Question about Nikon COOLPIX L4 Digital Camera
Blury and dark pictures
Hey I am having a problem taking pics outside at night they come out almost completly black. And when I try to take pics in my home it is fine but at my sons indoor basket ball games ths pics are either to dark or if the pic comes out brighter it is VERY blury I love the camera and it takes great pics i hope itis just a setting problem hope you can help
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
Taking a picture, everything that is white is pink and dark pics
Oops, it looks like you have a couple of annoying problems with your Kodak camera.
Is your camera still in warranty by where you bought it (30 days) or the manufacturer (1 year)?
Jul 10, 2010 | Kodak EasyShare CX7525 Digital Camera
I have a Nikon N60. Can't take pictures outside
can you manually change your f-stop to faster shutting. When the shutter stays open longer, it will draw in to much light. If you have an option for only outside pics, then I would try that as well.
Feb 06, 2010 | Nikon N60 35mm SLR Camera
Pictures taken inside are coming out dark and blury
Please readjust the ISO: Different SCN (If you're experiencing this problem with your low light pictures try and use SCN night, the logo shows a moon and a star, with or without Flash.
Jan 01, 2010 | Kodak EasyShare C875 Digital Camera
Fotos are white
Try the video. Is it ok?
Adjust the zoom so the internal lens is up close to the outside lens. Now, look into the lens at an angle so you can see into the lens without reflection. With the flash "off" so as not to blind you take a picture and watch the shutter close over the lens. Did it cover the lens? If not then something is obstructing it or there is an electrical failure with the electro magnetic switch operating the shutter.
Apr 24, 2009 | Fuji FinePix S6500 Digital Camera
I TALKED TO KODAK DIDN,T HELP
Trying taking indoor pictures in the "Night Portrait" or "Night Landscape" modes in the "SCN" command. Be careful not tho shake the camera in these modes.
The "Party" mode works well if the people in the picture are close to the camera.
You could also play with the settings in the "P" command to adjust the amount of light entering the camera.
Good luck.
Jan 08, 2009 | Kodak EasyShare Z760 Digital Camera
NIght time Evening Pictures
check the mode and check the flash to make sure it is on auto
Dec 12, 2008 | Olympus FE-230 Digital Camera
Blurry
when using any digital camera, you need to do a soft press on the shutter button to capture better pics... when pressing down hard, the images tend to be less than desirable
Jun 11, 2008 | Olympus SP-500 UZ Digital Camera
Night pictures
a) Place the camera on a tripod (or a steady surface - e.g. a chair)
b) Select P mode
c) Focus and take the shot.
Most probably, with the above settings, the camera will select a longer exposure without flash, lighting the scene properly (i.e. making it appear as night, as it should be). However, know that this will also create motion blur of moving subjects (the kids, in this case). If you want to avoid this, you must use flash in slow sync mode. Press repeatedly the flash button, until you see the "slow" indication on the screen (where the flash info appears, down left). Again, the camera should be on a steady surface.
If your pictures are again too bright, it means that the Exposure compensation is for some reason set to +. Use the appropriate button (check the manual if you don't remember which one it is) to fix it
Dec 18, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
Blury pictures
change the resolution setting in setting. and also you can adjust diplay bright ness and contrast for bets view & pics .thsi will solve the problem. Thanks Sangita
Jul 08, 2007 | Samsung Digimax S500 Digital Camera
Blury Display on FE140
It sounds like your lens's focus element is stuck. Given the events you describe it is possible that a grain of sand has worked its way into the focus motor's gearing and jammed it up. Normally the small motor moves the focus optic in and out to achieve proper focus, if its movement is limited or completely jammed you will experience blurry pictures. The camera will have to be disassembled and the sand cleaned out to restore normal function. There are repair providers you can find online who can work on your camera. David Millier Advance Camera Repair
Mar 20, 2007 | Olympus FE-140 Digital Camera
Nikon COOLPIX L4 Digital Camera Logo
87 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
