Question about Mastercraft Garden
I need a part for my mastercraft welder 58 8018 2. Where can I get it?
  • 5,641 Answers
I don't know the answer but the best place to begin will be the supplier you bought the welder from.
There is a strong possibility your little welder is of generic origin that is label engineered. If this is so there is likely to be many common parts shared by similar machines bearing different labels so some parts will be virtually universal and available from motor factors and welding specialist suppliers.
Posted on Sep 11, 2019
SOURCE:
Instructions on how to assemble the rolling cart for a canadian tire mastercraft 80 amp welder
This is a FUN project.
No instructions is even more fun.
Patience and logic.....
Hopefully you have alll the parts.
Spread them all out and then sort them.
Organize into categories:
- bolts
- nuts
- washers
- frame components.
- Etc.
The various bits have to be attached to each other so that the finished cart will receive the welder.
Take your time, loosely assemble what you think it might be, involve the wife and kids.
Eventually you'll get it and there won't be too many extra parts.
Hint! They sometimes give you extra parts in case you lose some.
Count the nuts and bolts and washers. Match them up to what they will hold together.
Remember, it's a fun project. Lot's of people NEVER read the instructions, much less use them.
Red Green would be proud of you!
Apr 29, 2015 | Welding Tools
I have a mastercraft arc welder that turns on but won't arc the overload light is not on or enything
I'm not familiar with this model and I don't know it's age, but as a general check item on any welder, make sure your welding leads are in good shape and that your earth clamp is actually connecting to it's lead. They can burn and tarnish with use and fail to connect. Check likewise the lead connection into the electrode holder. Check their attachment to the welder unit too. There may be a thermal overload protection fuse/device/switch inside the unit which may need to be reset/replaced if you've worked it heavily recently.
If the welder is TOTALLY silent when you switch it on, it may indicate a transformer failure for some reason, usually there is a little bit of buzz or hum. Within safe limits (bear in mind there are dangerous high voltages inside the welder) you might use a simple multi-meter to check that you are getting transmission of power from A to B throughout the unit to the work piece, and that you've got adequate voltage arriving at the work. More safely, with input power totally switched off and unplugged, you can use a multi-meter to check continuity of circuits through the welder to make sure there isn't a break in connection somewhere from a component fault or failure.
Nov 15, 2014 | Garden
My mastercraft ark welder turns on but won't ark the overload switch is not on
Get someone with electrical knowledge to test the circuits. Do you mean an Arc Welder or do you mean a MIG Welder? They are completely different in operation.
I have a Mastercraft AC-230 welder (58-8009-8) with helmits and accessories for sale. It is quite old and user has passed away. How much can I ask for this??
It is impossible to give a price without seeing the lot for sale, I will say that AC Oil cooled sets are a shop luxury and Manufactures of fertilizer would give you a good price, find a friend in the welding game, get his advice,
Jan 27, 2010 | Miller Electric Mfg Co 903505 Invision...
Looking for user guide for Mastercraft compound mitre saw model 55-6821-0
Hope this helps, you need to call or email.
Contact Info
Phone (305)392-2525
Fax: (305)392-2590
Email: [email protected]
[email protected]
[email protected]
Postal: 1354 NW 78th Ave. Miami, FL 33126
Nov 22, 2009 | Mastercraft Garden
I have an old mastercraft 110 volt ac stick welder model 110-104 have not used it for years have lost the instruction manual plate on the machine says primary voltage is 115 and primary amperage is 26.6...
35 amp should do nicely however make sure the mains cable is of the correct size, better still, get a qualified Electricion to install it.
Usualy 30amp could be used but using 35amp gives you some reserve
Oct 03, 2009 | Miller Electric Mfg Co 903505 Invision...
Mastercraft arc welder
i have a mastercraft welder wire feed , the power turns on the wire feed works and the fan in side turns on but it will not weld not even a spark! can anyone help?
Aug 30, 2008 | Miller Electric Mfg Co 903505 Invision...
Garden Logo
13 people viewed this question
Top Mastercraft Garden Experts
Frank Walton
Level 1 Expert
Vernon Taylor
NOEL
NOEL
Are you a Mastercraft Garden Expert? Answer questions, earn points and help others
