Question about Samsung ML 2010 Laser Printer
White Streaks down left side of page.
Hi ,
I filled my toner arm the the proper toner as usual and the print on left side of page is still faint with white streaks through it.
  • 70 Answers
Shake the toner hard and try again. It should work.
Posted on Dec 20, 2007
HP Color Laserjet 9500hdn printing yellow streaks at bottom of page
I'm not familiar with this model but have you ran the cleaning mode if it has one?
Aug 23, 2012 | HP Color LaserJet 9500HDN Printer
I have been having trouble printing my red. My letterhead contains a red "A" in it and a few other items have red. Normally, the red items have pink, yellow or white vertical streaks through...
Replace the magenta image unit. Yellow image unit also and for the white streaks have the glass that cover the laser cleaned.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 29, 2011 | Brother HL4040CDN Duplex Unit
Faint line when printing a letter
hi this may be the toner roller or supply drum for the toner cartridge . if it scratched or worn it leaves marks on the drum or the roller, which in turn fills with toner and leaves an imprint on the page, you can check these , just remove the toner cartridge and look at the green roller and also look at the black roller, it might be a simple case of changing it or cleaning it....hope this helps
Feb 25, 2010 | OKI C5250n Printer
HP Laserjet 2820 Streaks on Page
There are 3 parts to the imaging process that could cause your issue. You have the toner (x4), the imaging drum unit (Q3964A) and the fuser unit. If you are getting streaks from all colors, one or more these parts are the issue.
Let's start with the easy stuff:
Open the cover as if you were replacing toner where you can "visually" inspect the toner and imaging drum. Pull the drum out and pull back the "plastic shutter" on the top, this will expose a green drum CAUTION! Too much exposure to light and touching it can cause damage. Just take a quick look trying to see if any of the lines on your page match any marks on the drum. Check the bottom half of the unit as well there should be a white section across the bottom, expect that as well.
Next look at the toner, if you can look at any other color but black it will help you look for the streak marks a lot easeier. If you couldn't see any streaks on the drum on toner cartridges, it's time to look at the fuser unit. Power the machine down and turn it around, unplug it then fold down the blue clips and CAUTION! the fuser heats the toner to the page so if it's been used recently it may be hot. once the clips are down, just pull straight back and look for the streak marks.
Sorry for the book, but I hope it helps.
Jul 30, 2009 | HP LaserJet 2820 Printer
Faint area down left side of page
When you say "Cleaned the lens" I presume you mean the four LED print heads. Use a spirit to clean them with if the toner dust is hard to remove. I usually just use a finger and wipe the entire length. Make sure there is no foreign item laying on the drum top where the black plastic film is as the led head may not seat properly on it. Clean all the silver high voltage springs down the left side of the printer. They make contact with the drums. If you still have a problem then try printing solid colour blocks ie Yellow, Magenta ,Cyan and Black . This will identify which colour is giving the problem . Change that drum and all should be well.
Jul 26, 2017 | OKI C3400n Laser Printer
Balck and white streaks on left side of paper
Usually if there are streaks you need to change the pcu that is the same color as the lines. If the streaks are gray it also could be the fuser, but i would think it is the pcu.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
Toner splatter and faint double image
replace the toner cartridge or get the cartridge refilled as its about to empty .
Dec 09, 2008 | HP LaserJet 1020 Printer
Samsung CLP 510 light grey vertical streaks
you have 2 problem.
1). toner is bad
2). toner is low
change the toner should fix both porblem.
try to clean the roller while you have the toner out. (just in case).
Mar 27, 2008 | HP LaserJet 5p Printer
Black streaks
HI there it would need a PCU (Photo Condustor Unit) or drum unit which ever you prefer.
Thanks J
Dec 12, 2007 | Ricoh Aficio CL3500N Laser Printer
Samsung ML 2010 Laser Printer Logo
276 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
