Question about Indesit 24 in. IDL700 Built-In Dishwasher
Indesit IDL 730
Wash program seems to work to the end but 2nd and 4th lights flash. Have done all the usual, checked filter etc. All clean as a whistle. Help!!
  • leiherbs Aug 20, 2008
    I have the same problem(2 and 4 indicator lights flash rapidly and washing program is stopped) please help!
    Problem Solver:
  • 17 Answers
As you have checked that all the filters are clean this could mean you could have a problem with your pressure switch. This is a small round device that tells the washer that there is enough water in it . The pressure switch is located under the washer and is eay to fit . Once you have taken off the base of the dishwasher you will see a small round thing attached to the side of the washer base . It has a block connector and a small tube connected to it just remove these two and replace the switch and re plug it in
Posted on Dec 11, 2007
Our dishwasher idl 40 indesit has 1 and 3 flashing lights on the panel seems to be a problem
I have had this problem also and no longer take anything apart take out the filter plate pour boiling water into the well leave for 20 mins put on a 25 min fast wash and hey presto works every time. Mine seems to block up about every 4 weeks and the lights come on but this solution always works
Mar 06, 2012 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL 500 Pump noise when switched on not continuous, sounds like it is acting in surges, and the pre-wash indicator light flashes in time with the surges. Is this a fault, what is the solution?
this indicates that there is water in the base of the unit activating the safety float switch... usually a leak..or an overfill due to blocked filter
Power off & remove plug
1st port of call would be to drain the base by pulling forward and tipping back.. make sure you have large towels to hand...
Once drained power up again and put on quick wash...
if cycle completes verify no leak by tipping back again and no water should flow..
if there is a leak then the flashing would resume during cycle... and best get someone in to locate as there are a few possibilities...
Dec 18, 2009 | Indesit Dishwashers
Green flashing lights , what does it mean ?
I have an Indesit IDL 500, the machine will start fine but after about 20 mins the Ist and 2nd button start flashing. Can you help?
Regards
Ingrid Houben
Jul 06, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Jun 04, 2008 | Indesit 24 in. DE73 Evolution...
Indesit IDL 530 Dishwasher
Switch off, turn off power, turn off water, disconnect water inlet hose, check for blockages, remove filters, clean filters, refit filters, check water supply, reconnect water supply, reconnect power, turn on - problem solved.
Apr 12, 2008 | Indesit Dishwashers
IDL 700
A10 2 & 4 Heating element Open circuit heater
info from idl service manuall
Feb 29, 2008 | Indesit 24 in. IDL700 Built-In Dishwasher
Idl 705
i have similar problem machine starts then stops while bleeping the second and third lights then flash nothing more happens have checked water intake which is ok no blockages any more ideas would help thanks
Oct 07, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Fault codes
could be blocked filter according to instruction book for IDL 730
Sep 14, 2006 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit idl 705 Dishwasher
Having read another users fault (LUNNY) that has same fault. They got engr out and it was a blocked pump. Where is the pupmp located on this model as I have the same fault and want to resolve it asap.
Aug 24, 2006 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit 24 in. IDL700 Built-In Dishwasher Logo
318 people viewed this question
Top Indesit Dishwashers Experts
Eric Taylor
Marvin
Marvin
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
