Question about Combination Televisions
Dvd Player stopped working on my TV
I have a T2000-D Television with Dvd player and just recently the Dvd player has stopped working. It now says "wrong disc" no matter what dvd I put in. What's the cause of this? Is there a solution?
SOURCE: DVD player says "wrong disc type"
Clean the laser.
Posted on Mar 17, 2008
0 characters
1 Points
I recently purchased a 15.6 inch television of yours with build in dvd player, model# NX-555 but i need to know does it play blu-ray dicks or not? When i went to the dvd setup i tryed a blu-ray &...
I believe this is a Naxa LCD TV with built in DVD player.
It will not play Blu-ray discs.
You can connect a Blu-ray player to the available HDMI ports or the YPbPb "Componant" inputs.
I hope this helps.
Mar 11, 2010 | Combination Televisions
Cant Power up/down. DVD player wont work
You can try leaving the television unpluged for a couple of days and see if letting the circuits completely discharge will let the television reset itself to normal operation. You can also call Toshiba customer support and ask them if this problem is common and if there is a simple solution. The customer service telephone number is 1-800-631-3811. Give them the model number of your television and they will help you. I hope this information help you with your problem.
May 01, 2009 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
No picture and sound on t.v. all of a sudden
Hello Thomas,
I apologize that you are having issues. Normally, when this sort of problem happens, it is the cord connected from the DVD player to the TV. I suggest getting a replacement cord. How can you tell what type of cord this is? If the cord is seperated into yellow, white, and red ends, then this type of cord should be replaced. If it is a coaxial cable, like the one used to carry cable to a TV, then this type of cord should be replaced. If the cord has pins on the end, like a mouse, the S-Video cord should be replaced.
Jan 04, 2009 | Combination Televisions
press the stop key on the television and the on/off button on the remote at the same time.
Dec 26, 2008 | Panasonic PV-DM2792 Triple Play 27 in....
Toshiba Remote
you can buy a universal remote if the cost of a replacement is too high. hope this helps, good luck.
Apr 15, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Dvd does not work
Hi Denise,
Please check your connection between your TV and DVD player. Make sure , Video Out jack of DVD player goes to Video in of your TV, The same as the Audio jack. Then try opening your , set to VIDEO , and play!!!!!
Good Luck,
Apr 01, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
DVD player locked
I had this problem too. I found this solutiong on another web site and it worked. To unlock the dvd player turn on the tv.Get your remote in hand. Press and hold the stop button for the dvd player on the TV/DVD/VCR. Now press the power button on the REMOTE. This will unlock/lock the dvd player.
Mar 17, 2008 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
DVDs Play in Black and White
this may be the problem with your dvd player
Feb 14, 2007 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
DVD Player Subjective to Netflicks Discs...
Glad you have the problem straightened out.
Have a great week
NC Electronic
Mills, Wyoming
Jan 10, 2007 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Combination Televisions Logo
81 people viewed this question
Top Combination Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Combination Television Expert? Answer questions, earn points and help others
