Question about RCA F36650 36" TV
Picture problems It almost seems like it is getting a interference or something. The picture is good and the some off it gets distorted in some places and then it goes back to normal.
  • 346 Answers
Replace tuner
Posted on Dec 22, 2007
  • 108 Answers
Problem in the tv tuner. video processing cirucuits. Contact service engineer as there is no rectification process from the user part
Posted on Dec 20, 2007
Zte phones
It might be due to some interference in your network. If you gave good coverage and yet voice distortion takes place, then it might be due to some hardware issues in your phone. Please get it checked in a service center.
Aug 15, 2014 | Tracfone Wireless ZTE Valet
Phillips 28in wide screen tv. Picture OK through Sky, but has two moving distortions on ordinary aerial. Actual picture is good but the distortions moving up the screen make it very difficult to watch.
Even digital signals can be sensitive to electrical interference and using an antenna, you could be getting garbage from any nearby 'noisy' source. Something you might try is to temporarily switch off any electrical device in your home, one at a time and look for changes in the banding you have.
If the antenna you are using is outside (rooftop) and is rotor equipped, try changing the position to see if there is any increase or decrease of the problem. If an indoor antenna, rotate it slowly while watching the TV display for change. You may be able to determine the general direction of the source of interference. Some seemingly innocent devices that can cause problems; - Light dimmers/controllers - Poorly designed network routers - Cordless phones - Power supplies
Dec 01, 2010 | Philips Televison & Video
I own a pair of B&W dm605's and I am getting distortion from one of the units in the bass drivers. I have switched out the drivers with the 2 from the unit not making the noise and it is still there so...
I use sightly different nomenclature than you do, as I am an old audiophile However, if you have switched the dm605 that has the problem to the inputs to the dm605 that was OK and that unit stil has distortion, the problem is with the dm605 with the distortion. If the dm605 uses passive crossover network (inductor and capacitor), I doubt that is is the problem. That leaves the amplifier internal to the dm605 or or the speakers themselves. One or more of the speakers could have a tear in the speaker cone or physical interference between the magnet and coil..Interference can be caused by dirt or misalignment.
Dec 16, 2017 | B&W DM605 S2 Speaker
Kv-35xbr48 turns on fine nice picture then horizontal lines form distorting picture like interference also is the back hard to take off and put on needs a good vacum thanks for any suggestion
At first the picture is ok, and then distorted with horizontal lines i thinks. If the horzontal lines are parellel acros the screen, with an inch apart across the whole screen, your tv needs screen adjustments. Screen voltage may be high. look into the crt base also. Change it first. These also not resolve the problem, LOT may be faulty, with respect to screen focus pack. May need replacement. Try first setting screen voltage to a lower settings and observe.
Oct 14, 2010 | Sony KV-35XBR48 35" TV
Screen distorted,cannot watch dvd or vcr
If you are located near a tv station that is broadcasting on the same frequency that your dvd player is trying to use, you will pick up some of the stations' signal that will cause some video ( and sometimes audio) interference. To remedy this you need to set the dvd player to use another frquency (channel). To do this there may be a small switch on the back of the unit or you may have to do it through the players' programming menu where you would look for something like 'output channel select'. I hope this helps :)
May 27, 2009 | Samsung DVD-V5650
Uniden BC80XLT Radio Scanner distorted
It may very well be an interference problem. While the scanner may not have moved, there are many items around it that may be the source of interference. Think back to the time when the interference started. Did you install something new around that time frame? Perhaps a new computer, a new monitor, some new CFL light bulbs? Any of these items can cause interference. The other possibility is that the interference is coming from outside your home or office. While these sources may not be able to be corrected, you can do a few things to help reduce the effects of the intererence:
1. Move the scanner to a new location. Radio waves are tricky little things. You may be able to find a location where the interference is weaker, but your intended signal is still adequate.
2. Try moving the antenna. If using the rubber antenna that came with the scanner, try laying the scanner flat instead of upright.
The other thing you may want to do is check the frequency with another scanner. There is always the remote possibility that the problem is with the transmitter, and not with your scanner at all.
I hope this helps. Good luck!
Dec 27, 2008 | Uniden BC80XLT Handheld Scanner
Cd vs. microphone
A few possibilites.
1. Even though you have some kind of peak limiting on your mics, the signal might still be peaking somewhere along the audio path and causing distortion. Gain controls might be set too high somewhere along the way.
2. The amp you are using might simply be driving too much power for the speakers to handle.
3. A faulty connection, connector, wire or input could cause distortion of something like distortion which is of course would be more apparent at higher volumes.
4. Equipment placement could be picking up sounds or interference from other sources.
5. If you are able to discern level peaks but they are occasional and not flat out, then a compressor placed in the mic signal path could certainly help - otherwise see # 1 above.
Best of luck in solving this.
Oct 25, 2008 | Audio Players & Recorders
I recently bought a new DVD/VCR machine. The VCR is the problem, tapes are jumpy, many lines across the screen and close captions are distorted. EVen just watching TV without tape or DVD, close captions...
Hi Carrie
Not to worry, son-in-laws are good!
Assuming the machine is working correctly, there is only one reason why the picture will be distorted and that is interference.
Here are a couple of things your son-in-law may be able to check for you.
Firstly, make sure that the DVD/VCR is connected to the television using a scart lead. The DVD/VCR was probably supplied with one. It is a short cable with a large rectangular connector at each end.
If a scart lead is already being used, there may be other units connected to the tv that are causing interference. Try removing all the other units like cable tv, satellite receivers etc and see if the DVD/VCR is any better when it is the only unit connected to the tv. If it is, you will need to use a scart selector box so you can switch each unit connected to the tv separately. (Sorry I know it's getting confusing now!)
If it still isn't any better, ask you son-in-law to check through the menu on the DVD/VCR and look for a setting for Video Format. This should be set to PAL Format unless you are in North America in which case it should be set to NTSC Format.
Hope this helps, please feel free to ask me for more info if you still have problems.
Mar 13, 2008 | Televison & Video
Philips 55PW9363/17F
you get the distortion when the shredder is on because the shredder is sparking causing the interference. you can check your cables to make sure the have good grounding or just replace the cables.
Dec 03, 2007 | Philips 55PW9363 55" Rear Projection...
Sony DAV SA30 dvd player
Hi From the symptoms, you mentioned, ie playing CD's ok., Mpeg decoder chip is faulty. The new one supplied is a modified type. IC207, part no.6-707-406-01. Good luck. Capital98
Aug 16, 2006 | Sony DAV-SA30 System
RCA F36650 36" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
