Where is temperature control on Kenmore power miser 12 hot water heater?
I am trying to locate the temperature control for the water heater.
Can you tell me where the adjustment is located on the water heater?
There are two thermostats - one behind the upper metal housing and one behind the lower metal housing. You should really consult the owner's manual first before adjusting them. The manual is on line at the sears web site.
Posted on Sep 20, 2009
If you mean the temperature control dial, it's inside of the metal housing on the bottom of the unit. Slide the metal box up and off, and you will see the dial.
Posted on Jan 28, 2008
Kenmore ultra wash dishwasher gets stuck at 42 on the control panel
Be aware that all (well, almost all) dishwashers have a "thermal hold" period in their cycles. This is the point in the main wash cycle where the heater is turned on to heat the water to the optimum wash temperature (about 150 to 160 deg F), and during this time, the timer will stop advancing. Once the water has reached the desired temperature, the cycle will continue. IF it does not, then you have a water heating problem. This could be caused by a bad heating element, a bad controller, a bad thermostat or temperature sensor.
Mar 20, 2015 | Kenmore Dishwashers
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
Water Heater Issues
An electric water heater contains two elements (usually upper and lower). Normally hot water is maintained at a certain temperature to assure an immediate supply. When hot water is turned on at the fixture, the second element is turned on to boost the temperature. From your description one of the heating elements may be defective or set to incorrect temperature.
Apr 28, 2017 | Water Heaters
How to clean air intake screen on kenmore power miser 6 hot water heater
Kenmore is AO Smith.
Set this brand water heater on bricks for ez access to arrestor screen located on bottom.
Air intake located on bottom of unit, and should be accessible without removing combustion parts. Use feather duster, or compressed air.
Copy following links for specific illustrations and information:
Same information also shows in product manual .... and you didn't save that, but next time for sure.
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
http://waterheatertimer.org/How-to-replace-thermocouple.html
http://waterheatertimer.org/How-to-maintain-water-heater.html
Sep 17, 2012 | Water Heaters
I have a Kenmore Power Miser 12 gas water heater that the pilot light keeps going out. The water heater has been in service for 45 months. The pilot light has a blue flame with some orange flame flares...
check and or replace the thermal coupling. the coupling goes into the main gas control, if the coupling is bad it will shut off gas supply. as a safety measure.
Mar 09, 2011 | Water Heaters
Water heater- not always hot
common problems i have seen are:
1) wife or kids hitting the OFF switch thinking its the light switch in the closet where my heater is located.
2) heating element has died. you should have 2 elements in this heater. when one dies, the heater cannot keep up with the demand of heating 50 gals of water.
if there is a warranty, then now is the time to exercise it.
if no warranty, then it is possible to troubleshoot each element to see which one is dead if you are handy with a voltmeter and electrical wires. if comfy, i can provide steps to narrow it down. list the kenmore model number if you reply.
Feb 02, 2009 | Intermatic WH40 - Water Heater Time Switch...
Gas water heater burner wont stay lit
This is a major problem with Kenmore power miser 6, 9, and 12's - we purchased a Power Miser 6 in Nov. 2006 and have had 5 service calls in two years - we are on our 6th call now - Go to http://baheyeldin.com/technology-in-society/mistaken-identity-help-with-kenmore-water-heater.html or Complaintsboard.com and you will see multiple complaints on these models. We had Sears out days after we purchased the water heater, and had parts replaced, then more problems in April 2007 - It worked ok until Nov, 2008 and now it has gone out 3 times. We were told it is lint collecting on the screen that sits under the burner (difficult to get to) - we made a vacume attachment out of PCV pipe (like the one the repairman had) and vacumed the screen when the pilot light wouldn't stay lit - that is what they told us was the problem - but this time, the vacuming isn't working - Ash also builds up on the pilot light burner which has to be removed - you can't replace the thermal coupler without replacing the entire burner unit in this model - In short, if you can get your money back and buy a more reliable model, do it! Sears sold us a maintenance agreement after they had come out 3 times ($290), and still we go for 2-5 days without hot water waiting for them to come out and not fix our water heater. They also told us we should build a platform elevated off the floor to increase oxygen and decrease dust - funny our last model was still working at over 10 years and never had an issue in the same location! Sears installed the water heater, and should have installed it on a platform if that was what was needed. Also, there was no warning about having to vacume the screen (UNDER the heater - very difficult) - when we purchased this model or we wouldn't have bought it - Kenmore water heater repair line now tells you to try scrubbing the screen - but who wants to do this every month??? I can't tell you how inconvenient this has been - Looks like there was a class action suit against LOWE's which included the AO Smith water heaters (which is who built the power miser heaters) - no class action suit yet against Kenmore - This has been a nightmare and at the websites I listed, you will see many more such complaints, and some creative solutions...but I doubt any will work for long. Good luck.
Jan 14, 2009 | Water Heaters
Washing Machines Logo
759 people viewed this question
Top Washing Machines Experts
