Question about HP Photosmart 3310 Printer
Not able to get printer to respond
I get an error reading Magneta cartridge damaged or low on ink. I've replaced ink cartridge, gone thru shut down and start-up mode and have not had any results. Printer is locked up.
  • Just22 Jan 08, 2008
    I have the same problem but with the black cartridge.  I have bought a new one and it is still telling me that it is missing or damaged and not responding. What do I do?
  • 3 Answers
Try the solution suggested by 'STP162'
I had the same problem with a yellow cartridge, and, fingers crossed, his solution appears to have cured it.
Thank you STP162.
Posted on Jan 03, 2008
How can I make printer recognize refilled cartridge on lexmark prevail pro 705
Refilled cartridges will not reset the ink levels. The printer will still recognize it as empty.
Please be advised that refilled/remanufactured cartridges could damage your printhead and will not be covered under warranty.
Nov 27, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
Hi. My C3300 black and magneta is empty. I refilled it but it still say's it's empty and a yellow/orange light glashes on the panel. Can anyone help please
If the ink was refilled and the cartridge put into the printer it is possible that in most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
May 05, 2011 | Office Equipment & Supplies
I have a ip43oo and I get service error B200 What is it?
Your Pixma ip 4300 error B200 definition: Over-heated print head. It sounds like an: "ut-oh', but not a big deal. The reason the print head overheats? Ink needs to be replaced... Replace the ink cartridge that is low (you should have received that message at least once).
I would shut it down to prevent damage, until you can get the ink cartridge replaced.
Mar 17, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
How do i install my ink cartridges into my epson stylus nx125
Starts on page 23. http://files.support.epson.com/pdf/nx125_/nx125_qr.pdf
Replacing Ink Cartridges Make sure you have a new ink cartridge before you begin. You must install new cartridges immediately after removing the old ones. Caution: Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. Note: Leave the expended cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. 1. Turn on your printer. 2. If an ink cartridge is expended, the error and ink lights on the control panel stay on. 3. Open the document cover, then open the ink cover. Caution: Do not remove the ink cartridge guard or you may damage the printer.24 Maintaining Your Printer 4. Press the y Stop button. If a cartridge is low or expended, the print head moves that cartridge to the replacement position to indicate that it should be replaced. The P Power light starts flashing. If two or more ink cartridges are expended, the expended cartridge at the far left moves to the replacement position. The P Power light starts flashing. If no cartridges are low or expended, the print head does not move. Note: Do not hold the y Stop button for more than three seconds, or the printer may start cleaning the print head. 5. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning: If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children.Replacing Ink Cartridges 25 6. Before you open the new cartridge package, shake it gently four or five times. Then remove the cartridge from the package. Caution: Do not touch the green chip on the front of the cartridge. This can damage the ink cartridge. 7. Remove the yellow tape from the bottom of the ink cartridge. Caution: Do not remove any other labels or seals, or ink may leak. 8. Insert the new ink cartridge into the holder and push it down until it clicks into place. 9. Press the y Stop button. If another cartridge is low or expended, it moves to the replacement position. Repeat steps 5 through 8 to replace any other cartridges that need to be replaced. When you press the y Stop button and no other cartridges need to be replaced, the print head moves to its home position and the printer starts priming the ink. This takes about 1 1/2 minutes.26 Maintaining Your Printer When the P Power light stops flashing and the error and ink lights go out, ink charging is finished. 10. Close the ink cover, then close the document cover. Caution: Never turn off the your Epson printer while ink is charging or you'll waste ink. If the error and ink lights remain on after the print head moves into its home position, an ink cartridge may not be installed properly. Press the y Stop button again, and then press the ink cartridge down securely. Note: If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
The other day i opened the cartriges to see the number so i know which ones to get at the store and now i know ink is very low not sure how low but when i try to print it says allign cartriges and it dont...
Hello. Usually, the printer will just notify you that the ink levels of your cartridges are low and if they're out of ink already, it will advise you to replace the cartridges and won't print. In your case, the cartridges may be sending wrong information to the printer. Since the ink levels of your ink cartridges are low already, you might as well replace them. Hope this helps.
Mar 21, 2010 | Lexmark X2600 InkJet Printer
Ink cartridge error
Get a new magenta cart, but make sure you buy a genuine one, not a compatible. The chip on the cart in question may be faulty (approx 30% of compatibles can be faulty).
If the error does not go when a genuine cart is installed you may have a faulty main board or carriage.
Aug 26, 2008 | Epson Stylus Photo R320 InkJet Printer
Overiding Empty Cartridge error for Dell A10 962
I would take out both cartridges and put them in again. Realign the printer and the error codes should remove themselves. Try turning the printer off and on before puting the cartridges in again. That may make a difference. You can let your computer know not to tell you when the ink is low too. Let me know how this work for you.
Cynthia Charczenko
Dec 26, 2007 | Dell A940 All-In-One InkJet Printer
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Printing Error
try changing the ink cartridges.
This may have happened due to low ink levels. Also try reinstalling the printer driver.
If the print cartridges are damaged this problem will pop up. Even static electricity in human hand could damage the print cartridges.
Oct 07, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP Photosmart 3310 Printer Logo
49 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
