Using headphones with my yamaha dsp a595a amp
When i plug them in the sound still comes through the speakers and i dont seem to be able to turn them off,there are 2 bttons for speakers a and b but thy dont seem to do anythng...
  • 1,512 Answers
If you turn speakers A and B off together, there should be no sound coming out from your speakers(be sure that you do not have the amp operating in surroundmode.). The headphone cct in this amp is not affected by speaker switching and remains on all the time. v
Posted on Dec 17, 2007
My yamaha rx-v663 receiver is having problem with sound. Everything works but no sound.
It will be dry joints around the output stage, nothing to do with software.
Aug 04, 2018 | Yamaha Audio Players & Recorders
I have a yamaha yst sw320 subwoofer connected to a yamaha dsp-a595a amp. I recently disconnected my equipment and when i reconnected it im getting a feedback hum/noise through the sub. I've tried...
Subs don't go to a variety of connections on the amp. Let's stop guessing and stick with the prescribed one.
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Yamaha-YST-SW320-Subwoofers-manual/id/320bh340/t/2/
See page E1 regarding placement and safety.
http://www.retrevo.com/support/Yamaha-DSP-A595-Amps-manual/id/319ag821/t/2/
Page 44 - read about "humming".
If you have hum on the sub, is it there with and/or without the input cable attached?
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Mar 02, 2011 | Yamaha YST-SW320 Subwoofer
My yamaha DSP AX1 amp does not work when audio is connected via optical or coaxial any suggestions how to correct this. no sound comes from any speaker except the subwoofer.
Are all the speakers turned off (set to None) in the speaker menu.(except the sub)?
2 channel direct analog stereo may still work, but any surround modes will use the speaker settings and the full DSP digital section.
Check also the input mode isn't incorrect - although if the sub is wired correctly and gives sound this can't be whats wrong.
Aug 26, 2010 | Yamaha DSP-AX1 10-Channel Amplifier
No sound at all. Power is on and all lights light up, but so sound output regardless of speaker selected or input.
I do not have experience with this particular amp. Generic trouble shooting follows:
Might it be that you have headphones plugged in? (Unplug them, they turn off the speaker output) You are absolutely certain of the settings on your amp? (check them again) Are you certain you have an input? (AM, FM, CD, AUX, other) (Make sure the input is turned ON and the source is properly selected.
Is the output protected by a fuse or fuses? (look on the back panel for fuses or fuse holder)
Everything that is suppose to be plugged in IS plugged in ... all cables are intact? Did you check them for contunity? You can check contunity with a flashlight battery, the light of a flashlight and a paper clip.
Speaker selection switches are pressed as appropriate. Speakers are connected to the appropriate outputs and they are ON. Speakers are of proper rating - and resistance? 4 ohm - 8 ohm - 16 ohm??? Any controls on the speaker are set at a neutral setting?
I'm sorry your device is not functioning as you think it should. These things are designed to work and generally, they are pretty good at it. Sometimes, they just break (stop functioning) It may be that you will have to take it back from where you got it for repair or adjustment. But I am hoping you have the headphones plugged in.
Thanks for your interest in FixYa.com
Dec 26, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha Dsp-A1000 5 ch amp Bought a used amp will be hooked to an awia reciever and speakers also have two subwoofers need help to install correctly witch connections to use
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
Jul 24, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
I have a yamaha rxv2500 no sound coming out
check your speaker wire and speaker for open circuit.
Nov 28, 2007 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha dsp a2
Check the A or B switches it could be they are turned off!
Sep 28, 2006 | Yamaha DSP-A2 Receiver
93 people viewed this question
 Grubhead
Grubhead
