Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Not full cycle
The dishwasher starts a cycle- it will do the initial rinse, then starts to run the wash cycle, but only runs about 5 seconds then quits. It repeats this 3 or 4 times & then is done. It doesn't drain any of the water in the bottom. I can tell it to drain & it does fine. I've checked the arms & nothing is keeping them from spinning. I've removed the shelves & still thesame problem.
  • Anonymous Dec 22, 2007
    i have got exactly the same problem
    Problem Solver:
  • 10 Answers
Check the board for burned spots.
Posted on Dec 15, 2007
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol ABOVE the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the SANITIZE button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
My Whirlpool dishwasher washes but does not rinse or dry
Most likely the control panel is defective. Go to the repairclinic.com for further diagnostic help and parts.
Apr 25, 2017 | Dishwashers
913T Dishwasher Stops after 10 seconds
913T is a very old model (1996), I have one, I'm not a repairer, I have the same fault. It doesn't have drawers or infrared or a display.
I've just shortened the ribbon cable, which had pinch damage at the door close pinch point. I used a male & female ribbon squeeze connector pair to make a good clean joint. With the cable fault it wasn't even starting the drain cycle. Now it does start, but then long beeps, and I suspect it's detecting a fault with the motor or a sensor or faulty wire, and is halting.
I've found running the rinse cycle first then allows the main wash cycle to run, no longer stopping at 10 seconds (after the initial drain), just as the first power wash commences.
May 24, 2012 | Dishwashers
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Diplomat Dishwasher ADP8352 Will not complete wash Cycle
My Diplomat ADP8352 when running a cycle it will run for ages, doesn't seem to get hot. If i switch off the m/c then switch it on again it dumps the water left in the m/c?
any ideas?
Jan 04, 2009 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Kenmore 74362
I had the same issue and you will never beleive the solution.
Steps to follow:
1) run one full cycle with no dishes or soap
2) run one full cycle with a dishwasher cleaner like Jetdry
3) run one full cycle with a gallon of white vinager
4) never put soap in the extra in and only fill the main soap bin half way.
should work fine from here on out, but never fill main bin more then half way when you do dishes. also run the hot water in the sink until the water is very hot before starting the dish washer.
Dec 19, 2008 | Dishwashers
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwasher only runs in rinse only mode!
my dishwasher just keeps bleaking clear AND NO WATER IS GOING INTO THE MACHINE IT JUSTS KEEPS RUNNING BUT THEIR IS NO WATER COMING IN.
THANKS
Jun 30, 2007 | Maytag 24 in. MDB5601A Free-Standing...
Quick Wash cycle restarting
Aestaie, On the quick wash cycle the machine goes through a heated rinse at 160 degrees. I think what's happening here is that the board checks the thermistor and is finding that the water is not hot enough and say's, hey, I need more time to heat this water and resets itself. The element in the dishwasher will only heat the water 1 degree every 3 to 5 minutes. So after the initial wash, there is a 2 minute drain, it fills again and there is the heated rinse. If the water is 120 and the final rinse needs to be 160, we have some heating to do here. Therefore the reset. Sounds like the dishwasher is working OK, Catriver..post back
Apr 24, 2007 | Maytag MDB9600A Jetclean II Built-in...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
135 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
