Question about Boxlight CP 19t Multimedia Projector
Lamp shuts down after startup
The projector powers up normally and displays image for less than 30 seconds and then shuts down just like it was powered down. After the normal power down cycle the green light comes back on as if it were properly shut down. I called Boxlight and they thought it was either the power supply or main board. Can you confirm this and can I get parts to repair it myself if it is a board replacement or component repair? To send it in for repair is too expensive. I am a tech so I don't mind working on it if we can salvage it for a backup. Any suggestions?
  • Anonymous Jan 10, 2008
    PROJECTOR LAMP LED REFUSE TO COME ON.
  • 2,237 Answers
It is the power supply/ballast. when you first turn it on, the caps on the ps/bal charge then discharge when the lamp is to strike. if the caps are dried out (from excessive heat), it takes a while to build a charge. so the power drain from striking the lamp brings the ps/bal into shutdown. after you try again, the caps are now up to full power and everything is fine. but every time you unplug it, you'll have the same problem. replace the power supply and ballast.
Posted on Jan 27, 2010
ASK Proxima C420 shuts down after 30 seconds. No indication of overheating or lamp problem.
Might be a problem with the video input. Try a different cable. If HDMI, you will need a really good cable for HDTV or 3D, and they are very expensive. My 12 foot cable cost $180.
Sep 12, 2014 | ASK Proxima C420 Multimedia Projector
Shut down after 30 seconds
Many projectors shut down if they cannot find anything attached to them.
Make sure you have a computer attached and sending an image out to it before you hit the projector reset button again.
It's a bit like the chicken and the egg since some laptops won't send an image out the cable unless it senses a projector, and the projector shuts down if it does not detect an incoming signal fast enough.
Apr 23, 2014 | Acer PD528W Bulb
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
NEC NP1000 powers up, strikes, then shuts down
the expected lamp life is an average .. its not unusual to see early failures ... check the lamp connections to make sure they are secure ... check ventilation to make sure its not blocked by dust .. if there is a fan, make sure its working ..
Oct 07, 2009 | NEC NP100 Projector
Eiki LC-XG110 lamp going off
Lamp is near end of life. Try reseting lamp timer and order new lamp if unit stays on
May 13, 2009 | Eiki LC-XG110 Multimedia Projector
Sanyo PLC SW20AR - Shuts itself down
check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Feb 08, 2009 | Sanyo PLC SW20A Multimedia Projector
Intermittent Power up / dn
HI-
The projector is overheating, try cleaning the filters for the fan.
Hope this helps
Oct 29, 2008 | InFocus LP 600 Multimedia Projector
Compaq MP2800 Lamp powers down after a few seconds
Hi Wayne
It is normal for the lamp's fan to start running , but should actually happen within 15 seconds of starting up. Try changing the lamp's fan and if the problem still persists then you will have to replace the Ballast ( lamp's powersupply )
Mar 22, 2008 | Compaq MP2800 Multimedia Projector
Projector shuts down after only a few minutes.
I'm having the same problem. My Model is PB8253. Projector started, then afer a couple minutes it goes off with the red lamp led flashing.
Just replaced the lamp, but the problem persists. Tried to remove all connecting cables, except for the power, but still the same problem.
Anyone with similar problem or solution, please contact me at dartveiga@gmail.com
Jan 19, 2008 | BenQ PB6100 Multimedia Projector
Boxlight CP 19t Multimedia Projector Logo
244 people viewed this question
Top Boxlight Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Boxlight Office Equipment and Supply Expert? Answer questions, earn points and help others
