Can i convert to a dvd i have a trv-35h elmo
You can very easily. You may use the S-VHS output on your Elmo ( a 4-pin DIN socket on the rear) going into the S-VHS input on your DVD player. You will need an S-VHS cord. Very cheap at Radio Shack or on Ebay. This gives the best quality. Our you can use the more familiar RCA composite video output (yellow socket) from the Elmo into the composite or auxiliary input on the DVD recorder.Be sure you have selected the proper input on your DVD recorder. Use a TV set as a monitor so you can see what you are recording.When I convert slides to DVD, I do a test run through the carousel to be sure the slides are all facing the right way, not upside down or backward.I set my Elmo timer on 5 seconds and let the carousel advance automatically. You may want to zoom in or color correct as you convert. In that case, pause your DVD recorder between slides, make your adjustments, then resume recording. This is called assembly editing. It works very smoothly and you get a better show,
Removing base will not allow me access to the lever mentioned or is there a way of dismantleing it further, thanks for your help, it is now intermittent as some times still only works in reverse then a loud click and is OK again.
The spring that pulls the fwd rev lever has come loose. I do nort know how to put it back on. It is attached to the underside of the lever and has two wires tha t somehow hook up tho either the lever or somewhhear on the machine. One wire of the sprong is straight and the other is has a right angle bend. I can not figure out if the bent wire hooks onto somthing or goes under the frame the lever is connected to.
Does anyone know how to hook this up?
Thanks
