Quoting from the link shown:
Step 1
Read the display on the electronic oven controls, where the clock and timer normally appear. If the display reads "CLN" while the "Door Locked" light is on, the Kenmore range is in self-clean mode. When the Kenmore range is in self-clean mode, you must stop the cleaning process before the door will unlock.
Step 2
Stop the self-cleaning process by pressing and holding the "Stop/Clear" button for three seconds. The oven lock should disengage after three seconds. In some cases, a malfunction between the control panel and the locking mechanism prevents the door from unlocking.
Step 3
Hold the light switch for several seconds if the "Stop/Clear" button fails to unlock the range door. Engaging the light switch for several seconds resets the entire locking mechanism and overrides the "Stop/Clear" button.
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
there is a timer and a locking relay when you shut the door and put it on self-clean then shut the door and latch it the relay kicks in and locks the door and turnsthe oven on max for a few hours the food resadue turns to powder that can be wiped off or vacumed out
Self cleaning works by 'burning' all of the material it is cleaning. If you have excessive grease other material in the oven, it will cause the smoking. Either do the cycle more frequently or remove as much of the goo as possible with a cloth before beginning. If you have a ventilator to the outside, turn it on and close the door to the kitchen to contain the odor.
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch
motors, sensor probes and even the electronic controls can be destroyed
by this operation. Suggest oven cleaner method.
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. Good luck, ya'll!
