Fairly new vacuume, while cleaning just turned off. I switched plugs, no go. I cleaned everything out, no go. Let it sit for a while and it still won't turn on. Any ideas?
I have a MACH 3 Cyclone that is only a few months old that just suddenly stopped working and went totally dead like there was no power going to it.
I tested the power switch and noticed that there was no power running to the switch.
I then noticed that the switch sat on top of a very long adjustable handle so I figured I would check the pwer connection at the base of the handle.
1) I unscrewed the 2 screws closest to where the power cord goes into the vacuum.
2) Pulled the small blue cover partially out (it wouldn't come out all the way)
3) I found that there is a power cord (looked like a really small extension cord) that runs through the inside of the handle. Adjusting the height of the handle must have made it come uplugged at some point. I plugged this cord back in.
4) I reattached the small blue cover and screwed the 2 screws back in.
This fixed the problem.
I am willing to be that this is a common issue with this vacuum cleaner. Its a 5 minute very easy fix and strongly suggest checking this if your vaccuum suddenly goes completely dead without warning.
mine blasts dust out the front a makes huge vvvvvv noise and freeks family out,need solution,already dusted it out pulled the strings out of the brush re alighned the belt and took it apart and put it back together again works but,THE DUST!
