Metz 45CL-4 Pinouts for add-on battery pack plug
Have purchased add-on battery pack(over the shoulder) but need pinouts to hook up or make cable to plug into flash unit jack (Top, Right when facing flash lens)
SOURCE:
  • 216 Answers
SOURCE: Metz 45 ct5 flash battery pack wiring diagram
You can rig that fella up for a better power.
[email protected]
Posted on Dec 30, 2007
rhoncruz
  • 134 Answers
SOURCE: need pinouts
I have an old pc chips M575 motherboard that also uses the J3 ATX Form card. I can only assume the pinouts are the same so here they are from the manual.
Pins 1-4 and 10- 13 are USB connectors
USB USB
Pin Description Pin Description
1 +5v 10 +5v
2 data- 11 data-
3 data+ 12 data+
4 ground 13 ground
Pins 5-6 and 15-16 are PS/2 Mouse Connector
Pin description
5 +5v
6 Mouse CLK
15 Mouse Data
16 ground
Pins 7-9 and 17-18 are Infrared connector
Pin description
7 Ground
8 Reserved
9 +5v
17 IR in
18 IR out
hope that helps
Posted on Nov 30, 2008
SOURCE: Metz 45CL-4 Service Manual wanted..
Hi !
Here is a link to the Metz manufacturer:
http://www.metz.de/en/photo-electronics/instruction-manuals/mecablitz.html
I hope it will be to some help.
Regards Lars
Posted on Feb 27, 2009
SOURCE: Acer veriton 7100 front panel audio pinouts
gfexcel  vga drive
Posted on Jun 26, 2009
  • 14 Answers
SOURCE: JFP1 AND JFP2 PINOUTS
http://www.retrevo.com/r/11370bh228/4/Mainboard+Layout#q=MSI+MS-7021
Posted on Dec 14, 2009
Can metz 45CL-1 support Nikon D5100?
To use Metz 45CL-1 with Nikon D5100, you need use in apperture priority mode (A), adjust same ISO and apperture in Flash and Camera (Ex: ISO400 and F: 5.6) . The flash adjust light intensity to mantain correct exposition. You need use an adapter to conect Sync cable in your camera.
Nov 13, 2015 | Nikon D5100 Digital SLR Camera With...
Pinouts for metz 45-ct5 flash
Center of PC Sync Plug is Positive.
Outside is ground,
[email protected]
Feb 10, 2014 | Metz Mecablitz 60CT4 TTL Flash
Connecting usb
Usually red white green and black unless the motherboard has a cable connect lead already
The USB Pinout:
Pin
Name
Cable color
Description
VCC
Red
+5 VDC
D-
White
Data -
D+
Green
Data +
GND
Black
Ground
http://pinouts.ru/SerialPortsCables/usb_cable_pinout.shtml
http://pinouts.ru/Slots/USB_pinout.shtml
http://pinouts.ru/connector/4_pin_USB_A__USB_B__mini-USB_jack_connector.shtml
hope some of these will help you
Feb 24, 2012 | Foxconn 6100K8MA-RS Motherboard
Can a Metz 45CL 5 be used with a CanonD40 safely?
Are you sure that you have a 45CL-5? It's a model which I've never seen nor heard of before, but it's possible that it is a non-standard custom model number for a specific supplier or territory.
The answer to your question is "possibly": but you asked if it can be used safely so the answer must be a firm "no".
Various sources (e.g. here) quote the trigger voltage on the (presumably closely related 45CL-4) to be a little higher or even vastly higher than Canon's 6v limit. Metz themselves are unclear on the issue and it doesn't help that they do not list the CL-5 on their support page nor on their main corporate page, but they do list a 45CL-4 and a 45CL-4 Digital. The differences between the two models may just be to add additional capabilities which suit digital SLR's but perhaps it also brings the trigger voltage below Canon's 6v limit.
As there is so little published information about the 45CL-5 then I strongly suggest that you do not risk your camera until you have a definitive answer from Metz themselves: you can contact their support service by clicking here. The link is for the UK, if you're elsewhere (Australia?) then you may need to make your own search.
I hope that I've been of some assistance and that the links provided help you to get the answer straight from the horse's mouth. Please take a moment to rate my answer.
Feb 20, 2010 | Metz 45 CL-1 Flash
Hi My Metz 45cl-4 asa control on the hammerhead
yes it can be repaired use a WD 40 spray on asa dial try it
Oct 10, 2009 | Metz 45 CL-4 TTL Flash
Hi !
Regards Lars
Jan 27, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Contacts voltage
Originally the 45CT1 had high trigger voltage. In the production period Metz improved it to a much lower voltage release circuit. Metz homepage (metz.de) holds the information, from which serial number on have 45-CT1s low trigger voltage. However, even the high trigger voltage was lower than 200 volts, thus safe for your Fuji.
Laszlo
May 03, 2008 | Metz 45 CL-1 Flash
Metz 45cl
I found th answer in the manuel. You can not use flash when pluged into charger.
Apr 24, 2008 | Metz 45 CL-1 Flash
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Ekse
