Garden Logo
Posted on Sep 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can model# 3001MA spray latex house paint? - Rl Flomaster Garden
Anonymous
Level 2:
  • Expert 124 Answers
  • Posted on Sep 14, 2009
Anonymous
Expert
Level 2:
Answers
124
Questions
0
Helped
70531
Points
398
It should but you might need to thin the paint with water if the paint is very thick. Two or three thin coats are better than one thick coat.
Instructions for earlex 120 sprayer
http://www.manualslib.com/manual/388222/Earlex-Ags120.html
there is your link for your spray gun in general every time you use any spray gun it needs to be cleaned run solvent through it to clean it -water for latex, paint thinner for oils remove the tip housing take out the fluid needle clean it every time so it looks like new.
As for thinning stay around 15% in general latex paint does not atomize well so I tend to stay away from latex on metal parts or like a small box and so on however yes we use latex on homes but an airless sprayer is used you basically have a style of "cupgun" thats for detail work... EARLEX AGS120 Operating Instructions Manual
Spray gun problems
You basically have what is called a "cupgun" and there are a few reasons for this and it should be pretty simple to fix I want to stress that anytime you spray the paint no matter what latex-oil needs to be thinned with the compatible solvent water for latex paint thinner for oil/Alkyd by about 10% - 18% that could be the problem if you have latex in your gun but probably it has to do with the "needle seat" in the back of the gun there should be a knob to adjust the needle turn your gun on pull the trigger and turn knob till paint comes out if that wont work you may have debris in your paint that has clogged the stem pour all the paint out clean gun completely pour paint threw a strainer cone or strainer bag and be sure to thin it...
How to waterproof cardboard boxes
Paint or spray the cardboard with a waterproof coating
  • Spray the cardboard with an automotive primer and then let it dry. You can also use a variety of waterproof varnishes to provide this initial waterproof coating for your cardboard. Since you will be painting the cardboard with another layer of protective covering, make sure the substance you use for this initial layer can be painted over.
    Next, paint the cardboard with an outdoor latex paint similar to what you would use on the outside of your house. Having these two layers of waterproof sealant--a primer and a latex--should keep your cardboard stiff and dry for quite a while.
Mar 16, 2012 • Cameras
Unable to find part for a type MBC 78596 NO. devilbiss. I want to spry latex paint but do not know were to go to get a larger neddle and spray head
If you haven't already check with your local Paint store. Not Lowes or Homedepot. I mean Sherwin williams or Pittsburg paint. They should be able to get you one.
1helpful
What is the correct concistancy the paint needs to be mixed at for the dynatec psg 45 electric spray gun
It depends on 3 things.
What you are painting.
Whether you are applying latex, oil-base, or primer.
What size TIP you are using.
We use spray equipment and use size 17 and 19 for latex, and 11 for oil.
Double-check the size that came with your gun and look at tips at Home Depot.
Old tips wallow out and the spray pattern is irregular/uneven and the gun blows out too much paint and our material costs go up.
The manual says "dilute correspondingly"
http://www.airless.com.au/Airless%20Sprayer.pdf
Let's say you are spraying oil-base stain: I would NOT dillute this material.
Oil-base primer: 1 thinner to 4 paint
Latex primer: use a roller and brush so you have a good undercoat for the paint.
Oil-base paint: I would add 1/8 thinner with 1 paint, and be careful of runs
Latex stain: try 1 water to 4 stain
Cheap interior flat latex: 1 water to 4 paint
Latex semi-gloss interior: 1-1/8 to 4 paint and apply very thin coats and let dry between coats.
Cheap exterior flat latex: 1+ to 4 paint, and add more or less water as needed
Good exterior latex paint: use a roller and brush because the purpose of latex exterior pain is to apply heavy protective coat over outdoor materials ... dilluted exterior latex will not give sun and mildew protection.
We use heavy spray equipment and apply exterior latex straight form the can. It's the only way to give lasting job, unless you're doing a temporary playhouse.
The key to successful spraying is to strain your paint to get out the lump and clogs - BEFORE putting paint into the gun.
We always strain the paint unless it's a freshly opened can.
If can was opened yesterday, we strain it.
That because paint gets a dry film that will clog the sprayer.
First you need to mix your material, so you need a couple buckets.
Pour the paint and thinning material in 1 bucket, and then to mix, pour back and forth between two or three buckets. This action will mix the paint thoroughly and save you an hour of rotating a paint stir stick.
Next, you need to strain the paint.
Wash out a 5-gallon bucket.
Buy 5 gallon strainer that fits into bucket.
Pour material into bucket with strainer, lift strainer up and then grab end of strainer and squeeze out all the paint.
Immediately put lid over paint so no drying film will form.
Wash out strainer.
You're ready to put paint in spray gun.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on paint project.
Jan 06, 2011 • Garden
When spraying latex paint I do not get smooth finish
Turbine powered hvlp systems are not the ideal system for spraying latex paint. If you plan to do lots of latex spraying an airless system is recommended.
You should be using a 2.00mm or 2.5mm tip. More thinning than recommended may be necessary to get a good spray. The addition of floetrol or similar latex retarder is a good idea. A retarder will slow the drying and allow more time for the paint to level and result in less orange peel finishes
1helpful
Will vaper spray gun do latex paint
Yes is the short answer, but you will need to use a latex wet edge extender (X.I.M) makes one most paint store should carry it. You can also use a bit of water, no more than 10% or as detailed on the label.
Keep adding the extender or water until it stops shooting spatter an has a finer mist.
2answers
I bought a psh1 to spray latex as the reviews
Hi
What size is the jet?
What compressor pressure are you using, LOW is good >20PSI
You will need quite a large jet for latex paint even thinned. I have tried a 1.8mm jet and that still clogs!! Consult your local spray painter with what size jet you need.
I am betting the standard size of 1.5mm is way too small, that type of gun is fine with the correct jet size.
3answers
IR 210g - using thicker paint
i dont have so much as a solution as a couple of things you can try to figure out whats going wrong.
make sure your compressor can handle 10.5 CFM @ 50psi
hook up the gun and dry spray it to check for blockages in the air supply
if the air comes through strong and constant, fill the paint hopper with water and spray until empty
if the water comes through constant, add half of the hopper with paint thinned with penetrol or floetrol
if the paint is coming out weak or spotty, make sure the vent cap is open on the paint hopper
if the cap on the hopper doesnt have a vent, try spraying with the cap off or cracked a bit.
if that doesnt work take off the hopper and check the filter for blockages.
i suggest straining all your paint before pouring it into the hopper
Top Rl Flomaster Garden Experts
Jay Finke
Jay Finke
john h
Are you a Rl Flomaster Garden Expert? Answer questions, earn points and help others
