Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Brother MFC-240C Change Unable 50
I get Change Unable 50 error. There is no paper jam or foreign object as the manual suggests for the possible cause of this error. I checked the other post but the picture is not so clear to take the unit's cover apart so that I get to see the print head. Please let me know how I can fix this problem. Thank you.
  • 7 more comments
  • aoiisora Dec 12, 2007
    I can't see the picture of how to open the scanner cover. I can take off two small plastic pieces easily but the picture is not visible to see how to go beyond and access the print head. Would you please show me a picture with better resolution?
    Thanks a lot in advance.
  • Anonymous Dec 19, 2007
    I have a Brother MFC-845CW Printer. I just bought this printer 6 months ago. I am getting an "Unable to Clean 50". Please let me know of any fix for this problem.
    Carolyn
  • Bellboy Jan 01, 2008
    I bought my MFC-240C printer about 6 months ago and it worked great. When printing on plain paper I don't have a problem, but if I try printing labels or photos I get an "Print Unable 36" error message. There is no jam as I can print to plain paper after this message.
    Any help would be greatly appreciated
  • rashane1 Apr 23, 2008
    brother mfc-240c message print unable 50 and sometimes 30
  • Anonymous May 02, 2008
    I remove te paper, then I disconnct the printer, but still the screen says unable to print 50 and sometimes 30
  • Anonymous May 12, 2008
    paper jam and empty cyan
  • Momma Bear 1 May 14, 2008
    How do I get rid of unable to change 50 or 30? thanks
  • smascola Feb 08, 2009
    I followed the instructions (and was able to make the pics bigger by saving them first...kind of blurry but better). Anyway, I took the printer a part seveal times and reseated the ribbon. Still nothing.....I started with print unable 50 message, then print unable 30 message.....then I got a printer jam message only to have it now turn to a print unable 32 message. I don't want to take the printer apart again....might just throw it out the window though.
    I have to say though, the first time I took it apart, the ribbon was unseated. Then I didn't put it back in the right place. The last couple of times, I did put it back in the right place...even cleaned the ribbon. It does look like there are a couple of smudges on it though that won't come off. I have no idea how they got there.
    Anyway, curses to Brother for making their error message so nonsensicle...and their "trouble shooting guide" equally useless. The weirdest thing is that wiht this error message NOTHING works, I can't even turn the printer off!!!!!!
  • Anonymous Mar 16, 2014
    brother dpc j125 unable to unit 50 remove papaer and close scanner cover
I also had this problem, your solution was spot-on, remove the top cover and control panel and re-seat the encoded strip. simple.
boy, are you guys good.
Posted on May 17, 2008
The solution jast like Solution #3 :
1-remove the top cover
2-remove the panel
3- re-seat (re - s e a t !!! not re- s e t !! ) the encoded strip.
now i will write in hebrew :
1-לפתוח את המכסה של המדפסת
2-להרים את הקונטרול פאנל (איפוא שכל המספרים הצג וכו') יש שם 3 ברגים להוציא את הברגים להרים את המכסה הזה שם יש שני חיבורים שבכל חיבור יש כמה חוטים, להוציא את שני החיבורים הקטנים האלה ולהחזיר מחדש לפתוח מחדש את המדפסת . אני מקווה שזה יעזור
Posted on Apr 21, 2009
  • 832 Answers
  • Mix-it-up
    Mix-it-up Dec 13, 2007
    Sorry no chance of pic with higher resolution. This is restriced by fixya program (you can complain about that by contacting the team. Nay be there will be a more intelligent solution in future!)
    Try to use a higher resolution by help of your browser.
    Here are some more hints: You have to push down a plastic at the bottom next to the blue support to get the support loose. When opened the 2 plastics as you have written unplug the cables and flat cable so that you can push the scanner backwards from printer. loose screws which can be seen. you have to press/click the dashboard upwards to get to the hidden screwes which are left. there are two hosses on the left and right side where the printer cover is
    mounted. now you should be able to pull up the cover. Et voila! You can see into the printer and simply fix the small foil which runs paralell to the ph right into position (This can be seen on the
    last pic.) afterwards stick some adhesive tape onto the ph to
    avoid the lift next time there is a jam!
