I think it's the freezer fan that stopped working,open the freezer and see if it goes you should hear it running and even see.This fan allows the cold air into the fridge compartment,without it it takes ages for the fridge to get cold.I've got the same problem if you find the motor online let me know on [email protected]
I had this problem. The Evaporator fan in the freezer was working but no air would be circulated from the freezer into the refridgerator. To test this you open the door of the freezer, and depress the door button(s) of the upper refridgerator doors so that the light extinqueshes in the refridgerator. This will engage the evaporator fan in the freezer. You can check to see if air is venting from the freezer into the refridgerator by feeling the holes at the top most part of the multi-air flow channel in the refridgerator. If air is comming out when the freezer door is open, close the freezer door and feel if air has stopped. If you have kept the upper door buttons pushed in on the refridgerator and now have the freezer door closed, you should still hear the fan running, but may have not air flow with the freezer door closed. The cause of this is the air return channel from the refridgerator to the freezer is either frozen or clogged. My return-air channel was not frozen but clogged by a residue from something that spilled inside of the bottom of the refridgerator. The return-air channel has two vents in the rear-bottom of the refridgerator that exit into the freezer behind the evaporator (cooling coils). You can't see it even if the back interior panel is removed from the freezer compartment.
The bottom line here is that if air is prevented from moving from the refridgerator, back down to the freezer, then your refridgerator will not cool, but your freezer will work just fine. You will not need to replace the fan, unless the fan is not functioning. You may need to check the dampener, to ensure that your multi-air flow channel is open - (allowing air to come into the refridgerator). The multi-air flow channel is easy to remove once all of the shelves are removed from your refridgerator. Only 2 screws holding it in (securing the center rack top and bottom). The top screw is located behind a small plastic cover that can be removed.
Good day,
The common reason for this is the fan motor behind the rear panel in the freezer compartment is not running.
With the machine on and running, open the freezer door. You should hear the fan running.
If not the motor can be accessed by removing the rear panel in the freezer compartment.
Replacement is a nuts and bolts operation.
okay this is what you check for, is your freezer back panel covered with ice, if it is then take the panel off and check your heaters for continuity and look at your bimetal thermastat.
another checking point is do you hear the fan running, if not then you need to replace evaporator fan.
You have a bad fan motor remove the ice maker and the back panel of the freezer and you will see the fan blower. changed and will work like new again :)
could be your evaporator fan which is located in freezer.If you dont hear it blowing when compressor is running then it is evap. fan motor.if you see alot of frost building up on back panel inside freezer then you have a defrost problem.check heater and thermostat to see if they are good or bad.the thermostat will usually pop apart but not always it is located at the top in back of freezer on coils.it will have two wires going to it.good luck.and unplug first.
Hello.
How long did you wait after installing the fan? It takes 24 hours for the unit to recuperate.
If the fan hasn't been working for a long time, you may have not noticed it was running a lot, but with the new fan you can hear it. Let me know if you don't think this is the case and I can guide you through some other options.
More likely than not there is a blockage of ice bettween the freezer and the refridgerator. most fridges work to get the freezer cold as a priority.Then the cold freezer air is circulated throughout the rest of the unit to keep the fridge cold. Thats why you may hear a fan running in the fridge unit while the compressor is not on. Unplug and open the doors to warm the inside. Look at the plastic piece bettween the two units and remove. See if there is ice build up and use a hair dryer to melt, dry area out and restart the unit by plugging back in or turning temp dial. Hope this helps.
