Question about Bose Wave Radio
Wave CD changer
We have a wave w/ 3 CD changer...the CD in the top unit works fine, but if I load CDs in the lower unit it spins them up and then gives an error message. any help would be great!
  • musicalkt Apr 05, 2008
    Yes, often times when I play a CD not played before in the Boze Wave- it shows the error message - sometimes spits it out. If I put back in a few times it will play.
    Now - I always push eject on the remote first to be sure there's no CD in the player. This time no CD came out so I put a new one in - walked away-realized it was playing - came back to find it half in. In trying to gently push it back in again - won't go and it feels like there was a CD in prior!!
    There are five screws to remove the grilled bottom part....what's the chances I'll b e able to see and remove a CD if in there?
    Any help is appreciated.
  • 16 Answers
Could try a CD lens cleaner disc, but this will just as likely get stuck inside. Far better to contact Bose for a repair - sounds like a problem in the changer mechanism
Posted on Jan 25, 2008
Someone put 2 cd in the top cd player how do we eject them
that is a problem because your system cannot read/receive commands thatr are blocked. Try ejecting by taping the player. If not, someone has to open the unit to get the cds out. Now this is an expensive unit so have someone knowlgeable to look at.
Sep 25, 2013 | Bose Wave music system Multi-CD Changer...
How do I load cd into bose multi changer
The owners manual should tell you that- I think you just insert them.
Dec 08, 2012 | Bose Wave music system Multi-CD Changer...
Wave Music system Multi-CD Changer
The unit has a power supply problem, no user servicable parts inside. Bose uses a thermal fuse built into the power transformer. Take unit apart and check for connection issues first, then look for a possible fuse, if none exist chances are it is in the power transformer, contact Bose for service.
Sep 02, 2012 | Bose Wave music system Multi-CD Changer...
I have a bose wave system. I tried loading cds in the multi changer and kept showing error and never would play. The multi changer still has one of my disc and will not eject. I tried unplugging and...
Hi, The cd disc is not in his place inside the multichanger, you must open the appliance and try to take out the cd without forcing, otherwise you wil brake the mechanical system,
after this the system will work well.
Jan 30, 2011 | Bose Wave music system Multi-CD Changer...
Cd will not eject from cd disc error message and will not read the cd.. disc errors on cd2 and cd4,but will eject the cd.will not play cds. have unplug both units for an hour. no change...
My first guess would be that the loading belt is slipping. This will prevent the cd from loading completely and thus won't read. The belt costs around $2-$3. Care must be taken when opening up this unit.
Let me know if you need any additional info.
Sep 30, 2010 | Bose Wave music system Multi-CD Changer...
2000 jeep grand cherokee limited 10 disk cd changer says ''err''
The in-trunk units have a tendancy to go bad. you can take the cover plastic interior cover off to access the CD changer, un bolt the changer, and visualy inspect the two rollers for debris, or missing /broken gears that move the rollers to take the CD from the CD cartrage to the player. if that looks fine, chances are that the laser went bad (common in rear mount units) and you can order a new one from Jeep, or you can remove it and update the in-dash head to an aftermarket of your choice (& yes you steering wheel controls will still work). you could also fit a more modern MP3 unit where the Changer was.
Feb 20, 2010 | 2000 Jeep Grand Cherokee
Ford cd changer problems
CD player is not working. Motor will not unload or load discs. It will play CDs fine but cannot change them. Unit will need to be repaired by an audio specialoist or replaced.
Sep 07, 2009 | 2003 Ford F250 Super Duty Crew Cab
Bose Wave Music Sys & 3 CD Changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will probably have to be disassembled to get the CD out or have it serviced.
Dec 23, 2007 | Bose Wave music system Multi-CD Changer...
Playing CDs
An old post but did you get an answer and do you need a copy of the manual?
Jun 29, 2007 | Bose Wave music system Multi-CD Changer...
Bose Wave Radio Logo
584 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