    When reassemble be careful with the encoder disc!
    Do not stain nor break it when fixing the cover.
  • Mix-it-up
    Mix-it-up Dec 20, 2007
    @carolyn (mfc 845cw):
    Did you had a paper jam before?
    There could be some paper left on the traveling path way which cant be seen from out side.
    Open printer as described and have a good look into both edges of the travelling path way (espacially the left side where the encoder disc is mounted on one of the gear wheels).
    Press gently onto the ph cover to make sure it is clicked into the rail.
    Do check the encoder strip (small plastic foil paralell to ph) Is it in right place upon the ph? (see pics for that)
    New Friend:
My MFC-845CW reported "Unable to Change 50". It cleared after I manually inserted a sheet of paper at an angle and then moved the printhead over the paper. The paper absorbed some black ink, which surprised me but like I said the error cleared.
Posted on Jul 08, 2015
Thank you the above post was far more informative than the minipics
Posted on Aug 18, 2008
Guess What? These printers **** !!!!!!
Posted on May 25, 2008
Unnable to scan with my mfc-2400c
Posted on Dec 15, 2007
2 Suggested Answers
  • 526 Answers
SOURCE: BROTHER MFC-240C,UNABLE TO CHANGE 50
This error is usually caused by the Carriage Encoder Strip being dislodged from
the sensor mounted on the Print Head/Carriage Assembly.
Unfortunately, you will need to remove the scanner assembly, and top cover assembly to check to see if the encoder strip has come out of the printhead assembly.
Posted on May 05, 2009
Clear "error 76 : Unable to clean" on brother printers mfc-j430w
Most likely, The machine has a mechanical problem or a foreign object such as a paper clip or ripped paper is in the machine
Nov 20, 2013 | Brother Multi-Function Center MFC-240C...
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
Clean Unable 46
Clean unable 46 means that the ink tank is full. You need a replacement tank installed and the count reset. This is a holder inside for the used ink,best to be a shop repair.
Jun 23, 2009 | Brother MFC 240C All-In-One InkJet Printer
Error : Unable to clean
Unable to clean means that the waste-ink "sponge" is full. If you've already checked for small paper part (which is very unlikely to cause this error message), the error is mechanical. Unfortunately, that's not something us users can change, but the machine would require to be sent to service. So if your machine is not within warranty, I'd doubt it'll be worth the service cost.
Jun 02, 2009 | Brother MFC-5840CN All-In-One InkJet...
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
May 05, 2009 | Brother Multi-Function Center MFC-240C...
Screen says CHANGE UNABLE 51.
Follow the instructions listed below:
Error Message Cause Action
Change Unable
XX
problem.
—OR—
A foreign objects such as a clip or
ripped paper is in the machine.
Open the scanner cover and remove any foreign
objects inside the machine. If the error message
continues, see Transferring your faxes or Fax
Journal report on page 90 before disconnecting
the machine so you will not lose any important
messages. Then, disconnect the machine from
the power for several minutes and then
reconnect it.
Try this and let me know if this helped solve the problem. Binary Bob
Nov 29, 2008 | Brother MFC 240C All-In-One InkJet Printer
What is 'print unable 51' never had a paper jam!
Do the following:
Print Unable
XX
problem.
—OR—
objects inside the machine. ( You might try cleaning the scanner glass.)
If the error message continues, disconnect the machine from
the power for several minutes and then reconnect it.
Try this and let me know what happens. Binary Bob
Nov 21, 2008 | Brother MFC 240C All-In-One InkJet Printer
Error Message: Scan Unable A6
did you get the solution to the problem u mentioned
Feb 21, 2008 | Brother MFC-8220 Fax
the scanner or main circuit board is defective. Give it back to dealer due to warranty.
Jan 12, 2008 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
13,711 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
