Question about Dell Inspiron B130 Notebook
Dell B130 won't load up
I have had many problems with this laptop. I invested in another mobo. Lastnight I installed the mobo and the latop worked perfectly. I was using the HD from another laptop that I had purchased. It brought up everything that the original owner had on his HD. I deleted everything and the laptop was running fine. I did a disc cleanup and defragment. This morning when I turned it on it went into the dell screen but the white loadup line only went about an inch and stuck! Will not go any farther. Any ideas what the problem could be? Last night I run the diagnostic disc and the tests passed.
sodak222
  • 1 more comment
  • sodak222 Dec 12, 2007
    Thank You for the info. After running the diagnostic disc again it came up with 2 error codes. They are in the audio. The code numbers are 6563:0268 and 6563:0667 I can't seem to find anything on the internet on how to correct these errors.
    sodak222
    Kegtapper. I tried the F8 key before the meter bar apprears and it does nothing. Still brings up the meter bar. I can't believe this laptop worked perfect last night and nothing today. I have tried a different HD, memory and even switched the dvd/cdrw drive and the same thing.
    sodak222
    Found the problem! The screws in the case were not tight! When I pushed down by the HD activity light it loaded up! I turned the laptop over and tightened the scres and it runs perfect. Why would the case screws not being tight cause it not to load up? New one for me.
    sodak222
    Scholar:
  • 94 Answers
Finding where the problem is.
Start windows in SAFE MODE
You will see the last file that it hangs at. Usually AGP440.sys
Disabling AGP440.sys
Boot the system - Hold F8 Key
before the METER BAR on the bottom starts
Go to the Recovery Mode -
When it ask for directory <1> should be shown (unless you have multiple boot partitions.
When in the console mode enter
disable AGP440 (or AGP440.sys)
***depends on SP level***
Exit the console and attempt to reboot normally
hope that helps
Posted on Dec 11, 2007
My Dell Inspiron B130 won't turn on. The battery light blinks yellow twice then green, but that is the only thing happening.
Take the battery off completely and drain the flea power from the laptop by holding down the power button while the battery is off. Hold down the power button for about 15-20 seconds to ensure no power remains on the laptop. Check if your battery has a drain button too. Drain the battery and place it back on the laptop.
Charge it for about 30 minutes before you turn it on. See if it works.
Post here if you need further help.
Jul 30, 2011 | Dell Inspiron™ B130 PC Notebook
Hello, i have problems installing audio codec in inspiron dell b130. can help. Thanks. winxp profesional.
Hello, To get software codec and driver click the following http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRON1300/B130&os=WW1&osl=en&catid=&impid= Then select your present operating system to get software codec and driver compatible. If finish downloading. double click software, read installation instruction carefully. Before use software codec need to restart your laptop first.
Hope can help you. Fixya team
Jul 10, 2011 | Dell Inspiron B130 Pentium M 1.7ghz...
Inspiron B130 shuts down after about 5 seconds
Sounds like a bad AC adapter not charging the system. If a known good adapter has the same issue (Or this adapter works on another system) then it is a motherboard replacement
Sep 14, 2009 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Startup Issues
when digit the password to initiate does not initiate and it gives the following message me:
The User Profile Service service failed the logon.
User procases out cannot sees loaded
por favor la repuesta en español
Compaq Presario CQ60-215DX Note book PC
May 10, 2009 | Dell Inspiron B130 Notebook
Keys Not working
if replacing the keyboard failed to resolve the problem then the keyboard controller is most likely failing and than means a new motherboard.
Dec 30, 2008 | Dell Inspiron B130 Notebook
Laptop will not come on
If you have good ac to connector and still no activity(no beeping or lights)  need a new mobo.  Try with no battery in.  Else call dell for warranty or take to shop to replace motherboard.  Dell offers extended warranties.  I hope you reupped it!  I change 5-10 Dell mobo's a day.
James Mac
Sep 07, 2008 | Computers & Internet
Blue Screen with error messages
Startup your laptop keep clicking f8 until you see option like star in safe mode just click on "LAST KNOWN GOOD CONFIGURATION(your most recent settings that worked)"
Simple as that ;-).
Dec 29, 2007 | Dell Inspiron B130 Notebook
Power shuts off after about five seconds
check power pack. sounds like it may be bad
Dec 01, 2007 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
291 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
