Question about Panasonic KX-TG2352 Cordless Phone
Busy signal on Panasonic KX-TG2352 Cordless expandable system
No problem with incoming calls, but when I try to dial all I get is a busy signal. If I dial first and then hit talk the numbers dial and the the busy signal returns. The system is about 4 years old. I have another cordless phone in the house and it works just fine
  • Anonymous Jun 15, 2008
    I have an AT&T E27176 phone with a base and second set. I also have other cordless phones in the house. When I connect the base, all phones in the house have busy signals. I disconnect the At&t base and everything works.
  • 13 Answers
SOURCE: message problem
In your case there is no problem regarding your cordless phone. The problem might be in your network only. So please contact your network officer immediately.
Posted on Mar 18, 2009
SOURCE: I have a 5.8GHz Expandable Digital Cordless Phone
My problem was solved when I discovered that my internet connection was off. After I reset it, my phone resumed working.
Thank you.
Posted on Sep 06, 2009
njvinod
  • 1462 Answers
SOURCE: I have a panasonic cordless phone, model
If you get busy tone in your Panasonic KX-TGA820 cordless phone, it may be due to any one of the following reasons:
1)The called handset is in use.
2)The handset you are calling is too far from the base unit.
Check whether the base unit is not so far from the handset
3)There is no handset registered to the base unit matching the extension number you entered.
Try to re-register the handset to the base unit again, To know details regarding registering and re-registering, please refer page 38 of the manual, which you can download from the link given below
4)Other units are in use and the system is busy. Try again later.
Try to check whether the other units are not using your base unit
You can download manual for your phone from the following link for reference
http://service.us.panasonic.com/OPERMANPDF/KXTG8231.PDF
Please rate this solution
Rnj VINODKUMAR
Posted on Nov 11, 2009
  • 3 Answers
SOURCE: Panasonic kx-TG2352 can not dial ,phone works for
Believe it or not, I accidentally discovered you have to really press hard on the numbers to dial !!! I guess this happened as one is used to a light touch working on a cell etc
Posted on Dec 01, 2009
SOURCE: System is busy message when hitting talk
At the main base unit, unplug the power in line for a minute. That fixed mine. It has happened twice...don't know why.
Bob W
Posted on Aug 31, 2010
Why do our handsets show busy with an incoming call and don't allow us to answer a call?
We recommend you test the main base unit with a different telephone cord on a different telephone jack.
Apr 29, 2014 | Panasonic KX TG4031 Cordless Phone
Panasonic KX-TCD220E - pulsating busy signal for a few seconds then dial tone
If that pulsating tone is anything like what I sometimes here on my phone, then it has nothing to do with your phone. It's your telephone company telling you that there's unheard voicemail on their system. You'll need to contact your telephone service provider for instructions on how to access their voicemail system.
Apr 10, 2012 | Panasonic Lands Phones
The Panasonic KX TA824 system phone How can I make that when somebody is on the corldess phone that is connected to the system Lets say extension 105 when a call comes in to extension 105 I should not get...
On an 824 you only have one option, call forward busy/no answer. It means all calls transferred to that extension would go somewhere. Since an 824 has no ring groups, you can't make the system do a double hop (CF busy to 101 and if 101 is busy CF to something else) but at least it's something.
From the cordless, dial 712 1xx # with xx being the extension of the forwarded number. (710# cancels).
Carl
Oct 31, 2010 | Panasonic KX-TA824PK Phone
I have attached this cordless to KX-TA824 supporting 2 incoming lines. How can I select which line (CO 1 or CO 2) to call from?
If you start with intercom dial tone, press 81 or 82. If you dial 9 you'll get line 2 before line 1 in normal programming, and if you dial a line that's busy with 8x access codes, you'll get a busy, even if the other line is free.
Of course, you could also RTFM and program the system to function with your TA-824 http://public.carl.airpost.net/Pana/TA-824/UG_TA_0823%5B1%5D.pdf
Starting on page 15 or so of the pdf, after you set up the keys, you'd press the > and 1 or 2 to get to lines 1 or 2 :-)
Carl
Oct 08, 2010 | Panasonic KX-TD7896 Cordless Phone
Panasonic KX-TGA101 not working
By jim_giardine on Jan 03, 2010
My parents have had their Panasonic KX-TGA101 for a little over a year and it just stopped working. It no longer rings when a call comes in. Plus when we try to answer a call or place a call all we get is a busy signal both auditory and in the display window.
SOLUTION: you might want to change a new phone line, that's maybe the culprit, most of the time is the phone line is worn out first due to too many reasons.
Jan 03, 2010 | Panasonic KX-TGA101S Cordless Handset
Nov 30, 2009 | Panasonic KX-TG2352 Cordless Phone
Phone screen says line is busy but it isn't. people can't reach
here is a link to a page where you can download the manual for free hope I helped
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/model.KX-TGA630S
Aug 31, 2009 | Lands Phones
Message problem
Mar 18, 2009 | Panasonic KX-TG6700 Phone
Panasonic KX-TG2352 Cordless Phone Logo
513 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
