Question about Nokia 5300 Grey Cellular Phone
Memory Chip isn't recognized
Everything on my phone (including the Nokia Suite) is working and updated----except for the memory chip. I've powered on and off the phone plenty of times. I'm unable to format the chip because the phone doesn't detect it's presence. This chip can be detected and read by a PC alone, but it seems to be invisible to my phone. I've formatted it with my PC, but this has had no affect.
What can I do? (It's the 1GB Mini SD Memory chip)
  • Anonymous Dec 21, 2007
    forget m card code
    Sergeant:
  • 199 Answers
Hi, get the card reader replaced by a technician, there might be poor contact to the card or card reader needs resoldering -lose joints .
Posted on Feb 01, 2012
    Sniper:
  • 108 Answers
1.Check whether your mini SD card is password protected
2.if then remove the password options in memory options
3.Check whether the Sd card is seated properly in its slot.
4.there might be sensors on the slot to check whether the card is present and for write protec options.
5.your sd card might be jammed in to the slot
6.Check with other sd card .Verify whether your slot is working properly.
7.improper pin seatings may also be counted
8.Contact service personnel for further recification
Posted on Dec 21, 2007
My phone show memory full,but i hae nothing on my SD card how do i move information from my phone memory to my SD card.
I had a similar issue. You need to go to the settings menu and check to see if your phone is recognized the chip. If no, power off your phone, take out the chip and reinstall it. If your phone is reading your chip, there are many apps you cc an download in google play. If your chip is not recognized, check it in a another phone.
Jan 28, 2015 | Huawei Ascend II battery 2200 mAh, Black
When i play radio or music player in my nokia 5220, the message show up "not enough memory" eventhough i 've deleted many data in my phone. How to resolve it?
have you checked if there are any firmware updates available for your device via Nokia Suite? if there are any, please update to the latest version offered. Failing that, you can try re-installing your current firmware thru Nokia Suite.
You should also save any photos/videos/music to your memory card, or if you don't have one, then invest in one as your device does support microSD memory cards.
to re-install, select check for updates, and it will say there are no updates, and next to the text saying there is no updates, there will be a paragraph within that paragraph in blue text will be "re-install".
Jun 08, 2014 | Nokia 5220 Red Xpressmusic Unlocked GSM...
Nokia C3-01 wont read a memory card
buy new one may the problem in on your memory card chip...
Mar 05, 2013 | Nokia C3-01 Touch and Type Unlocked Silver
I have an acer power f5 which canot accept a 1GB
Try the 1gb chip on its own. (with no other chips)
If it still does not work check your motherboard manual
Make sure that your memory is supported by your motherboard.
You will need to know the type and speed of the memory chip you have.
If the memory is a match and it still does not work it may just be stuffed. Did the memory work in another machine?
Hope this helps
Sep 24, 2009 | Racer AcerPower F5 PC Desktop
Unlock micro SD chip
U CAN PUT DA MICRO SD CHIP INTO THE ADAPTER AND FORMAT IT ON THE COMPUTER AND IT WILL ERAZE EVERYTHING U HAV ON THE MEMORY CARD?
Jun 16, 2009 | Nokia 5310 Cellular Phone
Hi, i have problem with my n73 cell and it is very slow in opening the features and sometimes it will appear " memory full delete some data" even if the memory s still spacious. i want to...
Download and install Nokia PC Suite and Nokia Software Updater available from Nokia.com, once installed use PC Suite to backup everything you need on your phone...
Make sure a working sim is inserted into the phone and General profile is selected, plug in the charger and turn the phone on, once fully started plug in the USB cable and run Nokia Software Updater, it will pick up the phones current version and download any updates...
May 09, 2009 | Nokia N73 Cellular Phone
How do i get the retsriction code for my nokia 5310b XpressMusic
The e-mail solution posted to me by Nokia below to unlock the media licence keys after firmware update worked and is thus (Note all your phone music will be wiped so will need to upload again from your PC):
1. Connect your phone to Nokia PC Suite in "PC Suite" mode. Launch PC Suite.
2. Use PC Suite Content Copier to back up the contents of the memory card onto the PC.
3. Disconnect the phone and format the memory card:
Menu > Gallery > (the memory card folder) > Options > Format memory card > Yes.
4. Re-connect your phone to PC Suite and restore the backed up data to the memory card.
Feb 11, 2009 | Nokia 5310 Cellular Phone
My Black Jack won't recognize memory card
make sure that the device is turned on.
and plug it in again if it doesnt work than something inside the memory chip is busted
Dec 16, 2008 | Samsung BlackJack Smartphone
FORGOT PASSCODE FOR ACCESSING NOKIA N95 MEMORY CHIP
this can only be done with unlocking box;s if u have one then fine if not contact me and arrange for it to be sent to me...email...fawad.tabassum@gmail.com
Jun 08, 2008 | Nokia N95 Cellular Phone
Forgot personal pass code on Nokia N95/need retrieval help
hey go to this page, here are some codes that you can use to reset your phone. http://www.syednetworks.com/general-nokia-secret-codes-for-all-phones. You use it at your own risk. txexixs
Feb 27, 2017 | Nokia N95 Cellular Phone
Nokia 5300 Grey Cellular Phone Logo
64 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
