Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Canon mf4150 "Toner not set" Error
Do you know how to fix this? I have tried a new cartridge and that doesn't seem to fix the problem. I have unplugged it and plugged it back in, replaced the paper, nothing seems to help.... please let me know if you have any ideas....thank you!
jtsmith@igloogroup.com
  • 6 more comments
  • Landon P Jan 13, 2008
    I have the same exact problem.
  • Anonymous Jan 22, 2008
    Toner not set. Donna M.
  • SirKnight Mar 25, 2008
    I have the same problem. When I try to copy a document, the printer displays an error message "Toner is not set.....Insert toner". I have removed and re-inserted the toner cartridge, and shut off and turned on the printer to reinitialize it -- neither action corrected the problem. I payed a visit to the local Staples store where I bought the printer and several print cartridges (over time), and found that their display printer had the same problem (same message). The store rep tried the same action described above with no success. We also tried using my cartridge in the display printer and no success. He thought that there may be a contact problem with our printers and felt that Canon may need to repair the printers. I tried cleaning the contact points on the print cartridge and inside the printer, but again, no success. At this point, unless Canon or someone knows a solution to this problem, I plan to buy another printer.
  • Anonymous Apr 12, 2008
    bought new catridge but the same error message is still coming up.!!!!! my printer is fairly new!!!!
  • Anonymous Jun 12, 2008
    I have the same problem it says "toner is not set" and I tried numerous times replacing the toner but nothing works. The last time I took the toner out, I found a little spring but I am not sure where it is from or what to do with it.
    Thanks in advance for your help.
    Jackie
  • Plankwing Oct 29, 2008
    I have tried the "remove and replace paper" method as many different ways as I could figure to do. Nothing has worked. I downloaded the Firmware Update. Instructions say "error" (red LED) is to be off, etc. Nothing I try will get it to turn off. And, it appears from the description in the instructions that all the Update does is change the error message. What good is that? But, my solution turns out to be simple: I bought the 2-year replacement plan, and Office Max is replacing it since I'm within the 2-years.
  • Anonymous Jan 10, 2009
    toner is out of range
  • Anonymous Mar 04, 2009
    WHO CAN FIX THIS THING!!!!
My IT guru at the place I work found an AMAZINGLY SIMPLE SOLUTION. Remove the paper, then remove and replace the toner cartridge. Now put the paper back in, and you are ready to go. Our IT man rocks!
Posted on Nov 16, 2008
Solution from Canon Support & Service follows. Found that it works. The key was removing the paper from the cassette tray.
1. Remove paper from cassette tray before replacing the Toner Cartridge-ICMF 4150
2. Install the Toner Cartridge-ICMF 4150
3. Turn the main power switch off and then back on-ICMF 4150
Posted on Mar 25, 2008
  • metguy31
    metguy31 Dec 19, 2012
    Thanks, I remember having a simular problem. You just jared my memory and it worked.
Bless you good folks. I found this website late this evening, and removing the paper and then reinserting the cartridge worked like a charm. Otherwise, I felt like I was going to go medieval on this printer. But, you know, my scanner still really sucks. But, at least it prints. Arya
Posted on Jun 13, 2008
Canon issued a firmware upgrade SPECIFICALLY for this problem.
The Canon website for support and downloads is:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=14444#DownloadDetailAct
The details of the firmware upgrade are as follows:
Firmware: imageCLASS MF4150 Firmware Update
File Name: MF4150_FirmwareUpdateTool_v057.exe
Description: "Toner Not Set" message improvement
Version: v057
File Size: .68 MB
Date Posted: 09/25/2008
Please select the correct version of Operating System when downloading from the support site.
Posted on Oct 29, 2008
Check the paper in the cassette. one or more of the paper is out of position . readjust the paper and restart the machine.
Posted on Jan 29, 2008
Same thing happened here.. Remove all your paper and viola!
Posted on Jun 06, 2008
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Error light flashing. Scren prompts set paper again, set toner again. Have installed new cartridge?
Hmm that is very bad indeed. Have you tried simply unplugging the printer from the power source for at least 10 minutes, then replugging it in to see if the errors persist? These errors just came out of the blue one day, nothing changed or happened to the machine? No power surges / outages or anything like that?
Thanks
Tim
Sep 30, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon image class MF 4150: it is flashing, message says toner is not set insert toner. Toner has been inserted, it was working this morning, I printed documents fine, now this message. I have taken the...
spacer.gif If you removed and reinstalled toner correctly several times and this error code is flashing, you need to try another new toner cartridge, even though the other one may seem still good to you. If this doesn't remedy problem the Troubleshooting section of the Canonusa.com website says to call 1-800-OK-CANON.
Jul 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
My canon imageclass mf 4150 says toner not set but there is a cartridge in it.
my canon imageclass mf 4150 says no paper even paper loaded, kindly help to solve.
Feb 11, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Toner is not set insert toner
Your toner cartridges may be faulty, or the wrong one. Try another cartridge
Jan 02, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Toner
I had the same problem with this printer. And I think I got the problem solved by removing the all paper from the paper tray, and re-inserting the toner cartridge. I think it is the problem with incorrect error message from Canon's printer. It is problem of paper being fed into the printer mechanism slightly.
Nov 27, 2007 | Canon imageCLASS® MF4150 All-In-One Laser...
Toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Nov 06, 2007 | Canon imageRUNNER 400S Copier
MF4150 Printing all Black - pages covrerd in black
Yes. Exchange it while you can. It will more difficult after the first 30 days. Could be a toner cartridge not seated properly. Or could be a high voltage power supply.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 10, 2007 | Canon imageCLASS® MF4150 All-In-One Laser...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
5,940 people viewed this question
old marine
old marine
