Question about Microsoft Windows Vista Ultimate Edition
Vista home premium
Not gettingDVD library option under Pictures and video option of Media center
not able to play HDDVD/normal DVDmovies using media center.
  • Arahim Dec 12, 2007
    not gettingDVD library option under Pictures and video option of Media center
    Still need a solution for this problem?
    Try our Premium Assistance plan
    Solution #1
    posted on Dec 12, 2007
    By melnavz
    Rank: Apprentice
    Rating: 78%, 2 votes
    there is no problems about your system. Its maybe your systems is lack media "codecs" that enhance your DVD files or Movies to play. maybe you should download any HD dvd codecs and install to your system. or may search google the "media player classic" and use as your player or VLC player preety cool player for almost movies.
    Hi, it is possible to play DVD, HDDVD with other applications, problem only when playing using Media center.
    Genius:
  • 1,226 Answers
There is no problems about your system. Its maybe your systems is lack media "codecs" that enhance your DVD files or Movies to play. maybe you should download any HD dvd codecs and install to your system. or may search google the "media player classic" and use as your player or VLC player preety cool player for almost movies.
Posted on Dec 12, 2007
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Media center problem
have you run the setup wizard?
just add the folders to check and see if it's detected
Dec 11, 2007 | Microsoft Windows Vista Ultimate Edition
Windows media player won't play any audio selections , says can't find files
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display. The Xbox 360 gaming console is an example of an extender.
Click on "Allow a program or feature through Windows Firewall." Click to check "Media Center Extenders." Click on "Apply."
Click on "General" and select "Windows Media Center Setup." Click on "Set Up Your Speakers." Follow the on-screen prompts to reconfigure your speakers.
and you should run the chkdsk utilty
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way i have found to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive.
hope this helps
Oct 23, 2012 | Toshiba Satellite A60-692...
Does not work for video files. AVI in Windows Media - player Vista 32
To play the avi files. you can try to options.
1. You can download a different media player which is VLC media player. It plays almost all kinds of video format.
2. Download K-lite codec and run it and you should be able to play .avi files in media player.
Hope it helps :-)
Feb 10, 2010 | Microsoft Windows Vista Home Premium for...
Media center won't connect to analog TV signal
If my memory serves me correctly, you need vista pro. home just isn't powerful enough and not made for it.
Jun 01, 2009 | Microsoft Windows Vista Home Premium with...
Windows Media Center proplem ( unknown Audio Error 80040155 )
Go to start : All Programs: Accessories: right click on Command Prompt, click run as administrator. click continue: you should see C:\Windows\system32> type there regsrv32 wmp.dll It should look like this C:\Windows\system32>regsrv32 wmp.dll
(make sure to put the space in between 32 and wmp)
An info box will appear. Click Ok then restart.
That should fix it!
Mar 23, 2009 | Microsoft Windows Vista Home Premium with...
Media Center file types
Yes, file extensions, .gif, .bitmap, .jpg are case sensitive. Just like if you tried to save a word document as .DOC then the file would look like test.DOC.doc. Change case and it will be fine.
Mar 02, 2009 | Microsoft Windows Vista Home Premium with...
Windows Vista Media Center Randomly Starts up.
Open Control Panel
Go into Default Programs
Under Custom remove the tick from Enable Media Centre.
Apr 29, 2008 | Computers & Internet
Unable to Play DivX encoded videos through media center extender (xbox360)
The media center does not currently use the codec to decode DiVX... but with all the upcoming changes to the xbox360 interface/ console / Marketplace I see Microsoft correcting this.
Hope this helps!
Jan 10, 2008 | Microsoft Xbox 360 Console
Microsoft Windows Vista Ultimate Edition Logo
122 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
