FixYa.com
Tags:
Intel D845GVSR Motherboard
Want to install drivers (by 32 users)
posted by Najju on Dec 11, 2007
i have got a D845EPI/D845GVSR motherboard. i formatted my system, now my display is showing fade and there no audio at all. can you help me ......
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
31 Other Users Have The Same Problem
Comment by Guest, posted on Jul 03, 2008
udfufjjfjfjf
Comment by sajain, posted on Jul 02, 2008
I HAVE THE SAME PROBLEM OF NAJJU,NO AUDIO AND DISPLAY IS FADE
Comment by Guest, posted on Jun 27, 2008
need vga for xp2
Comment by Guest, posted on Jun 26, 2008
I formatted my PC and now i want vga driver for INTEL D845GVSR Motherboard.
Comment by jambokiya, posted on May 31, 2008
from wher I can get the driver of the mother board from the internet or how I can down load the software
Clarification Request
by rbmohan, posted on Feb 21, 2008
hai how to the installed linux please
Best Solution
posted on Dec 21, 2007
Helpful (85)
technomang
Rank:Apprentice Apprentice
Rating: 90%, 12 votes
Had this problem a few weeks ago when i switched hard drive out to replacement Motherboard, my solution was to look for d854epi drivers, i had a d845GVSR disk and it didnt work so i went and download then drivers for d845epi, when installing you will get a message saying something like drivier cant be found, hit browse
goto WINDOWS-->SYSTEM32 first, then youll get the same message, but for different driver that driver is in WINDOWS\SYSTEM32\drivers.  Hope that helps, when installing drivers manually those two places will be where to look
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Dec 11, 2007
Helpful (85)
joey64
Rank:Wiz Wiz
Rating: 79%, 169 votes
you need to install the motherboard cd. this cd is the driver for you audio, ethernet,vga and so on. the procedure is that everytome you reformat your hard disk you need to install this drivers to function well and to prevent problem with your pc. in case you installed an expansion video card you need to install also its driver. you did not specify if what is your ram memory, is it 128mb, 256mb or 512mb
Comment by joey64, posted on Dec 18, 2007
you may download from this site www.Fixya.com/Intel+Driver
you can download from google just type in this motherboard model number then download driver
Solution #3
posted on Jan 10, 2008
Not Rated (0)
linktriscuit
Rank:Master Master
Rating: 90%, 11 votes
Check the capacitors on the motherboard, they may be bad.
Can you Help with these Motherboards problems?
Motherboards
battery wire
my battery wire keeps fallin... Answer This...
Motherboards
urgente¡¡¡¡...
como puedo hacer para... Answer This...
Motherboards
retrouver pilote audio
Carte m?re ASV533MSD+ de... Answer This...
Motherboards
je veut des instrustion
instrustion pour le produit:... Answer This...
Motherboards
MOTHER BOARD
dear sir i have a qss-3300... Answer This...
31 Other Users Have The Same Problem - Continued
Comment by nishuuu, posted on May 30, 2008
my display is blur and no sound
Comment by Guest, posted on May 21, 2008
I formatted my system and installed xp servicepack2. Now my computer is working under 8 bit colour mode
Comment by Guest, posted on May 20, 2008
no sound
Comment by Guest, posted on May 19, 2008
sound problem
Comment by alaudin, posted on May 13, 2008
I can't change the display resolution.Intel d845gvsr mother board
Comment by Guest, posted on May 08, 2008
i had formatted my system and i had installed window xp professinal service pack 2. now i want intel 845GVSR motherboard drivers to install.
Comment by Guest, posted on May 07, 2008
i ve formatted my system but lost the motherboard cd.graphics driver is not there.searches the net but could not download it.please notify me how to download this graphics driver for the motherboard d845epi
Comment by Guest, posted on Apr 29, 2008
please also give the driver of these board simply
Comment by Guest, posted on Apr 25, 2008
i want grPHICS DRIVERS
Comment by contrerasg20, posted on Apr 06, 2008
I downloaded the update from Intel.com for the BIOS for Intel D845GVSR Motherboard and now my USB connections don't work and also there is now sound. What can I do?
Comment by saravan, posted on Apr 03, 2008
my systems will formated and reinstalled for win xp-prof. edition i also instal mother board driver but no sound is happen
Comment by Guest, posted on Mar 28, 2008
I have got a D845EPI/D845GVSR motherboard. i formatted my system, now my display is showing fade and there no audio at all. can you help me please....
Comment by dh_inder, posted on Mar 19, 2008
Intel(R) 82945G Express Chipset Family software update
Comment by Guest, posted on Mar 18, 2008
Intel D845GVSR graphic
Comment by Guest, posted on Mar 08, 2008
i have mother board of mercury with intel 845 vga. i use fedora 4 as os. want to have drivers for intel 845 vga drivers for my pc
chandru
Comment by Guest, posted on Mar 07, 2008
i have got a D845GVSR motherboard. i formatted my system, now my display is showing fade and there no audio at all.also i do not have audio driver installation setup. can you help me?
Comment by Guest, posted on Feb 29, 2008
i lost my mother board cd to install drivers .. now can i get audio drivers for the mother board D845GVSR freely  in online..,, by audio is not working now... plz help me..
Comment by Guest, posted on Feb 20, 2008
yeh i hav the same problm nd i want to instal the audio video drivers frm were i download it
Comment by hamu11, posted on Jan 06, 2008
i have formated my system i want to install video drivers
Comment by Guest, posted on Jan 03, 2008
ethernet controllers, graphics (VGA) drivers are missing and I hav lost my Intel CD
Comment by naveen12, posted on Dec 30, 2007
i formatted the pc and now audio is not working
can you send me the audio driver for the same
motherboard model is D845GVSR
Comment by sajin, posted on Dec 26, 2007
i have no mother board driver of intel 845gv chipset
Comment by ucgls, posted on Dec 24, 2007
I tried installing the drivers from the Motherboard CD. But it says "Internal error - Incompatible File" and the browser closes.
Comment by Guest, posted on Dec 21, 2007
i have same the problem
YES I HAVE SAME PROBLEM
Comment by thangamk, posted on Dec 14, 2007
not installig Audio Driver, during instalation(before completing it) system get restarted by itself. in XP it show, it was an seroius error message box. i used this driver "AUD_ALLOS_5.10.0.6020_PV_RealtekAC97.exe". what can i do pls help me.....
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
