Question about Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
Blue green bvand
The tv has a blue/green band at the top 2+ inches on the left and 1" tapered to the right
  • joecarp Dec 12, 2007
    ctf1800, thanks for the quick response. I have a bose center chanel speaker on the wood cabinet top about 4" above the top of the screen. I moved the speaker and turned the circuit breaker off for a re-boot, no luck. what is a convergence adjustment?
  • joecarp Dec 14, 2007
    I can't find convergence anywhere in the menu or the manual?
    I have also read elsewhere, where these tvs have a slipping filter problem, could this be whats wrong?
    President:
  • 4,402 Answers
Have you tried convergance adjusting?
do you have anything on top of the tv like speaker ?
Posted on Dec 11, 2007
  • 1 more comment
  • Cary Farah
    Cary Farah Dec 12, 2007
    Go to the menu and page down till you see convergance, the you want to make sure all the bars are lines up making one white bar.
  • Cary Farah
    Cary Farah Dec 14, 2007
    Does it look like this?
  • Cary Farah
    Cary Farah Dec 15, 2007
    do you have a link to that filtering problem?
Picture ok with a 6 inches blue vertical line from top to botton
For a five or 7 inch band we have a fix. Six is a big problem. A vertical band is either a sync condition requiring an adjustment of one or more pots on the circuit board. Usually the condition is Horizontal and rarely up and down the screen. LED is generally very reliable and two of 3 colors within the diode in your case (one red and one green) are not working. If this TV is in Warranty, replace it as you cannot fix this yourself.
Jan 10, 2014 | Samsung UN55EH6000 55" Class LED HDTV...
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Hitachi 51GWX20B Rear projection HD tv, convergenance/color issue
I bet you have a open resistor for the blue sub yoke. Typically it would be a 2.2 omh or a 1.5 ohm. Some times it is hard to tell buy looking at them. It you have a Ohm Meter, unplug the set, pull the sub yoke plugs from there connectors.(They are the plugs right behind the heat-sinks) . If you know the resister color code it will be a must to determin if any are open or increased in value. If you see a resister that has two red bands and two gold bands, it it a 2.2 ohm. A resister with a brown band, green band, and two gold bands is a 1.5 ohm. On some occasions, you will see a brown band, a white band and two gold bands, this is a 1.8 ohm. This circuit does not give much leeway for subing with wrong values and it even could cause premature failure if the IC's again. One last thing, double check that all the pins made it through the board when mounting and are not touching each other top side of board. As far as the one side of the picture pulling in , I think it is all related. I have seen defective STK392-150's new out of the bag.
Well thats all I can tell you at this point.
Good Luck,
Skyassoc
Jun 19, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Wiring of Ethernet cat6 cable for computer to the modem asm32 to excess to internet
Pinout is as follows:
http://www.mae.ufl.edu/sysinfo/cat6_cables.htm
Looking at the Cat6 connector with the lock tab facing up, look at the pins, (brass colored contacts) going from left to right.
From the left it's pins 1,2,3,4,5,6,7, and 8.
The wires are twisted together in pairs.
First pair
1.Pin 4 goes to the White wire with Blue bands.
2.Pin 5 goes to Blue wire.
Second pair
1.Pin 1 goes to the White wire with Orange bands.
2.Pin 2 goes to the Orange wire.
Third pair
1.Pin 3 goes to the White wire with Green bands.
2.Pin 6 goes to the Green wire.
Fourth pair
1.Pin 7 goes to the White wire with Brown bands.
2.Pin 8 goes to the Brown wire.
Apr 15, 2009 | Avaya Computers & Internet
What color is positive speaker wire on 1998 blazer
1998 Chevrolet Blazer S-Series Stereo Wiring Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6 1/2" Rear Doors Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Mar 17, 2009 | 1998 Chevrolet Blazer
COLOUR ON MY TV IS MESSED UP.
palsonic tv is green and blue
Jan 11, 2009 | Televison & Video
How to connect a Nintendo Wii Audio Video ED Component Cable ?
Generally the Red, Blue, and Green are video with the remaining red and white are audio left and right respectively.
Dec 28, 2008 | Nintendo Wii Console
Sony kp-61v45 Blue Convergence off by 2 inches
you need to replace the convergence board its around 80 dollars
Aug 17, 2008 | Sony KP-61V45 61" Rear Projection...
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
