Question about LG LRFD25850 French Door Refrigerator
Water leak from dispenser
Whenever we use the water dispenser on our LG LRFD25820ST refrigerator, we open the door and find water leaks on the floor from under the dipsenser.
I have pulled the dispenser apart, tightened all of the feeder tubes and clips, closed it back up and it is fine for a day. The next day the same problem. I am absolutley baffled!
Fuck LG i have the same problem
Posted on Jan 16, 2008
The reservoir inside has to be replaced. After numerous calls to LG, I finally got the LG Mobile Service Tech to service it, and the water reservoir has been completely redesigned....can you say "design flaw?" Now, since the new "tube" has replaced the "reservoir," I have little green things floating in my filtered water! I hate LG products.
Posted on Jan 15, 2008
  • rochelle dinallo May 27, 2013
    I just got the tubing replacement. any idea how to now replace the reservoir with the tubing?
Lg refrigerator not dispensing water valve in door leaking when prees button
Seals in water valve are likely leaking. Disassemble rebuild or replace water valve .
www.lg.com/us/support/refrigerators
www.lg.com/us/support/parts-accessories
Jun 06, 2015 | LG Refrigerators
My water dispenser in the door is leaking water from behind the lever whenever it is pressed
Hi Daniel Roland - There are many reason for this issue to occur, for example the refrigerator could have a crack in the defrost pan, a defrost drain line blockage, a leak from the water supply line for the ice maker, but most cases water leaking inside and draining through the refrigerator cabinet. Try confirming that the vales are tightened. If the connection is still leaking, turn of the water supply line to the water valve and take the connection apart. You can try using Teflon tape when retightening the connection to ensure a good seal. Should this suggestion prove to be ineffective contact a professional to properly diagnose and repair the refrigerator a good seal.
Nov 14, 2012 | Frigidaire FRS26H5AS Side by Side...
Water leak on floor under refrigerator
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | GE Refrigerators
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
The Refrigerators inside Water Dispenser not Disapensing
Lets try this first. Have someone with a voltage meter unplug the two wires on the side of the dual water control valve for water dispenser on rear of your refrigerator and place the red and black probes from meter into the female end of the dispenser side of plug. Then while someone presses the dispense water control have the other person read the voltage. It should read the same voltage as home voltage when pressed. Us care not to touch probe ends at time of testing. Please tell me your results. I don't think the door open had anything to do with this. Yes leaving a freezer door open for hours does confuse the refrigerators memory and produces heavy ice in strange places. Unpluging and replugging will resolve that. I think the water control valve began to fail by becoming weak and finally failed, Sea Breeze
Apr 12, 2010 | Maytag MFD2561HE Stainless Steel Bottom...
My Kenmore side by side unit leaks water onto the floor and the water dispenser has stopped working. When I hit the dispense switch I hear water squirting.
Probably the plastic tube that came from the solenoid is broken somewhere between the solenoid and the dispenser(usually under the refrigerator).
Sep 20, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Ice is jamming on external dispenser. open the door and ice falls all over floor. what could it be?
my freezer is leaking water all over the floor it can come ok for a few days then starts again also build up of ice inside freezer any ideas how to solve this??
Sep 09, 2009 | LG Refrigerators
The water dispenser leaks
The most likely reason for the leaking at the water dispenser is the dual water control valve on the back and near floor is leaking water while shut off. The only option is to replace the water control valve. Sea Breeze
Aug 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leak in the left door (water dispenser)
ck container to rule out simple leak ck for cracks in container make sure lines are secure and free of breaks also part can be ordered. first ck all basics lines and conections in compartment
Aug 18, 2009 | LG LRFD25850 Stainless Steel French Door...
LG LRFD25850 French Door Refrigerator Logo
841 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
