Question about ASUS Computers & Internet
I have my own wifi, ASUS RTAC-3200. The wifi in the AT&T modem, Arris BGW210-700 doesn't do well enough to support all of my devices. Can I turn off off the router on their modem and use my own?
    New Friend:
  • 9 Answers
Yes you can..just put it on bridge mode
Posted on Sep 15, 2019
  • ASUS Master
  • 5,246 Answers
Ok this is so simple.
first off the router has ethernet,
and you can run 10 Access points or more in home..
off that 1 port. (router to AP1, then to AP2, and to AP3
all wired, then each with its own SSID. that is how I do it
and gains max range doing so.
if you like magic, get a MESH AP. (but is expensive)
and point 2, all AP even modem wifi or router wifi can be turned off easy, the manual is free to read, and the box to check is called
disable. wifi. for sure.
if you cant tune off wifi in the ISP modem and they will not help you then just leave it alone, ignore it
and setup an AP with its own SSID.
even use different channels, too. for sure.
SOURCE:
djxtreme979
  • 151 Answers
SOURCE: Switched to cable(arris modem) can't set up network
cable dsl same thing. Did you switch providers and get new modem from them? If so. Just delete previous netowrk and install new one let pc discover new one. Also, with your router you got a disc. It should install correctly. Perhaps it is previous network that is hindering you.
Posted on Dec 30, 2008
ohms
  • 1879 Answers
SOURCE: ARRIS Modem + D-Link router = no internet
when you are on Cable Internet with a "modem" only connected directly to the computer, what the ISP see is the computer's MAC Address (command prompt -> type ipconfig and hit enter).
put a router (which has it's own MAC Address) in-between and the ISP wont let you cause it sees the router not the computer.
check physical connection: cable modem -> router -> computer(hard wire for this troubleshooting)
access the d-link gui and locate the “Clone MAC Address" button (supposed to clone the computers MAC Address - verify if it's the same), save settings & reboot the router.
Posted on Jan 26, 2009
  • 31 Answers
SOURCE: i have an arris tm602gct and cannot connect thru my netgear
Can you connect if you are directly wired into the router?
You may want to try using a ball point pen and pressing the reset button on the back of the arris. Let it reboot and try again.
Some netgear routers come with the wireless disabled out of the box, so you need to be hard wired when you run the CD or if you try to connect through your browser 192.168.1.1
Posted on Apr 09, 2009
SOURCE: Arris Modem won't work with Airport Express
Not sure how helpful this will be, as I'm running a different piece of gear, plus it requires both troubleshooting + ISP assistance.  I had a similar problem with my AirPort Extreme: AirPort Extreme saw the Arris, iBook saw the AirPort Extreme, but no internet connectivity.
  1. In my case, I needed to set the AirPort to DHCP in the AirPort Utility application.
  2. Power down the AirPort Extreme
  3. Power down the Arris. You achieve this by unplugging the Arris *and* removing the back-up battery.
  4. Wait a few moments.
  5. Insert the battery into the Arris.
  6. Plug in the Arris power supply.
  7. Wait for the Arris to go through the restart protocol; when all the lights on the front panel are solid green, the start-up is complete.
  8. Power up the AirPort Extreme; wait for the front panel light to go solid green.
As I was doing this, I had my ISP on the phone that confirmed complete connectivity of the signal path and ensured that I was online.  While the Arris was powered down, my ISP also sent a "message" to the Arris; I don't know if this was a software update or what.  I completed the AirPort set-uo through the Utility application, the AirPort restarted, and I was online.
Hope this helps.
Posted on Apr 13, 2009
SOURCE: can't install linksys wrt54g2 router with arris tm602g modem
I've tried network magic and everything thing else and I still can't get it to work.
Posted on Dec 19, 2009
I have an arris modem and my wifi keeps going in and out...called comcast they said we have to change the channel on the modem and i have to get in touch with arris.. how do I do this
If you have the model number we can assist you. There are several things that you need to know. Your password to the modem if you have changed it, You need to be able to connect directly to it with a network cable,
May 05, 2018 | Arris Computers & Internet
How do I get wifi to work after the service guy has left
If he has activated WiFi, your WiFi capable devices should be seeing an Arris-XXXX wireless network. Just select that network and use the password the service guy has left you.
Dec 19, 2014 | Gateway Arris Touchstone Telephony Cable...
Nexus 5 drops motorola surfboard wifi with a minute. Nexus works with other wifis
You can check with Arris ( ARRIS for Consumers ) or contact the manufacturer of your Nexus 5 for troubleshooting.
Mark
Motorola Mobility Support
Nov 29, 2014 | Arris Computers & Internet
Find network key on sb6141
The term "Network Key or Passphrase" indicates your printer is asking for a WiFi password, but the SB6141 is not a WiFi capable device at all, it's just a Cable-to-Ethernet device. So then, you need to look at your WiFi router, which should be connected with an Ethernet cable to your SB6141. If this doesn't match your setup, you'll either need to get a WiFi router hooked up (that process will contain the answer to your question) or simply use an Ethernet cable for your printer.
Nov 09, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
I HAVE AN ARRIS TG862 & I CAN GET THE INTERNET THROUGH LAN BUT NOT WIFI HOW DO I GET WIFI TO WORK ON THIS PRODUCT? I HAD A TECH. FROM MY SERVICE PROVIDER AND THEY TOLD ME TO CONTACT ARRIS
This is a product that will support WiFI. Here is a description of it:
Touchstone; TG862A/NA Wireless eMTA;
DOCSIS 3.0, 802.11n, 2.4GHz, 4 Gigabit
Ethernet, 115-240VAC, 50/60 Hz North American Power cord,
If tech from service company could not activate service, I assume he feels something is wrong with the modem itself. Are you connecting over frequency 802.11n to the modem, perhaps it is not seeing the wireless frequency?
Feb 20, 2014 | Arris Computers & Internet
Arris WiFi Modem to lenovo thinkpad t61
As it works ok on your other devices then it may be the software on the T61. Try going to devices - wifi and update the driver.
Jan 28, 2014 | Arris Computers & Internet
Why cant i get wifi for my itouch
If you asking "does the arris have wifi?" then the answer is no, not this particular model.
Dec 25, 2008 | Arris Touchstone 450a (CM450) Modem
Connecting my arris modem to x-box live
I have an Arris cable modem and use Xbox live. They work very well together. Most ISP's will only allow one active device at a time. When you switch between you cable modem and your Xbox you need to use a pen and press the reset button on the arris every single time you switch.
Jun 22, 2008 | Arris Touchstone 450a (CM450) Modem
Open Questions:
Computers & Internet Logo
14 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
