Question about ATI Asus P4R800-V Deluxe Radeon FSB800 Prescott Ready Motherboard (MOTAS30)
No signal to monitor.......all dark
I hear the fans go when i turn it on.....that's it...nothing else.
    Problem Solver:
  • 15 Answers
And im sure the screen appers to be blank and the key board lights flash once and no feed back other than the fans spinning right? . this is a common problem with asus motherboards and AMD cpu's which indicates a bad motherboard or cpu if you have acces to anouther cpu try changing to that one if that doesnt work you're motherboard is gone
thank you
Posted on Dec 11, 2007
I have a NEC PlasmaSync 42MP02. When I turn it on, there's a click the standby LED changes from red to green, but then goes back to red again. Nothing appears on the screen, it remains dark.
Monitor is not receiving the video signal. Check the video connection cable at the back, also test the monitor on a different computer.
Jul 05, 2008 | NEC Televison & Video
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Nov 02, 2012 | HP Pavilion a1720n PC Desktop
My 3210 fails to start up the repair shop says it the motherboard replaced it and the cpu and the psu and it still doesnt start up any ideas
if you have change already the motherboard, cpu and psu here is what you need to do to check your pc by yourself and may be figure out what the cause of the problem.
1. connect the connector on your psu the motherboard. connect psu connector for hard drive, cdrom drive exhaust fan.
2. turn on the pc. look inside, if you see the led on the motherboard turn green then there's a power coming out from the psu.
3. hear the hard drive if its working, you can feel it vibrate.
4. check the little blower in the video card, if its spinning then there is supply in it.
when you turn on your pc the logo on the screen on the monitor will display. should you not see it, check if the monitor is plug in the ac outlet or the extension of your computer. if you see it then monitor is good. If this display followed by a dark screen with no signal display, then it means it is receiving no signal from your video card. go check the vga cable if its properly fix to the monitor and the video card. you can also detach the video card from the motherboard and reseat it properly. this sometime is the fix for no display.
If after booting after the logo, nothing else but dark screen, then is suggest you loosen the harddrive and reseat the connector properly, restart the system again. you can also check if the voltage from the power supply is dropping when there is a load in it. using a multitester test the 4pin connector. readings from the red wireshould be +5vdc and the yellow +12vdc. If its dropping then system will hang. check if there is shorted in your cpu, most of the time it is the blower or exhaust fan.
post back your findings so i can still help you out.
he power cable on your psu and the plug to the ac outlet. turn
Feb 08, 2011 | E-Machines eMachines Desktop PC
Signal has gone
If the monitor comes on and displays a message like "no input signal" or something similar, it's working properly but there is nothing coming from the computer. People often think that the computer is working and the monitor is at fault, when in fact the computer isn't starting up.
When you turn on the computer, do you hear the normal sounds of the power supply fan running and the hard drive spinning? Most computers will give a beep when they turn on and the motherboard finishes some startup checks. Do you hear that? Do you ever hear the normal startup sounds that mean Windows is actually running?
If you are convinced the computer is starting and booting into Windows, I would suggest you borrow a known good monitor to use as a test. If it works, that obviously means yours is bad. In most cases there's nothing you can do to repair a monitor yourself beyond checking for loose connections, bent pins in the signal cable plug, or a damaged cable.
If a known good monitor still has no image, the computer is at fault. Either the video card or integrated video isn't working, or the computer isn't actually starting up. In any case, that's where you would need to start looking for the cause.
Hope this helps you along the way to solving the problem. Thanks fo using Fixya!
Feb 02, 2010 | ViewSonic VX2235WM Monitor
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
Gateway FPD1760TFT LCD monitor
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Monitor not getting signal
Check your cables.
If the cables are fine then there is something
wrong with your comuter.
Do you hear any beeping sounds?
Mar 07, 2008 | HP Compaq d530 SFF PC Desktop
ATI Asus P4R800-V Deluxe Radeon FSB800 Prescott Ready Motherboard (MOTAS30) Logo
121 people viewed this question
Top ATI Computers & Internet Experts
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
