Samsung NV10 Digital Camera
Problem for Samsung NV10 Digital Camera
Hi, my Samsung nv10 camera, when switching on,
By t_franke on Sep 14, 2009
Hi, my Samsung nv10 camera, when switching on, only the auto focus light comes on. The lens does not pop out or open. The only way to switch off the aoto focus light is then to remove the battery. Any ideas?
Best Solution
posted on Sep 14, 2009
Very Helpful)
BillB-SA
Rank: Wiz  Samsung Cameras & Camcorders  Expert
Rating: 85%, 466 votes
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Samsung NV10 Digital Camera
Questions and Unsolved Problems for Samsung NV10 Digital Camera
Do you recommend Samsung NV10 Digital Camera?
Answer
Answer
self inflicted fault somehow got switched on in case and therefore broke lens will not now extend
Answer
Was given a used Samsung need digital camera VLUU NV10, but manual was not included. Need one badly!
Answer
Hello, I have had this camera for a few years and have had nothing but trouble with it. This camera... (More)
Answer
my camera gets stuck it would just stop working and freeze. i charge it fully and it still does... (More)
Answer
Samsung NV10 lens won't open when I turn on the camera. As soon as I turn it on it beeps 4 times... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Cameras Experts
Top Camera & Camcorder Repairmen
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
