Question about Minolta EP1030/1030F CS/PRO Copier
Minolta cs pro
When coping I have dark spots at top half of page- Looks like toner spots.
  • pklady36 Mar 19, 2008
    My copier is actually EP1031/EP10311F and I have spots all over the paper, even after replacing the Toner. I have cleaned the glass & pad, but it doesn't help. What else can I do??
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Minolta Master
  • 1,362 Answers
If it's only on the top half of paper there is something more going on, the seperation assembly could be having problems where the paper as it goes through lifts up on the drum and gets dirty.
Posted on Dec 12, 2007
Error Code C000
Minolta cs pro ep6001
error code - C 000
Sep 02, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
Minolta CSPro copier is not printing
Change the transfer/separator corona holders,corona wires and clean the optics(mirrors,lens exposure lamp),and make a copies.
May 24, 2010 | Minolta EP4000/5000 CS/PRO Copier
Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
May 10, 2010 | Konica Minolta Office Equipment & Supplies
Dark lines in center of the page when we make copies. Glass is clean. Toner is full. What is the problem?
You need to do some maintenance functions on it, go to preferences, then maintenance or cleaning.... it should show you how to clean so the lines are gone..
Apr 19, 2010 | Minolta EP1031/1031F CS/PRO Copier
1/3 OF RIGHT SIDE OF PAGE DARK OR LINED TOP TO BOTTOM
Drum Cleaning Blade failure. Open up the top half of the machine as if you were removing a paper jam. Now look under the top half and about in the center from left to right. You should see a burgundy colored cylinder running from the front of the machine to the back. If you can see the toner streaks on the surface....expecially on the 1/3rd like on the copy then this will be proof that the drum cleaning blade is the cause. Simple repair for a tech that knows copier basics. A good estimated cost would be about $25.00 for the blade and whatever the going rate is for a service call in your area.
Jan 28, 2010 | Minolta EP1083 CS/PRO Copier
Smudge on the paper
When you say smudges, do you mean toner spot or blobs of toner on you pages? If you get random blobs of toner... You need to take out the drum unit & remove the primary charge unit & remove the drum & vac. out a small little grove that seats right below the developer mag roller... It is most likely filled with toner and is dropping on to you paper as copies are being made. Good Luck
Feb 18, 2009 | Minolta EP4000/5000 CS/PRO Copier
Minolta 2050 with ATDC set as 140 and current as 0%
Hello sir; replace auto toner sensor will be ok, that sensor is located on developer unit.
Dec 24, 2008 | Minolta EP4000/5000 CS/PRO Copier
Konica/minolta ep4000 toner not even across page; has partial voids down page. cleaned everything. did half-test and image is bad at drum. what needs to be done next and in what order thank you Bob
You have plenty things to check sorry to say. What is the condition of drum and starter? What about the charge assembly? Is the grid still in good condition?
Jul 04, 2008 | Minolta EP4000/5000 CS/PRO Copier
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
67 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
