will probably need to have the low power pre-drivers replaced as well as this amp is DC coupled,
I have found current limiting resistors in the signal path tend to protect the first and second stages from damage, including the input differential pair.
Posted on Jan 30, 2014
How check pcb after lightning strikes??
Over voltages as little as 20% greater than expected (under the right circumstances) can cause components to fail with no outward indication of failure. Other times, these same or greater voltages will obliterate a component and without the benefit of a schematic will make identifying & replacing it impossible.
Nearby lightning strikes often cause multiple components on different PCB to fail at the same time, complicating troubleshooting significantly. Faults can appear on power supply PCBs and in the RF stages along antenna / cable inputs and out to cable boxes DVD players, etc.
These are usually not fixed by DIYers without specialized test equipment and manufacturer's service manuals.
Jan 30, 2015 | Televison & Video
Lightning strike, blows internal fuse (6.3v 125/250) on plug in.
sounds like the lightning strike took out at least the power supply if not more. sorry to be bearer of bad news.
Oct 31, 2010 | Toshiba 24AF41 24" TV
I am trying to purchase a owners operating manual for Kenwood M2 Power Amp. Can you help?
Hi -
A manual is available for free from this site below:
http://www.hifiengine.com/manuals/kenwood/basic-m2.shtml
You will be required to register before downloading, but there is no fee to do so.
I hope this helps!
Mar 26, 2010 | Audio Players & Recorders
Lg flat screen lightning hit and now it wont work
This may just be an internal fuse on the power supply has blown, if you have a multi-meter you can remove the rear cover & check for yourself to see if it is open circuit you may be lucky & this is the only problem. However, very often lightning strikes can cause a lot of damage to the circuitry, so if the fuse is at fault & then blows again, I would suggest contacting your supplier to get an repair engineer to take a look for you & access any further problems.
Aug 02, 2009 | LG Televison & Video
TX-SR803 with no sound or popping hissing on any input
It is common for a short term power surge to open up the internal fuse in the main power transformer. Without testing some components inside the unit, I really can't say for sure whether or not the unit is worth repair. I would suggest that you invest in a detailed repair estimate at an authorized Onkyo service center.
Keep us posted.
Dan
May 26, 2009 | Onkyo TX-SR803 Receiver
Lightning strike to powered console.
On a generic level, without knowing the specifics of your equipment, I.E. amp & mixer make/model, you start at the mixers input stage. If an amplifiers output transistors die, they usually cause the amp to trip or blow a fuse, the weakest point in the system. If the amp is not doing this then the chances are, it's an line level problem, mixer related.  Again, you have to list the equipment you have in order for me to be more specific.
Nov 02, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
POWER SURGE
sounds like DC on that output.
needs service possibly fried all the output transistors on that channel
Jul 30, 2008 | Xantech PA1235X Amplifier
Kenwood VR-407 Receiver Logo
612 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
rigger094
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
