Question about Dell 0Y3740 Keyboard
Dell Computer-MS Keyboard--HELP
I just had a Dell 5150 serviced by a contracted technician because the memory was defective. I bought this computer second hand and the keyboard is a microsoft keyboard not a dell keyboard. After the technician fixed the memory problem and replaced it I now can't use the keyboard. When I boot up the computer I have 3 little green lights that are flashing on the keyboard but the keyboard will not work.
Before this computer completely died on me I was having the same keyboard issues on and off. Do you have any suggestions?
Thanks for your help.
Sincerely
Tammy
  • beckyk315 May 21, 2008
    my key board works for a while
    then stops
    or makes letters like this
    bbbbbbbbbb
    tried others
    does the same :(
  • 1,602 Answers
YOU MAY HAVE TWO ISSUES:
KEYBOARD NOT CONNECTED
CMOS BATTERY IS STARTING TO FAIL
HOW MANY TIME DID THE LIGHTS FLASH.
DID YOU CHECK TO SEE IF THE KEYBOARD WAS EVEN CONNECTED, IT GOING TO BE A RIBBON WITH LITTLE WIRES GOING THROUGH THE RIBBON, THE RIBBON ONLY GOES IN ONE DIRRECTION,
THE OTHER PROBLEM IS IF THE CMOS BATTERY IS GETTING LOW THEN IT WILL NOT KEEP THE BASIC INFORMATION ABOUT THE COMPUTER SETTING CORRECT, THIS MEANS YOU COULD LOOSE THE MONITOR, KB, HD, TIME, OPERATIONAL SYSTEM, AND BOOT SEQUENCE. HARD DRIVE SETTINGS.
IF YOU JUST PICKED UP THE COMPUTER FROM THE SHOP
YOU SHOULD OF CALLED THEM AND EXPLAINED THE PROBLEM AND WHAT SHOULD YOU DO NOW.
RODGANDYSR.
P.S.
EVERY TIME YOU EVERY HAVE ANYONE ELSE WORK ON ANY OF YOUR COMPUTER EQUIPMENT AND DEVICES, HAVE THEM EXPLAIN WHAT THEY DID IN SOMETHING YOU CAN UNDERSTAND SO YOU DONT MAKE THE SAME MISSTAKE AGAIN.
Posted on Mar 07, 2009
Dell set me a new keyboard to replace the original one because the keys are sticking and one fell off. No instructions and I don't how to lift up the plastic around the keyboard to replace it
Hi ktaydus.
Welcome to FixYa! How are you doing?
You did not specify the model of your dell computer.
You can check the manual online so that you know the step by step instruction on how to replace the keyboard of your dell computer.
You can go to this link: http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?c=us&cs=19&l=en&s=dhs&~ck=anavml
Just select the model of your dell computer or enter the service tag which you can find on the bottom of your laptop.
Hope that helps. Thank you for using FixYa.
Jul 18, 2011 | Computers & Internet
Tip
Service manual for Dell inspirion 1100, 5100, and 5150
Hello,<br /><br />Download the service manual for Dell inspirion 1100, 5100, and 5150 by simply click the below link.<br /><br />Note that the manual is in PDF format, so you need to have Adobe Acrobat reader already installed on your computer.<br /><br />Also, your computer configuration speed will determine how fast the service manual will load. Wait for the service manual to load completely before scrolling in order to avoid it hanging.<br /><br />It is advice able that you print it so that you can have a hard copy. Its usually strenuous reading from the computer.<br /><br /><a href="http://www.elhvb.com/mobokive/edwin/laptops/dell/INSPIRON/1100-5100-5150/1100-5100-5150.PDF%20">http://www.elhvb.com/mobokive/edwin/laptops/dell/INSPIRON/1100-5100-5150/1100-5100-5150.PDF</a> <br /><br />Good luck.<br /><br />
on Dec 28, 2010 | Computers & Internet
My secretary was using my computer and now I can't get the "insert" key or the numbers pad to work. I have a dell wireless keyboard. When I bought a Dell laptop several years ago I had to...
Welcome to FixYa.
As a standard troubleshooting for wireless devices please do the following:
  • Restart your computer.
  • Open note pad and test your keyboard.
  • See if the keyboard functions properly.
  • Open MS word and test your keyboard.
  • See if it functions properly.
Tell me the results in Notepad and MS Word so that I can determine if it's the macro in MS Word that turns the INSERT and NUMPAD key off.
Jun 18, 2011 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard on my dell studio 1737 doesn't work, mousepad works, keyboard does not
It could be one of two things, the ribbon cable that connects the keyboard to the motherboard is disconnected.
Or it's a defective keyboard.
Keyboards for laptops are relatively inexpensive, anywhere between 20-40 dollars on ebay.
Buying a new keyboard and having a computer technician install it, which takes ten minutes, should be a good investment, rather than getting a new computer or sending it back to dell.
Hope this helped.
Apr 18, 2011 | Dell Studio 1737 Laptop
6 beeps no signal and display dell 5150
it is probably a problem with your Ram Memory. however i would like to recomend you to check this link about your computer lights and beep codes http://support.dell.com/support/edocs/systems/dim5150/en/sm/tshoot1.htm
gud luck
Jan 26, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My Dell Inspirion 5150 will not turn on. The Battery, gleen light is on. When I press the power button the fan starts and the computer appears to try to start for 5 seconds and then dies. Any ideas?
The Inspirion 5150 is a wonderful computer. reseat the memory chips it should fix it. or else. you cna run the hardware test. to run the hardware test. turn off the computer and then press the Fn key on the keyboard hold it down and then turn on the computer. the computer will go into diagnostic boot where it will test all the components. and you cna release the fn key then. it will tell you which h/w part has gone bad. i think its a motherbaord, but you can try to reseat the memory may be it will fix it.
how to reseat the memory? click here to see how to reseat all the components in 5150. Good luck.
Aug 05, 2009 | Dell Inspiron 5150 Cooling Fan with...
1 USB Port Failure
Hi Guys
Unfortunately after looking at the computer installation details i was at fault, although i have had
the computer for well over 2 years and this is the first time it has happened.
My Dell Dimension 5150 has 7 USB ports 5 at the back and 2 in the front and it appears that i have
connected the keyboard and mouse to the wrong ports.
There are two ports at the bottom allocated for the keyboard and mouse and for some reason i had
them in the top three ports hence my problem but still not sure why it happened.
Anyway my Dell Dimension 5150 is now running OK and no further help is needed.
Many Thanks.
Nov 03, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension E510 memory upgrade
Please check the type of RAM you are using.
You must return it to BestBuy and try using a Dell store.
Call Dell Accessories sale and they will be able to give to better options and it wud work too.
Jun 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 0Y3740 Keyboard Logo
147 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
